Twin paradox: what do clocks show when the moving twin accelerates?
  • Level: Graduate
  • Thread starter Thread starter granpa
    Paradox Twin paradox
43 replies · 8K views
granpa
suppose we start with a long line of stationary, evenly spaced and perfectly synchronized clocks along the x axis. if the stationary twin is at the origin and at t=0 the other twin passes the origin moving at relativistic speed with gamma=2 then from the point of view of the stationary twin the moving twin is length contracted to 1/2 his normal length. but despite this moving twin, due to loss of simultaneity, will see the line of clocks as no longer synchronized and therefore as being contracted to 1/2 its normal length. that's obvious. presumably, due to loss of simultaneity, each individual clock will seem to be running at 1/2 its normal speed even though the time read off as each individual clock passes would be running at twice normal speed. i think that's right.
but what happens when the moving twin suddenly stops? now all the clocks are synchronized and there is no length or time contraction. in particular, from the point of view of the moving twin, what time does the non-moving twins clock show just before and just after the moving twin suddenly stops?
what happens then when the moving twin begins moving back toward the origin? what does he see?
Look at this example - (My value for gamma differs from yours a little bit):
Let us assume three clocks A, B, and C. A and B are at rest in S and C is at rest in S', while the relative velocity between S and S' is 0.5c.
In S:
A and B are synchronous and the distance between them is 1 light-second.
At t=0 clock C starts from A and arrives at t=2 at B. In S, clock C is time-dilated and therefore shows the t'=1,73..s. The same is happening when C travels back from B to A. So t=4s and t'=3,46..s..
In S':
We are no changing the frame and are looking into S'. In that frame, A and B are not synchronous, becaus of relativity of simultaneity B starts 0,577..s before A. Due to Length-contraction the distance between A and B is 0,866..Light seconds.
When A starts at t=0, B is showing t= 0,5s (Not 0,577..s because B is time dilated).
Now we can answer your question:
When B is just before C, C shows t'=1.73..s. Both A and B are time-dilated, so A shows t=1.5s and B shows t=2s.
When B stops at C, A jumps forward in time to be synchronous with B, so A and B show t=2s.
When B is just after C, A jumps forward in time again and shows t= 2.5..s.
When A stops at C, C shows t'=3,46..s. Both A and B are time-dilated, so A shows t=4s and B shows t=4.5s. So when A and C are coming togeter, in both frames A shows 4s and C shows 3.46..s - so A is older. :smile:
thank you. I figured it was something like that.
now I presume that this shift in A's time from B's point of view as B accelerates has something to do with general relativity. (of course, the time on A's clock doesn't really change when B accelerates. it just appears to B to do so). I suggest another thought experiment.
suppose the length between A and B is some absurdly large distance (jillions of light years) and C, having already stopped at B, instead of changing speed instantly, accelerates at 1 g for some length of time (about a year) till it reaches relativistic speed. the time spent accelerating is such a small part of the total transit time that it can be ignored. during this acceleration the time on A's clock continually shifts (from B's point of view). how is this equivalent to gravity?
I'm just trying to understand general relativity here. I don't need a detailed mathematical explanation.
granpa said:
... presumably, due to loss of simultaneity, each individual clock will seem to be running at 1/2 its normal speed even though the time read off as each individual clock passes would be running at twice normal speed. i think that's right.
That would be better stated as {each individual clock will seem to be running at 1/2 its normal speed even though the time read off as each individual clock passes would show an elapsed time that is twice that shown on his own clock.}
When he is moving the line of clocks is no longer synchronised and he sees each clock as having a positive offset right from the outset and the further away each clock is the greater the offset proportional to Do*v/c^2 where Do is the proper distance measured in the rest frame of the line of clocks. Thereafter he see the line clocks advancing at 1/2 the rate of his own clock but the elapsed time on each clock that he passes is twice that shown on his own clock because as far as he is concerned they had a head start.
granpa said:
..but what happens when the moving twin suddenly stops? now all the clocks are synchronized and there is no length or time contraction. in particular, from the point of view of the moving twin, what time does the non-moving twins clock show just before and just after the moving twin suddenly stops?
Lets say he is looking through a telescope at the non moving twins clock and it shows 2.00.00 PM just before he stops. 1f he stops within one second then he will see a time of somewhere between 2.00.00 PM and 2.00.01 PM on the non moving twin's clock. In other words, he will notice very little change in elapsed time of the non moving twin's clock. What he will notice, is that just before he stopped the non moving twins clock was advancing at rate of 1/2 a second to every second that passes on his clock and just after he stops the non moving twin's clock has speeded up to the same rate as his own clock. When he has stopped he will notice that the clock that he has stopped next to, shows an elapsed time that is twice that of is own clock. If he allows for light travel times, he will notice that all the clocks in the line of clocks show twice the elapsed time of his own clock.
