Finding the Phase Angle for a Differential Equation Solution
  • Thread starter Thread starter Sparky_
    Form Trig
The discussion revolves around finding the phase angle for the solution of a differential equation expressed as -cos(√2t) - 2sin(√2t). The user initially miscalculated the amplitude A, stating it as 5 instead of the correct value of √5. Various methods for calculating the phase angle phi were attempted, yielding different results, but none matched the book's answer of 3.6052. The correct approach involves using the ASTC quadrant diagram to determine that the angle phi should be expressed as π + phi. The final clarification confirms that A is indeed √5, correcting the earlier error.
Sparky_
This is a solutuion to a differential equation I've solved:
-cos(\sqrt(2)t) - 2sin(\sqrt(2)t)
I've been asked to put it in the form:
Asin(wt + phi)
A= sqrt(-1^2 + -2^2)
phi = sin^{-1}phi = \frac{c1}{A}
phi = cos^{-1} phi = \frac{c2}{A}
and
phi = tan^{-1} phi = \frac{c1}{c2}
A = 5
phi = sin^{-1}phi = \frac{-1}{\sqrt(5)}
phi = -0.4636
phi = cos^{-1} phi = \frac{-2}{\sqrt(5)}
phi = 2.678
and
phi = tan^{-1} phi = \frac{-1}{-2}
phi = 0.4636
Can you help with the phase angle? (3 different answers - none of which are correct)
The book has 3.6052 which I see is pi + 0.4636.
Thanks
-Sparky
Sparky_ said:
A = 5
A isn't 5. You miswrote your answer here, despite having found the correct one.
Sparky_ said:
\phi = sin^{-1}\phi = \frac{-1}{\sqrt(5)}
\phi = -0.4636
\phi = cos^{-1} \phi = \frac{-2}{\sqrt(5)}
\phi = 2.678
The "basic angle" (do you use that term? I don't know if this is the proper term) of \phi is 0.4636.
sin \ \phi = -\frac{1}{\sqrt{5}} Are you familiar with the trigonometric quadrants ASTC, where A is the top right hand quadrant and the rest are labeled in that order anti-clockwise?
From that diagram, sin is negative for the bottom 2 quadrants. That means to say the angle phi is either \pi + \phi \ \mbox{or} \ -\phi'
cos \ \phi = -\frac{2}{\sqrt{5}} Again you want the values of the angle for which cos phi is negative. From the ASTC quadrant diagram, cosine is negative for \pi - \phi \ \mbox{or} \ \pi + \phi
The only possible solution which satisfies both is \pi + \phi.
Oops, typing error, I meant A= \sqrt(-1^2 + -2^2)
A= \sqrt(5)
Thanks
