Trying to calcualte the uncertainty
  • Thread starter Thread starter lavster
    Uncertainty
The discussion focuses on calculating the uncertainty of the mean from two repeated measurements, A and B. The participants confirm that the formula for δ(A-B) is correct and that δA can be expressed in terms of δ(A-B). They clarify that the uncertainty of the mean, δ((A+B)/2), is indeed δ(A-B)/2, and the presence of √2 in the denominator is correct. However, they advise against substituting δB for δA, even if they are equal, to avoid confusion. The conversation also briefly touches on differentiation but clarifies that it is not directly relevant to the uncertainty calculations.
lavster
if i have two repeat measuremetns, A and B, is the following correct? I am trying to calculate the uncertainty... I know there are easier ways to do this but i need to have the uncertainty of the mean in terms of δ(A-B).
from pairs of measurements A and B at each setting we have:
δ(A-B)=〖(〖δA〗^2+〖δB〗^2)〗^(1/2)
=√2 δA
(since δA=δB).
Rearrangement of this equation gives the uncertainty of a single measurement:
δA=(δ(A-B))/√2
Now considering the mean of each pair of measurements:
δ((A+B)/2)=δA/√2=(δ(A-B))/2
In particular, is is correct to have the √2 in the denominator in the last line?
Thanks
It is correct, but I would not replace δB with δA even if they are equal, that is just confusing.
You can get the same result without the detour of δ(A-B), as δ(A+B)=δ(A-B) and δ(X/2)= (δX)/2 for all X.
Thanks :) is this just differentiation? So delta F(A) = da times dF/da ?
Where do you see differentiation?
No.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
