Trig Identities - Pre-calculus in a Nutshell - Section 4 Question 1
The discussion revolves around proving the trigonometric identity $$\frac{\sin \theta + \tan \theta}{\csc \theta + \cot \theta} = \sin \theta \tan \theta$$ using various algebraic manipulations. Participants share their approaches, emphasizing the importance of converting all terms to sine and cosine for simplification. Several strategies are suggested, including clearing fractions and extracting common factors to facilitate cancellation. There is a consensus on the utility of different methods for tackling such identities, with some expressing a preference for avoiding auxiliary functions like sec, csc, and cot. Overall, the conversation highlights the collaborative effort to understand and solve trigonometric identities effectively.
MichaelRocke
Morning, I hope someone could help me. I've tackled this one a few times and keep getting stuck.
Essentially its to establish the following identity
My latest attempt
\begin{align*}
\frac{\sin \theta + \tan \theta}{\csc \theta + \cot \theta} = \\
\frac{\sin \theta + \tan \theta}{\csc \theta + \cot \theta} \cdot \frac{\csc \theta - \cot \theta}{\csc \theta - \cot \theta} =\\
\frac{\sin \theta \csc \theta + \tan\theta \csc \theta - \sin \theta \cot \theta - \tan \theta \cot \theta}{\csc^2 \theta - \cot^2 \theta} = \\
\frac{1 + \tan\theta \csc \theta - \sin \theta \cot \theta - 1}{\csc^2 \theta - \cot^2 \theta} = \\
\frac{\tan\theta \csc \theta - \sin \theta \cot \theta }{\csc^2 \theta - \cot^2 \theta} = \\
\frac{\tan\theta \csc \theta - \sin \theta \cot \theta }{1} = \\
\frac{\tan\theta}{\sin \theta} - \frac{\sin \theta} {\tan \theta} = \\
\end{align*}
I would even be grateful for any resources on solving problems like this, I have checked out few youtube videos which are helping, but the problems explained tend to have less terms.
Many thanks in advance
I'd convert everything to \sin\theta and \cos\theta first then simplify the expression.
Likes DaveE, MichaelRocke and PeroK
MichaelRocke said:
Homework Statement:: Morning, I hope someone could help me. I've tackled this one a few times and keep getting stuck.
Relevant Equations:: $$\frac{\sin \theta + \tan \theta}{\csc \theta + \cot \theta} = \sin \theta \tan \theta$$
The first thing I saw was a factor of ##\sin \theta## on the LHS:
$$\sin \theta + \tan \theta = \sin \theta(1 + \frac{ 1}{ \cos \theta})$$
Likes MichaelRocke
FWIW I simply cleared the fraction by multipying by denominator. Everything cancels apart from the numerator.
$$ \frac{sin+tan}{csc+cot}=sin.tan \ \ \ \ \text {[multiply bs by } (csc+cot) \text{ ]} $$
$$⇒ sin+tan = csc.sin.tan + cot.sin.tan$$
$$⇒sin+tan=tan + sin \ \ \ \ \ W^5 $$
Thank you for your replies!
I have gotten so far\begin{align*}
\frac{\sin \theta + \frac{\sin \theta} {\cos \theta} }{\frac{1}{\sin \theta} + \frac{\cos \theta}{\sin \theta}} = \\
\frac{\sin \theta (1 + \frac{1} {\cos \theta}) }{\frac{1}{\sin \theta} + \frac{\cos \theta}{\sin \theta}} = \\
\frac{\sin \theta (1 + \frac{1} {\cos \theta}) }{\frac{1}{\sin \theta}(1 + \cos \theta)} = \\
\frac{\sin^2 \theta (1 + \frac{1} {\cos \theta}) }{(1 + \cos \theta)} = \\
\frac{\sin^2 + \frac{\sin^2 \theta} {\cos \theta} }{(1 + \cos \theta)} = \\
\frac{\sin^2 \theta} {\cos \theta} = \\
\sin \theta \tan\theta
\end{align*}
Where I think I want to get it to the $$\frac{\sin^2 \theta} {\cos \theta}$$ bit of but keep running into brick walls.
Gonna have a little break and crack on again later tonight. I feel such an idiot for not getting this, but that won't stop me from trying!
\end{align*}
Just take a factor of ##\cos \theta## out the denominator and you are done.
Likes scottdave and MichaelRocke
There was a direct approach:
$$\frac{\sin \theta + \tan \theta}{\csc \theta + \cot \theta} = \sin \theta (\frac{1 + \frac{1}{\cos \theta}}{\frac{1}{\sin \theta} + \frac{\cos \theta}{\sin \theta}}) = (\sin \theta \tan \theta)(\frac{\cos \theta}{\sin \theta})( \frac{1 + \frac{1}{\cos \theta}}{\frac{1}{\sin \theta} + \frac{\cos \theta}{\sin \theta}})$$
The strategy is to take out the answer and reduce what's left to identically ##1##.
Likes MichaelRocke
Thank you!
I literally stuck at it for a few minutes more and learned how to fiddle with the fractions so it cancels
\begin{align*}
\frac{\sin^2 \theta (\frac{\cos \theta + 1}{\cos \theta}) }{(1 + \cos \theta)} = \\
\end{align*}
Shout out to PeroK for your help! Cheers!
Likes scottdave and PeroK
I think you'd have found it much easier to keep the cot, csc and sec. The whole idea (I thought) of using these auxiliary functions was to avoid all the fractions.
Then start by clearing the given fraction and work with sums and products.
Once you get a term containing a pair of reciprocals, like cot and tan, they just disappear.
I'm not sure this would help if the result were a complicated fraction, but here you knew the result was simple sin and tan, so all the other functions must cancel.
