MHB Is this Trigonometric Expression a Constant Function of x?
anemone
MHB
POTW Director
Prove $\sin^2(x+a)+\sin^2(x+b)-2\cos (a-b)\sin (x+a)\sin (x+b)$ is a constant function of $x$.
It is not at all a hard challenge(Emo), but I am amazed at the beauty of this problem therefore the sharing of it with MHB's members.
Mathematics news on Phys.org
With $\alpha = x +a$ and $\beta = x + b$ the given expression reads:
\[\sin^2\alpha + \sin^2\beta - 2\cos (\alpha -\beta )\sin \alpha \sin \beta \\\\ =\sin^2\alpha + \sin^2\beta - 2 \left (\cos \alpha \cos \beta + \sin \alpha \sin \beta \right )\sin \alpha \sin \beta \\\\ =\sin^2\alpha + \sin^2\beta - 2 \sin^2 \alpha \sin^2 \beta - 2\cos \alpha \cos\beta \sin \alpha \sin \beta \\\\ =\sin^2\alpha - \sin^2 \alpha \sin^2 \beta+ \sin^2\beta - \sin^2 \alpha \sin^2 \beta - 2\cos \alpha \cos\beta \sin \alpha \sin \beta\\\\=\sin^2 \alpha(1-\sin^2 \beta) + \sin^2 \beta (1-\sin^2 \alpha )- 2\cos \alpha \cos\beta \sin \alpha \sin \beta \\\\ =\sin^2\alpha \cos^2\beta + \sin^2 \beta \cos^2 \alpha - 2\cos \alpha \cos\beta \sin \alpha \sin \beta \\\\ = \sin^2\alpha \cos^2\beta - \sin \alpha \cos \beta \sin \beta \cos \alpha+ \sin^2 \beta \cos^2 \alpha - \sin \beta \cos \alpha \sin \alpha \cos \beta \\\\ = \sin \alpha \cos \beta(\sin \alpha \cos \beta- \sin \beta\cos \alpha)+\sin \beta \cos \alpha(\sin \beta \cos \alpha-\sin \alpha \cos \beta)\\\\ =\sin \alpha \cos \beta(\sin \alpha \cos \beta- \sin \beta\cos \alpha)+\sin \beta \cos \alpha(\sin \beta \cos \alpha-\sin \alpha \cos \beta)\\\\ =\sin \alpha \cos \beta \sin(\alpha -\beta )- \sin(\alpha -\beta )\sin \beta \cos \alpha \\\\ =\sin (\alpha -\beta )(\sin \alpha \cos \beta - \sin \beta \cos \alpha )\\\\ = \sin^2(\alpha -\beta )\\\\ = \sin^2(a-b)\]
  • which is independent of $x$.
[TIKZ]\draw[thin] (0,0) circle (5cm);
\coordinate[label=left:A] (A) at (-5,0);
\coordinate[label=right:E] (E) at (5,0);
\coordinate[label=below:O] (O) at (0,0);
\draw (A) -- (O)-- (E);
\coordinate[label=left: D] (D) at (-4.33,2.5);
\coordinate[label=left: C] (C) at (-2.5,4.33);
\draw (A) -- (D)-- (E);
\draw (A) -- (C)-- (E);
\draw (D)-- (C);
\coordinate[label=right: B] (B) at (4.1,2.87);
\draw (A)-- (B);
\node (1) [font=\small,blue] at (-3.6,0.26) {$x$};
\node (2) [font=\small,orange] at (-4.3,0.65) {$\beta$};
\node (3) [font=\small,purple] at (-4.2,1.5) {$\alpha - \beta$};
\node (4) [font=\small,purple] at (3.0,1.1) {$\alpha - \beta$};
\node (5) [font=\small,teal] at (-3.8,1.0) {$\alpha$};
\begin{scope}
\path[clip] (E) -- (A) -- (B) -- cycle;
\draw[thick,blue] (A) circle (0.98);
\end{scope}
\begin{scope}
\path[clip] (B) -- (A) -- (C) -- cycle;
\draw[thick,orange] (A) circle (0.8);
\end{scope}
\begin{scope}
\path[clip] (B) -- (A) -- (D) -- cycle;
\draw[thick,teal] (A) circle (1.2);
\end{scope}
\begin{scope}
\path[clip] (C) -- (A) -- (D) -- cycle;
\draw[thick,purple,double] (A) circle (1.38);
\end{scope}
\begin{scope}
\path[clip] (C) -- (E) -- (D) -- cycle;
\draw[thick,purple,double] (E) circle (1.18);
\end{scope}
[/TIKZ]
Draw a circle with diameter 1 unit and let $O$ be the center of the circle and $AE$ be the diameter of the circle.
Using Sine Rule on the right-angled triangles $EAD$ and $EAC$, we get the following:
$ED=\sin (x+\alpha)\\CE=\sin (x+\beta)$
Now, consider triangle $CED$. Applying the Cosine Rule, we get
$CD^2=ED^2+CE^2-2(ED CE)\cos (\alpha - \beta)=\sin^2 (x+\alpha)+\sin^2 (x+\beta)-2\sin (x+\alpha) \sin (x+\beta)\cos(\alpha-\beta)$
This completes the proof.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
