Troubleshooting Idle Flutter Noise in a Mini Cooper | Engine Noise Fix
  • Context: Automotive
  • Thread starter Thread starter DrChef
    noise
The discussion revolves around troubleshooting an idle flutter noise in a Mini Cooper, particularly when the air conditioning is on. Participants explore potential causes of the noise, which is described as a strong, high-frequency fluttering sound emanating from the tailpipe, and consider various mechanical and combustion-related factors.
  • One participant suggests the noise could be related to a slipping belt, but others challenge this by questioning its connection to the engine's firing order and the nature of the noise.
  • Another participant proposes that the noise might be due to something loose vibrating at its natural frequency, recommending further investigation beyond just the tailpipe.
  • Several participants note that the firing frequency at 900 rpm is approximately 22 Hz, which could be considered normal, especially with the added load from the air conditioning.
  • There is a discussion about the nature of the pulsations at the tailpipe, with some expressing interest in understanding why certain engines produce higher pulsations than others.
  • One participant mentions that the sudden discharge of exhaust gases from the cylinders may contribute to the observed flutter noise, questioning the specific mechanism behind it.
  • A participant describes the high-frequency content of the noise as unpleasant, contrasting it with the more desirable low-frequency sounds typically heard in sporty cars.
Participants express a mix of agreement and disagreement. While some acknowledge that the pulsation frequency is expected, others remain uncertain about the specific causes of the high-frequency flutter noise, indicating that the discussion is still unresolved.
There are limitations in the discussion regarding assumptions about the noise's origin, the definitions of terms like "high frequency," and the lack of direct auditory evidence to support claims.
DrChef
Hello guys,
I am currently having an annoying issue with my Mini Cooper (1.5-liter 3-cylinder TwinPower Turbo).
When I leave it idling, above all when the air conditioning on, I can spot a strong fluttering noise clearly audible from the tailpipe.
It could be described as an impulsive noise, mainly high frequency content, counting about 20 pulses per second (my car revs at about 900rpm at idle).
I strongly doubt it is generated by the exhaust itself, even if I can hear it from the tailpipe. I think the exhaust is acting just an amplifier, getting this noise directly from the engine where it could be originated...
Did any of you experience this issue? Any idea/thought on what the root cause could be and how can I fix it?
Could it be calibration related (e.g. valve timing or other engine settings)?
Thank you
Cheers
How about a slipping belt?
Mmm, that wouldn't occur at the main engine firing order, and anyway I couldn't explain why a slipping belt would generate a pulsation at the tailpipe.
I think it's more something to do with the combustion process or downstream the exhaust valves...
Sounds like something is loose and is vibrating at it's natural frequency. You will need to do more than listen to the tail pipe and hypothesize. Listen in other places. Use a wooden dowel with one end against your ear and the other pressed up against various places.
22Hz is firing frequency at 900rpm. AC increases engine load. So this could very well be normal. Really impossible to tell without actually hearing it.
Exactly, I think it's normal having pulsations at the tailpipe in every car because it's how a IC engine works, you will always have gas pulses at the firing frequency. The question is why some engines produce higher pulsations than others... what are the main things that can mostly contribute to this phenomenon?
I am interested to understand this from the physical point of view (of course).
By my calculation, at 900 rpm each cylinder fires at a rate of 450 pulses per minute x 3 cylinders = 1350 pulses per minute / 60 = 22.50 pulses per second.
Did someone put a stone up there?
Yes that's correct. That's why I said that this pulsation frequency would be expected. The problem is understanding why it results into a high frequency flutter noise.
It may be that it is the sudden discharge of the cylinder exhaust gas. I can't say specifically what the mechanism is; but, what you are experiencing doesn't seem to be much different that the flutter that is is heard in the extreme case from a single cylinder engine at low rpm's. By "high frequency" are referring to the pitch or sharpness of the sound you are hearing vs its pulse frequency?
Thank you for your reply. High frequency I mean a broadband noise mainly above 500Hz. Usually in sporty cars you can hear this idle impulsiveness at low frequency, and that's normal and pleasant. The problem is that the high frequency content makes is sound like a tractor and it's not so nice to experience...
