Twin paradox explained for laymen
  • Level: High School
  • Thread starter Thread starter Tony Wright
    Paradox Twin paradox
254 replies · 27K views · last reply
pervect said:
I'm not following. If he's mistaken, he gets the wrong answer. I'm not too inclined to go into this further, unless I can understand your motivation for sayin he's making mistakes.
During any inertial-flight part of the traveler's trip, he is correct that the stationary twin is aging slower. With a high-acceleration quick turnaround, the inertial flight may be the vast majority of the trip. In that case, the traveling twin knows, correctly, that the stationary twin is aging slower during the vast majority of the trip. Yet, at the end, the stationary twin ends up older. So what would you say to the traveler as to why his turnaround caused the stationary twin to age so much more during the brief turnaround time to end up older?
PS. I am ok with this conversation ending here. I don't see any reason to continue it.
Emphasis mine.
Neither piece of knowledge is correct. Both are coordinate-dependent statements that are not correct in any larger sense.
jbriggs444 said:
Emphasis mine.
These phases of the flight are the basic SR situation of one observer traveling inertially versus a stationary observer. Each observer sees that time is passing slower for the other. Its validity is not open to question. It is fundamental SR.
Coordinate-dependent statements can be correct or incorrect. They refer to the reference frame.
In their respective restframe, both twins can calculate the other twin's watch's (frame-dependent) tick-rate. They can integrate that tick-rate over the complete travel-time to calculate the frame-independent age-difference. Both calculations must give a consistent result.
This is not correct and is at the root of your problem. Time dilation is relative. In various other inertial frames the time dilation may be more or less for either twin. Time dilation is not differential ageing.
In their respective restframe, both twins can calculate the other twin's watch's (frame-dependent) tick-rate. ...
Note that these frame-dependent calculations depend on frame conventions, while coordinate-independent statements do not.
It is my understanding that all physical processes appear slower in an IRF that is moving wrt a stationary observer. Any physical process which can be thought of as a clock goes slower. That includes normal clocks, molecular processes, and the aging process.
There is your problem. There is no "moving" and "stationary" observer. "Stationary" is not a concept in relativity.
The physical processes are unaffected because inertial motion is relative. Neither twin is physically affected in any way by their relative motion.
Right. Call them observer A and B if you prefer. All that is necessary is that they are at a fixed position in different inertial reference frames that are moving wrt each other. (This is not a problem with my statements. I used the terms "moving" and "stationary" to represent a typical situation.)
No. That is not all that is necessary. The term "observer" carries more baggage than that.
I should have said that any physical process in one IRF appears slower to an observer in a different IRF that is moving relative to the process IRF.
Then what would you say is happening during the inertial flight stages of the trip? What does each one think about the aging process of the other. If there is some difference between them, why?
But that has no physical significance, so needs no physical cause. Proper time along a worldline is an invariant quantity. All observers agree on that. Time dilation is not invariant.
Assume, the traveling twin just came back from Alpha Centauri and both twins are now sitting in a room on Earth with a constant distance of 1.5 meters from each other in their common restframe. Then their age difference is still frame-dependent.
Does the age difference in their common rest frame have no physical significance?
The inertial phases are physically indistinguishable. But, like the triangle analogy, if you join two lines at an angle they are longer than the direct line.
This is why utlimately it's about spacetime geometry; not about time dilation as a physical process with a cause.
No, he isn't. All he can say is that in the inertial frame in which he is currently at rest, the stationary twin is aging slower. But this is a frame-dependent statement. Frame-dependent statements are not about actual real things; they're about calculated abstractions.
This is false. Each observer calculates that, in his current inertial rest frame, time is passing slower for the other. But that is not what each observer actually sees. What each observer actually sees is what I have been describing all along about Doppler shifts. In other words:
The traveling twin sees the stay-at-home twin's clock running slower than his until he turns around; then he sees the stay-at-home twin's clock running faster than his. The speed-up in the second part outweighs the slow-down in the first part, so when the twins meet up again the traveling twin has seen the stay-at-home twin's clock have more total elapsed time than his.
The stay-at-home twin sees the traveling twin's clock running slower than his for most of the time they are apart; then, not long before the twins meet again, the stay-at-home twin sees the traveling twin's clock speed up so it is running faster than his. But the slow-down in the first part outweighs the speed-up in the second part, so when the twins meet up again the stay-at-home twin has seen the traveling twin's clock have less total elapsed time than his.
The Doppler Shift Explanation page in the Usenet FAQ article that I linked to earlier describes this in somewhat more detail.
