Two blocks on string with 30-60-90 triangle at constant speed
SqueeSpleen
There's two blocks of mass m_{A} and m_{B} which are linked by an ideal string. The block of mass A descends at constant speed. There's no friction. If the pulley is ideal, which one of the following is true[/B]
Multiple-choice answer options listing mass relations between m_A and m_B, with the first option circled as correct, beside a diagram of two blocks on a pulley over a 30-60-90 incline with g pointing down.
Newton laws and trigonometry I think.[/B]
I think that the correct answer is the second one, but the first one is marked as correct so I wanted a second opinion.
My reasoning is the following: If the speed is constant it means there is no acceleration, so the sum of the forces is 0. Then I decomposed gravity in the component that's compensated by the normal force done by the triangle and it's perpendicular component. So I arrived to
m_{A} (1/2) = m_{B} sqrt(3)/2
Now that I check, it isn't item 2. it would fall in item 1 as 1/sqrt(3) is between 0.25 and 0.6
Right?
sorry for the typos, I broke my keyboard yesterday (I won't drink coffee while on computer again) and I'm with a rubber one until a new one arrives, at least it's better thanthe one that windows have to use with the mouse.
[/B]
  • Physics diagram of two blocks on a 30-60-90 triangular incline joined by a string over a pulley; block A on the 30 degree slope, block B on the 60 degree slope, with g pointing down. Beside it, multiple-choice options comparing mA and mB, the first circled.
Working it out very quickly, and thus prone to error, I think the first answer is correct.
Absolutely correct! Way of solving by simply taking their Sine components of 'g' and solve it.
