Two beetles vector problem: why is my magnitude wrong?
  • Thread starter Thread starter gokugreene
    Vector
2 replies · 9K views
gokugreene
Hey guys, I need your help figuring out what I am doing wrong.
Two beetles run across flat sand, starting at the same point. Beetle 1 runs 0.5m due east, then 0.80m at 30 degrees north of due east. Beetle 2 also makes two runs; the first is 1.6m at 40 degrees east of due north. What must be (a) the magnitude and (b) the direction of its second run if it is to end up at the new location of beetle 1?
40 degrees east of due north = 50 degrees
vector A = 0.5m
vector B = 0.8m
vector C = 1.6m
A = .5i + 0j
B = (.8cos(30))i + (.8sin(30))j
C = (1.6cos(50))i + (1.6sin(50))j
R = 2.35i + 1.78j
R = [2.35^2 + 1.78^2]^1/2 = 2.95m
arctan=(1.78/2.35)=37.14 degrees
Answer should be: (a) 0.84m (b) 79 degrees
What am I doing wrong here? Am I approaching it wrong?
You aren't showing the crucial part of your work! What did you do with vectors A, B, and C after you got them?
The first beetle's total motion is A+ B, then second's is C so to arrive at the same place the second beetle must go A+B- C.
I was adding A + B + C. I see how logically that wouldn't make sense. Thanks I got the answer.