The crucial point here is that you have to distinguish the frame-dependent concept of "time dilation", which by itself cannot be used to make accurate predictions about differential aging, from the invariant concept of "directly seen Doppler shift/clock rate", which can be used to make accurate predictions about differential aging. But the latter is not the same as the former; the directly seen Doppler shift/clock rate factor is not the same as the calculated "time dilation" factor.
This is actually one of the limitations of the most common way of teaching SR, that it focuses on inertial frames and calculated frame-dependent quantities, and invites confusion of frame-dependent quantities with invariants.
No. What appears is what I described as seen above. There is no direct observable that corresponds to the frame-dependent calculated time dilation. (There can't be, because frame-dependent quantities can never be direct observables.)
No, it isn't. The fact that they are at rest relative to each other is not frame-dependent; it is invariant. What you are calling the "age difference" can therefore be confirmed using round-trip light signals whose round-trip travel time, according to either twin's clock, will be unchanging and invariant. So the "age difference" can be expressed entirely in terms of invariants.
It is true that you could construct a frame-dependent "age difference" in some other frame by assigning coordinate times to various events on the two twins' worldlines; but these coordinate times would not correspond to any direct observables, since they would not match up with the actual readings on the twins' clocks or the information the twins could exchange using round-trip light signals between them.
I can answer that one tomorrow if no one else does in the meantime.
I have not read every post by FactChecker, but I agree with this one.
Given two inertial observers, each must consider the other's clock to be running slower (or the same). Each must consider the other guy ages slower (or the same). That's basic SR.
Why can't people just agree on this?
The traditional Twins Paradox as described, an astronaut moving at relativistic speed wrt an inertial observer instantly changing velocity to one of relativistic speed in the opposite direction, is physically impossible. One should not be surprised to get impossible answers when applying the correct laws of physics to an impossible behavior.
What "impossible answers"?
The impossible answer is that each twin considers the other to be younger.
No, it isn't. All that "basic SR" says is that frame-dependent "time dilation" is symmetric; but frame-dependent "time dilation" is not a direct observable. "Ages slower" implies that there is a direct observable corresponding to "time dilation". There isn't.
Because it's wrong.
The traditional twin paradox does not require an instantaneous turnaround. That is an idealization. It is easy to set up a realistic scenario in which the elapsed time for the astronaut during turnaround is negligibly short compared to the elapsed times of the outbound and inbound inertial legs of his trip. The latter is really all that is required to simplify the calculations that show that the traveling twin has aged less when the twins meet again (i.e., to avoid having to make a more complicated computation of the actual elapsed time for the traveling twin during the turnaround).
PeterDonis said:
Even the idealization in which the turnaround is instantaneous does not give that answer. See, for example, the discussion in this thread:
https://www.physicsforums.com/threads/potential-energy-formula-in-special-relativty.991687/
Potential Energy formula? What's the purpose for introducing the potential energy formula into this thread? Are you saying the traditional method for solving the twins paradox in textbooks is wrong? Do you recognize that the traditional method gives an incompatible answer to the answer in your reference?
  • Skeptical
And Observer B's clock is always slower?
You're trying to keep a very un-relativistic view. This will not work.
What do you think the "traditional method" is? Can you give a reference? I suspect you are misunderstanding what the "traditional method" actually is.
Because one way of addressing the twin paradox is to adopt a non-inertial frame for the traveling twin, and in such a frame there will be a nonzero "pseudo-gravitational" potential energy difference during the turnaround.
I suggest that you read the Usenet Physics FAQ article on the twin paradox that was linked to earlier in this thread. You seem to be uninformed about the various possible ways of approaching it.
Because it's wrong.
Dropping the relevance of acceleration by making it negligibly short doesn't work. As the turnaround time gets smaller the magnitude of the acceleration gets bigger. You know that. The contribution of relative aging to the problem stays the same. Consider fuel consumption for the space trip. Coast at constant velocity wrt Earth to Alpha Centuri. No fuel consumed there. Neglect the trunaround because it is so small. Coast at constant velocity back to Earth. Fuel consumption = 0. Someone should tell NASA.
  • Skeptical
  • Sad
Nobody is claiming that acceleration is not "relevant" simply because we idealize the turnaround to be instantaneous. In fact, the entire point of the other thread I linked to is that (as both my posts in the thread and the papers referenced show), even if we idealize the turnaround time as negligibly short for the traveling twin, we cannot ignore the time elapsed during the turnaround for the stay-at-home twin.
Nobody is claiming that the turnaround does not exist or can be neglected in all respects simply because we idealize it as being instantaneous. You are responding to a straw man.
I am beginning to think you are trolling.