For the sake of argument let's say the clock that he stopped next to, shows an elapsed time of two hours while his own clock shows a journey time of one hour. If he moved back to the non movig twin so slowly that there was no further time dilation of his own clock, then when he got back his clock would be one hour behind the non moving twins clock when they are standing next to each other once again. However, no matter how slow he moves, there will be some time dilation and the slower he moves the longer that additional time dilation will be over so that in practice his clock will be slightly more than a hour behind the non moving twin's clock.
[EDIT] When I stated that when the moving twin looks at the non moving twins clock through a telescope I should have added that he would have to allow for a classic doppler shift in his calculations.
Time dilation is not necessarily due to acceleration. I read an analogy in the context of "the clock postulate" that went something like this. Imagine a cyclist on a cold but calm day. When he accelerates from rest to a velocity relative to the air he feels a wind chill factor that cools him down more than when he is at rest. It is not the acceleration that causes the wid chill, but the motion relative to the air. The acceleration simply changes his motion relative to the air. When he stops accelerating and sentles down to a cruising speed he continues to be cooled at greater rate by the wind chill factor even though there is no longer any acceleration. For wind chill factor you could substitute time dilation gamma factor.
i know that velocity results in time dilation. that isn't what i was referring to. when B stops then the line of clocks are all synchronous. before that they were out of synch. that is a time shift.
Ok, let's try and create the equivalent situation in a gravitational context. C is sitting on the surface of the Earth experiencing a constant acceleration of 1g. A is high up and his clock rate is faster than that of C because he experiences less gravitational time dilation. To make the situation completely equivalent C observes A to moving away from him at a progressively greater rate in your kinetic example so we will have to do the same in the gravitational example and have A accelerating upwards. A's upward acceleration will cause his clock to kinetically time dilate and classic doppler shift due to motion going away from C will make his clock appear to be slowing even more as far as C is concerned. As you can see the situation, is is not simple for your example and proportional effects of kinetic time dilation have to be weighed against the gravitational time dilation. Without a detailed mathematical numerical analysis it would be difficult to conclude anything.
this is factored out when talking about time dilation (and loss of simultaneity) as is light travel time.
The thing to keep in mind is that gravitational time dilation is due to a difference in potential rather than difference in local g force. Thus a clock runs faster at the top of a mountain than at sea level not because gravity is weaker, but because it is higher in Earth's field. If we were to replace Earth's gravity field with an uniform one (one that didn't fall off with increased distance from the center of the Earth), the Clock on the mountain would still run faster, even though it experiences the same gravitational force as one at sea level. In fact, it the difference in clock rates will actually be greater, for the very reason that Earth's gravity in the first example falls off with distance, which leads to a smaller difference in potential than the uniform field does.
When B accelerates at one g towards A, this is the equivalent of a uniform gravity field of 1 g strength extending from B to A, from B's point of view. Since A is vastly higher than B in this "field" from B's point of view, A is at a vastly greater potential and runs vastly faster than B. The greater the distance from A to B, the faster A runs according to B.
When the moving twin accelerates, he sees a linear spatial gradient in the speed of light, and all things under a pseudo-force equal to the force per unit mass he experiences times the energy of the particle under examination. The linear spatial gradient in the speed of light is equal to the force per unit mass he experiences. Note that I am using a slightly different definition of force, since the velocities in the momentum formulas are normalized by light speed. Since the pseudo-force is proportional to energy, it is like gravity. I have posted a calculation on my hi5 account, under the name johnwilliams22. I hope this helps.
Hello dude222
Quote
------When the moving twin accelerates, he sees a linear spatial Gradient in the speed of light, and all things under a pseudo-force equal to the force per unit mass he experiences times the energy of the particle under examination. The linear spatial gradient in the speed of light is equal to the force per unit mass he experiences. Note that I am using a slightly different definition of force, since the velocities in the Momentum formulas are normalized by light speed. Since the pseudo-force is proportional to energy, it is like gravity. I have posted a calculation on my hi5 account, under the name johnwilliams22. I hope this helps.-------
What is that in layman's terms.
Matheinste.
http://www.sysmatrix.net/~kavs/kjs/addend4.html
The standard version of the twin paradox has an astronaut twin – call her Stella – accelerating away from her Earthbound twin sister, Terra. Stella rockets through the cosmos at relativistic speeds, then later turns around and flies home, eventually landing back on Earth.
But in order to eliminate pesky accelerations, we'll say that the astronaut twin, Stella, was already in motion as she passes over Earthbound twin Terra. At the pass-by, their clocks each start at zero. Then, instead of later turning around, Stella eventually passes another astronaut, Alf, moving equally fast in the opposite direction, who adopts Stella's clock reading and continues back toward Earth. When Alf arrives at Earth, he passes over homebound Terra without slowing, at which time their clock readings are compared. Thus there are no accelerations and the scenario can be examined with the simplest (SR) arithmetic, like what's been shown in diagrams thus far.
Hello again.
I thought that the twins (non)paradox required them to be in the same frame as each other at the start and end of the traveling twins journey.
Matheinste.
Hello again
In your scenario above the traveller never returns.
Matheinste.
Hello again.
I think i'll pass on this discusion and leave it to those who understand these things.