This is a very neat solution, but I think it would be better like this:
$$\sin \theta \tan \theta (\csc \theta + \cot \theta) = \tan \theta + \sin \theta$$
Since:
$$\sin \theta \csc \theta = 1,\ \tan \theta \cot \theta = 1$$
And the result follows.
Likes neilparker62
Fair enough. I'm not very math-sophisticated.
I did wonder whether I should have done it by some formal procedure, but it seemed so obvious once you simplified the equation.
Thank you Merlin3189 for your solution too.
I like the idea, very elegant too.
For my approach, I tried to reach the end of $$\sin\theta\tan\theta$$ without using it in any steps (if that makes sense), I don't know if I was being overly strict on myself?
As I say, not sophisticated at math. If I needed to do it as you suggest, following my simplification, I then have the clue to do it:
## \frac{sin+tan}{csc+cot}= \frac {sin.tan}{sin.tan} \frac { (sin+tan)}{ (csc+cot)} ##
## \frac{sin+tan}{csc+cot} = \frac {sin.tan (sin+tan) } { sin.tan.csc + sin.tan.cot } ##
## \frac{sin+tan}{csc+cot} = \frac { sin.tan (sin+tan) } { tan.(sin.csc) + sin.(tan.cot) } ##
## \frac{sin+tan}{csc+cot} = \frac {sin.tan (sin+tan) } { (tan + sin) } ##
## \frac{sin+tan}{csc+cot} = sin.tan ##
Which would be shorter if I didn't try to explain.
PS. Sorry it's taken so long - I've been doing battle with Latex to try to show cancellation (and as you see, losing!)
Relevant Equations:: ## \dfrac{\sin \theta + \tan \theta}{\csc \theta + \cot \theta} = \sin \theta \tan \theta##
My latest attempt:
##\dfrac{\tan\theta \csc \theta - \sin \theta \cot \theta }{1} ##
I see you have completed this, but looking at your Original Post, I see that you nearly had the result there.
After that you have: ##\dfrac{\sin \theta}{\cos \theta}\cdot \dfrac{1}{\sin \theta} - \dfrac{\sin \theta}{1} \cdot \dfrac{\cos \theta}{\sin \theta}##
##\ =\dfrac{1}{\cos \theta}-\dfrac{\cos \theta}{1}##​
##\ =\dfrac{1-\cos^2 \theta}{\cos \theta}##​
etc.
Likes MichaelRocke
Good work!
For the life of me, I can't figure out why anyone every invented or used sec, csc, and cot functions. I thought they were pointless when I first saw them and 40 years later, I still think they are.
Of course it's just a personal preference, but I will always prefer a little simple algebra in place of creating a whole family of redundant functions.
Likes MichaelRocke, ehild and Dr Transport
DaveE said:
Good work!
I met sec and csc here, in PF first in my life, and I always have to check which is 1/sin and 1/cos. We did not learn them here, in Hungary.
Likes MichaelRocke
DaveE said:
Good work!
I hardly ever use ##\csc## or ##\cot##, but I find ##\sec## more useful, because of its relation to ##\tan##:
$$\sec^2 \theta = 1 + \tan^2 \theta; \ \ \ \frac{d }{d\theta}\tan \theta = \sec^2 \theta$$
That said, I'd be happy to use ##\frac 1 {\cos \theta}##, if ##\sec## were abolished with the others.
Here's what I would take from this exercise. There are several different strategies for proving an identity, both for trig identities and more generally:
1) Express everything in common terms. In this case, ##\cos \theta## and ##\sin \theta##. I would say this is a reliable generic method.
2) Try to extract the answer and then simplify what's left to ##1## or ##0##, as appropriate. In this case, that was to take out a factor of ##\sin \theta \tan \theta##.
3) Try to re-express the identity. In this case it was easier to prove the equivalent identity: ##\sin \theta \tan \theta (\csc \theta + \cot \theta) = \tan \theta + \sin \theta##.
I use all these techniques frequently. If things don't obviously simplify one way, it's amazing the way things just fall out in 1-2 lines when you try a different approach.
Likes MichaelRocke
PeroK said:
I'd be happy to use 1cosθ\frac 1 {\cos \theta}, if sec\sec were abolished with the others.
The exact reason I said to convert everything to \sin and \cos initially.
I wonder how much easier the problem would be if it were simply to show that:
$$\frac{a + \frac a b}{\frac 1 a + \frac b a} = \frac{a^2}{b}$$
Brilliant, thank you for your advice here. I have plenty of more exercises to go and starting to tear through them at a much faster pace.
\begin{align}
\frac{\sin \theta + \tan \theta}{\csc \theta + \cot \theta} &\stackrel{?}{=} \sin \theta \tan \theta\\
\frac{\sin \theta + \tan \theta}{\frac{1}{\sin \theta }+ \frac{1}{\tan \theta}} &\stackrel{?}{=} \sin \theta \tan \theta\\
\frac{S + T}{\left(\frac{1}{S }+ \frac{1}{T}\right)} &\stackrel{?}{=} S\ T\\
\frac{S + T}{S\ T} &\stackrel{\checkmark}{=} \left(\frac{1}{S }+ \frac{1}{T}\right)
\end{align}
Likes MichaelRocke
Possibly enlightening...
https://commons.wikimedia.org/wiki/File:Circle-trig6.svg
https://blogs.scientificamerican.co...unctions-your-math-teachers-never-taught-you/
https://www.theonion.com/nation-s-math-teachers-introduce-27-new-trig-functions-1819575558
Likes SammyS and MichaelRocke
The expression has denominators of ##\sin\theta## and ##\cos\theta## so I would multiply top and bottom of the fraction by ##\sin\theta \cos\theta## to clear.
Or more simply <br /> \frac{a + b}{a^{-1} + b^{-1}} = ab.
Likes neilparker62
