Tricky rational function integral
The problem involves evaluating the integral of a rational function, specifically \(\int \frac{4x^5-1}{(x^5+x+1)^2} dx\). Participants are exploring various methods to approach this integral, including partial fractions and integration by parts, while considering the context of preparing for the math GRE.
  • Participants discuss the potential use of partial fractions and the derivative of the denominator as a means to simplify the integral. Some express uncertainty about the effectiveness of these methods, while others suggest that the structure of the problem hints at a specific approach.
The discussion is ongoing, with various participants sharing their thoughts on possible methods. Some have offered insights into the structure of the integral, while others are questioning the feasibility of certain approaches. There is no explicit consensus on the best method to solve the integral.
Participants note the complexity of the problem and its suitability for a standardized test like the GRE, with some expressing skepticism about its inclusion due to its challenging nature. There is also mention of the potential for multiple interpretations of the integral's solution.
terhorst
[tex]\int \frac{4x^5-1}{(x^5+x+1)^2} dx = ?[/tex]​
The solution is
[tex]- \frac{x}{x^5 + x + 1}[/tex]​
Other than getting lucky and noticing immediately that this could be the derivative of a fraction, I do not see an easy way to solve this. The partial fractions solution is long and involved. I am reviewing calculus material to study for the math GRE, so am trying to see if there is a more efficient way. Given the level of the other exercises in this book, I would be surprised if there were not. Help me see the light! Thanks :-)
I don't know a more systematic way than partial fractions. Of course, you might look at (x5 + x + 1)' = 5x4 + 1 and observe that x(5x4 + 1) - (x5 + x + 1) gives you the cancellation you need. You might even suspect it from looking at how convoluted the solution would be otherwise. Still, not so easy without hindsight. If there is indeed a better way to handle such questions, I too would like to know.
This is a problem I would have skipped if I had seen it on the math GRE. :) Since the GRE is multiple choice, you could always take the answers and differentiate them and see if you recover the integrand.
Generally, though, I'm not sure how you'd solve this problem. The squared function on the bottom suggests that it could be the result of the quotient rule. That might be enough of a hint to notice what Tedjn said.
You can do it by parts. Use v=1/(x^5+x+1) with the original integral being u*dv. It just happens that the v*du integral works out nicely. It's not a general method. It just happens to work out that way. And I only guessed that by working backwards from the answer. I really can't see any reason to put this on the GRE, except for cruelty.
Here is an efficient way:
[tex] \frac{4x^5-1}{(x^5+x+1)^2} = \frac{Ax^4+B}{x^5+x+1}+\frac{Cx^4+D}{(x^5+x+1)^2}[/tex]
[tex]4x^5-1 = (Ax^4+B)(x^5+x+1)+(Cx^4+D)[/tex]
I think it's much faster then the other methods.
Multiplying that out,
[tex]4x^5- 1= Ax^9+ (A+ B)x^5+ Cx^4+ Bx+ A+ B+ D[/tex]
Since there is no [itex]x^9[/itex] term on the left, A= 0. Then A+ B= B= 4, but there is no "4x" term on the left. That does not work. There are no "A", "B", "C", and "D" satisfying that equation for all x.
  • · Replies 19 ·
