Trig Identity Proof: Show that 4(sin^4x + cos^4x) is Equivalent to cos(4x) + 3
The discussion focuses on proving the trigonometric identity 4(sin^4x + cos^4x) ≡ cos(4x) + 3. Participants express confusion about the hint provided in the textbook, particularly regarding the double-angle identity cos(2x) = 1 - 2sin^2x. They discuss various approaches to simplify the left side of the equation using identities, including rewriting sin^4x and cos^4x in terms of sin^2x and cos^2x. Suggestions include utilizing double-angle identities and expanding terms to facilitate the proof. The conversation emphasizes the importance of correctly applying trigonometric identities to solve the problem.
phospho
Show that:
4(\sin^4x+\cos^4x) \equiv \cos4x + 3.
Really stuck with this, no idea how to go ahead with it. The book gives a hint: \sin ^4 x = (\sin ^2 x)^2 and use \cos 2x = 1 - 2\sin ^2 x
But I don't even understand the hint, where did they get
\cos 2x = 1 - 2\sin ^2 x from?
phospho said:
Show that:
This is one of three double-angle identities for cos(2x).
The other two are
cos(2x) = cos2(x) - sin2(x)
cos(2x) = 2cos2(x) - 1
The 2nd one above and the one you're asking about can be obtained from the first one I showed by using the identity sin2(x) + cos2(x) = 1.
cos2x=1−2sin2x from?
cos (x + x) = cos^2x - sin^2x = (1 - sin^2x) -sin^2x = 1 - 2sin^2x, using the identity sin^2x +cos^2x =1
To start you off, write the given equation as, 4((\sin^2x)^2 + (\cos^2x)^2), and use the double angle identities to get this solely in terms of \cos.
You can start by using this:
a2+b2=(a+b)2-2ab
This would mean that:
4(\sin^4x+\cos^4x)=4((sin^2x+cos^2x)^2-2sin^2xcos^2x)
Now rest should be easy to solve.
working :
4((sin^2x)^2 + (cos^4x)
4((1-cos^2x)^2 + cos^4x))
4(1-2cos^2x + cos^4x + cos^4x)
4(1-2cos^2x + 2cos^4x)
Pretty much stuck here.
a2+b2=(a+b)2-2ab
continuing from your working: 4(1 - 2sin^2xcos^2x), but I don't really know any identities to go from here...
How about doing the angle sum on the RHS: Cos4x= Cos(2x+2x) , and expand?
He doesn't have cos(4x), he has cos^{4}(x), or (cos(x))^{4}
phospho said:
working :
4((sin^2x)^2 + (cos^2x)^2)
Use the following double-angle identities:
sin2(x)=0.5(1-cos(2x))
cos2(x)=0.5(1+cos(2x))
ehild
Bacle2 explicitly was referring to the right side of the original identity, which has a cos(4x) term in it.
See below.
Look at the RH side of the original post, it has a Cos(4x)+3.
Edit: Sorry, I did not see Mark44's post, and now I cannot see the 'delete' option.
Try using these identities:
i)sin(2x)=2sin(x)cos(x)
ii)cos(2x)=1-2sin2x
If you square both the sides of i identity, you may see a way through.
Use what ehild suggested if attempting the way I started (which is just one way to tackle the problem - there are many others).
We have, as suggested in my last post,
Now, use the double angle identities that ehild suggested, specifically \sin^2x = -\frac{1}{2}(\cos2x - 1) and \cos^2x = \frac{1}{2}(cos2x +1)
Substitute these into the eqn, expand the brackets and simplify...
