Two charges hanging on strings
  • Thread starter Thread starter catch22
    Charges Strings
10 replies · 2K views · last reply
catch22
the answer for d comes out to be 0.017 m.
BUT, if we kept with tan instead of switching to sin, we would have
mg(d/2)/ mg =kq q / d2
d^3 = 2k q q
solving for d
d = 0.0121 m
clearly on a big scale, the two answers are about the same distance but the answer from using tan is more accurate, right?
d^3 = 2k q1 q2 = 0.0121 m.
This equation doesn't make sense. On the left you have a length cubed. In the middle you have something with dimensions of Force times length squared. On the right you have just length.
The answer using the tangent function should be very close to the answer using the sine function. You are right, that using the tangent function will give the more accurate answer. But it is harder to solve the equation with the tangent function and using the sine function approximation for this problem still gives a very accurate answer.
whoops, sorry, the length of d is 0.0121 m after solving for it.
Using the tangent, the answer for d will be .017 m to two significant figures. This is the same as using the sine function to two significant figures. In fact, using the tangent will give the same answer as using the sine to 5 significant figures (for this particular problem).
How did you express the tangent of the angle in terms of d and L?
TSny said:
Using the tangent, the answer for d will be .017 m to two significant figures. This is the same as using the sine function to two significant figures. In fact, using the tangent will give the same answer as using the sine to 5 significant figures.
my math was off. sorry, I will look at it over.
wow, the math is much longer
I'm getting :
2.25d3 - (d5/4) = 1.14 x 10-11
If I use the tangent function and make no approximations, I get an equation involving d6 and d2.
How did you express the tanθ in terms of d and L?
tanθ = (d/2) / sqrt (L2 - (d/2)2)
OK. That looks good. Perhaps you then used an approximation for the square root part?
But, if you don't want to make any approximations, then use your expression for tanθ in your equation
tanθ = kq2/(mgd2)
Square both sides to get rid of the square root.
tanθ = kq2/(mgd2)
I try to avoid using approximations because I want the most accurate answer. But as you can see, the math does get a big long.
Yes, it does get messy. Of course, that's why it is suggested to make the approximation of replacing the tangent by the sine.
If you let x = d2, you can reduce the equation to the form x3 = bx +c for certain constants b and c. This has the form of a "depressed" cubic equation and the solution can be looked up.
For example, see equations (2) and (4) here: https://sites.oxy.edu/ron/math/312/14/projects/Fernandez-Gosselin.pdf
Or you can solve the cubic numerically to whatever accuracy you need.
