Trigonmetry Functions (radian circles)
  • Thread starter Thread starter phat2107
    Circles Functions
7 replies · 3K views · last reply
phat2107
If sin (x) = -6/7
what is cos(x) = ?
what is tan(x) = ?
the answers have to be in integer form, as in no decimals.
the "x" is supposed to be in quadrant 3
2. The attempt at a solution
This is in radians
so i did sin^-1 (-6/7) = -1.02969
the answer I am assuming is (x)
than cos (x) --> 0.5150 and since its in quadrant 3 this will -.5150
than tan(x) --> -1.664
im not sure if i am right soo far, but assuming i am. i tried using pythagoras to figure our what -0.5150 will be in decimal --> -(sqrt(13))/7
and tan --> and I am lost can't figure this out
any guide or assistance would be great thanks
sin(x)=opp/hyp.
so if sin(x)=-6/7, what is opp and hyp?
When you get that, draw the angle x in the 3rd quadrant and construct the right angled triangle.
Draw a right triangle inside a circle of radius 7. The sine function is positive in quadrants I and II and is negative in quadrants III and IV. Since you are given that sin(x) = -6/7, which quadrants can the angle x be in? For each of these, how long does the side adjacent have to be?
Your answers won't be in integers: they will be either rational numbers (the quotient of two integers) or the quotient of a radical and an integer.
You could also use the fact that [itex]sin^2(x)+ cos^2(x)= 1[/itex] to find cos(x) (remembering that the angle is in the third quadrant so cos(x) is negative.)
Then use the fact that tan(x)= sin(x)/cos(x).
In essence, both rock.freak667 and I are telling you, "yes, use the Pythagorean theorem".
The teacher asked for fractions, so my mistake as putting it as an integer sorry..
I get how to get what tan(x) is but i don't understand how to find the fraction or what the fraction looks like
the cos one worked, ( i can check online if i got the right answer and i did) but tan is confusing me,
tan(x)=sin(x)/cos(x)
or if you drew the triangle properly, you could find tan(x) by it's definition.
Use the fact that:
[tex]cos(x)=\sqrt{1-sin^2x}[/tex]
If you know the value of sin(x) you can very easy find the value for cos(x) using the formula above ^^.
Then, when you know the values for sin(x) and cos(x), just substitute here tan(x)=sin(x)/cos(x) and find tan(x).
Regards.
Rock.freak667's point is that, since sine= opp/hyp, you can represent sin(x)= -6/7 as a right triangle with "opp"= -6 (on a graph, down 6 on the y-axis) and hypotenuse 7. You can use the Pythagorean theorem to determine that "adj" (measured on the x-axis) is [itex]-\sqrt{7^2- 6^2}[/itex] (negative square root because you are told that the angle is in the third quadrant and both x and y are negative there). Now that you know the lengths of all three sides of the right triangle, it is easy to find any of the trig functions. In particular, cos(x)= adj/hyp and tan(x)= opp/adj.