Goodbye .
Matheinste.
granpa said:
Janus:
wikipedia backs you up. you are 100% right.
Although Janus is always 100% right, that does not necessarily follow as a result of being backed up by wikipedia!
Garth
Stella and Alf have different hyper-surfaces of simultaneity, this is where the paradox arises.
Alf cannot simply adopt Stella's clock reading as his own.
Garth
he doesnt. he just notes how much time elapsed for stella.
time elapsed for stella on outward journey + time elapsed for alf on inward journey=total time elapsed for moving twin=acceleration is not necessary to explain the paradox.
scenario:
a long line of one million stationary perfectly synchronized atomic clocks placed one light second apart from the origin along the x axis. at t=0 a rocket passes the origin at gamma=10. at t=0 all clocks, including the one on board the rocket, which are identical, read 0. the rocket uses a strobe to read the clocks as they pass its window. the rocket reaches the last clock at exactly the same moment as another rocket going the opposite direction at gamma=10. at that point the first rocket transmits a message to the second rocket telling them how much time had elapsed since he passed the origin.
an observer at the origin looking through a telescope at the clocks would see them out of synch due to the time it takes for the light to reach him. but after compensating for that he can easily calculate that they are synchronized.
when the rocket passes the origin at t=0, an observer on board the rocket, looking through a telescope at the clocks, would see exactly the same thing but because light seems to him to be moving at c, relative to himself even though he is moving, would calculate that the clocks are out of synch.
we know that he perceives each of the clocks to be ticking at 1/10 its normal rate. if v is his velocity and d is the distance to the clock as measured by a stationary observer then d/v is the time it will take him to reach it which is also the time the clock will read when he does reach it. subtracting from that 1/10th of the time he perceives having passed during the journey one gets the time that he perceives that the clock read when he was at the origin.
Hello again.
One last thought.
If the traveling twin passes the stay at home twin on his outward journey and is the same age he cannot have been born at the same time. If they were born at the same their travel histeory i.e spacetime intervals covered, are differenttime they cannot be the same age. Time dilation between moving frames or something along those lines.
Either way they are not twins in the normal sense of twins.
Matheinste.
matheinste said:
Hello again.
One last thought.
Matheinste.
They could be cousins twice removed. But "The Cousins' Paradox" doesn't quite have the same ring.
Twins are used as a sort of shorthand (perhaps not intentionally) meaning "two of the same". So the twins could just be two copies of the same person, the traveller takes out some sort of special insurance, by jumping in the Duplomatic 2000 and making a back-up copy of herself. Then she gets fired off into space reaching cruising speed after a very short period of time and sails off to some destination, then turns around, reaches the same cruising speed in the opposite direction (again very quickly) and returns to see how the copy is going. The copy is older, and pissed. They get in a row and the older, stay-at-home copy loses it and goes on a rampage, leading to a confusing car chase with people shooting at each other for no readily apparent reason. In the end, you find out that in fact both were copies and the real original had gone off in another spaceship which went much faster than the first and hence the original is still young and beautiful when she gets back and marries the policeman who solves the case by accurately shooting the bad copy (twice, because you thought she was dead, but she wasn't really the first time). Just before the credits begin to roll, you learn that the policeman is actually a grandson of the copy he just "retired" (he was raised by an Angolan sheep herder, so he never knew).
Oh, hang on, that has nothing at all to do with the original twins' scenario.
Feel free to pick holes in my alternative scenario.
cheers,
neopolitan
(Sorry about that granpa, it was just that the small-mindedness got to me for a moment there :smile: )
time elapsed for Stella on outward journey + time elapsed for alf on inward journey=total time elapsed for moving twin=acceleration is not necessary to explain the paradox.
There is no paradox in non-inertial observers experiencing less lapsed time than an inertial one, the paradox would be if two observers, Terra and Stella, each believe that they are in the inertial frame and therefore both conclude that they ought to experience the greater time lapse.
Stella + Alf cannot conceivably consider their combined experience to be inertial, there was a violent acceleration as your clock frame of reference went from Stella to Alf.
Garth
granpa said:
... btw, the total elapsed time is exactly the same.
matheinste said:
... For who(?)
granpa said:
stella + alf
ElapsedTime(Stella+Alf) < ElapsedTime(Terra)
For example let Stella's velocity (Vs) = 0.8c and Alf's velocity (Va) = -0.8c
Stella and Terra set their clocks to zero as they pass each other. Stella continues to a station that is one light year away in Terra's frame which takes 1/0.8=1.25 years according to Terra and 1.25*0.6 = 0.75 years by Stella's clock, Alf who is passing the station as Stella arrrives sets his clock to 0.75 years and when when he passes Earth, Alf's clock reads 1.5 years while Terra's clock reads 2.5years.
Of course this does not conclusively prove any observer is ageing slower than the others and to do that a fourth observer (Fred) would have to transfer from Stella's ship to Alf's ship as they passed the station and that would involve violent acceleration for Fred as Garth has pointed out.
as i said before:
