Finding Gareth's force in a tug of war with a 1.25kg rope
  • Thread starter Thread starter Mrchilko
    Force
20 replies · 3K views
Mrchilko
Don't know where to start cause this is part of Newtons laws apparently but seems to be more varied around his second law... Just can't figure out what equation to use.. Question : Rhys and Gareth are having a tug of war with 1.25kg of climbing rope. If Rhys pulls with a force of 24N and the rope accelerates away from him at 1.4m/s2, with what force is Gareth pulling the rope ?
ΣNet = m*a
Fnet= FA + FF
I'm only assuming that you have to take the mass of Rhys and use that plus the weight of the rope to your advantage..
ΣNet = m*a
Fnet= FA + FF
Hmm ... It's too bad that you don't have the mass of Rhys (or Gareth) to plug into your equation. :frown:
However, if you read the problem statement carefully, you will find that neither Rhys nor Gareth are doing any movement.
When Rhys pulls with 24 N, what accelerates away from him? Is Rhys accelerating away from himself? Is that possible?
I figured it out.. Don't know if its the right way.. But I did: 24N / 1.4m/s2 to find mass... Because m= Fnet/a... And seeing that this seems to be the only force mentioned.. And since it never mentioned them moving. That equaled to 17kg... 17kg+ 1.25kg( weight of rope) seeing that he is pulling the rope and Rhys. Then I got 18kg... 18kg * 1.4m/s2 = 26N... That was the answer in the book too... Haha now I'm dealing with a much harder question
You were already given the mass of the rope (1.25 kg). You were asked to find out the force with which Gareth is pulling on the rope.
What, it was too complicated to write a net force equation involving Rhys and Gareth?
A stopped clock is right twice a day, too. That doesn't mean it's right all the time.
Then you should start a new thread for this question rather than hijacking your own thread for the first problem.
Ahhh... Too many questions and a important test tmr... I don't have time to post now... I have to figure it out on my own
Your relevant equations are correct. You are given the mass and acceleration so you can work out fnet. You are given one of two forces so can work out the other.
Have you drawn a free body diagram of the rope, or do you feel like you've advanced in physics beyond the need to draw free body diagrams?
I just Started physics 3 months ago... II am only assuming it takes very much practice to move on from free body digrams
Excellent. So, based on your free body diagram, please write out your Newton's 2nd law force balance for the rope.
Chet
I'm just confused with the weight of the rope... Cause isn't it possible that there is gravity beeing exerted onto it... And wouldn't that have an impact on the result
Haven't you ever been in a tug of war contest?
The weight of the rope is irrelevant to the force of the pull being applied by the people on each end of the rope.
No. Neglect the weight. That's in the vertical direction, and we're doing a force balance in the horizontal direction. So...
Ye so I will figure out when I can. I'm guessing it's just going to be Netforce - Rhys = gareth in some form or not
I have no idea what Rhys and gareth are.
Chet
Ye woops lol that wasn't really meaning that I meant more Fnet = F( of Gareth) - 24N
Excellent. And, in terms of the mass of the rope m and the acceleration of the rope a, the net force is equal to ?
Well Fnet = m*a
a= Fnet/ m
M= Fnet/a
So Fnet = 0.400* 1.4 = 0.56
Mrchilko said:
Well Fnet = m*a
a= Fnet/ m
M= Fnet/a
Wrong problem, Mrchilko.
The problem statement tells you that the mass of the rope is 1.25 kg and its acceleration is 1.4 m/s2. So what does this give you for the net force?
Chet
Fnet = 1.25 x 1.4 = 1.75 net force hahahah I get it... Is it not 24N + 1.75N = 25.75= only 2 SIG figs so 2.6 x 101N = the force Gareth exerts on the rope
