Two fixed charges and one free to move problem.
  • Thread starter Thread starter Cmon101
    Charges
The discussion centers on determining the position of charge Q3 (3.33 µC) relative to charge Q1 (1.39 µC) such that the net force on Q3 due to fixed charges Q1 and Q2 (-3.22 µC) is zero. The participants derived the equation F = (K(Q1Q3))/X² + (K(Q2Q3)/(.301 + X)²) = 0 to find the equilibrium position. They concluded that Q3 must be positioned to the left of Q1 to achieve force equilibrium, leading to the final equation X = 0.301 / (√(Q2/Q1) - 1), resulting in a negative value for X, indicating the correct placement of Q3.
  • Coulomb's Law for electrostatic forces
  • Basic algebra for solving equations
  • Understanding of charge interactions (positive and negative)
  • Graphing calculator proficiency for visualizing functions
  • Study Coulomb's Law in detail to understand force interactions between charges.
  • Learn about electric field concepts and how they relate to charge positioning.
  • Explore graphical methods for solving equations involving multiple variables.
  • Investigate the implications of charge magnitudes on force equilibrium.
Students studying electrostatics, physics enthusiasts, and anyone involved in solving problems related to electric forces and charge interactions.
Cmon101
Three charges, Q1, Q2, and Q3 are located in a straight line. The position of Q2 is 0.301 m to the right of Q1.
Q1= 1.39x10-6 C and Q2= -3.22 x10-6 C are fixed at their positions, distance 0.301 m apart, and the charge Q3= 3.33 x10-6 C is moved along the straight line. For what position of Q3 relative to Q1 is the net force on Q3 due to Q1 and Q2 zero? Use the plus sign for Q3 to the right of Q1.
F=(K(Q1Q2))/r^2
So I attempted to solve it by using X as the distance from Q1 to Q3 and built this equation:
[k(Q1Q3)]/(X^2)+[k(Q2Q3)]/[(x-.301)^2)=0
Since .301 is the distance from 1 to 2 which is fixed I assumed X-.301 was the correct way to calculate distance from 2 to 3 for that portion of the equation.
When I go through this I get to the point where I'm at [.0417/(x^2)]= [-.0965/(x-.301)^2].
I then plug this into my graphing calculator (one side as one function, the other as another function) and then excute the intercept function to easily find X, but there is no intercept meaning that my equation above for X is wrong.
Any help is appreciated. Thank you in advance.
Hi Cmon101
welcome to PFinstead try to write the forces b/w Q1Q2 and Q1Q3
How do I use the force of Q1 on Q2 after I find it? I thought since one and two are stationary that force did not matter. Sorry I'm kind of slow at understanding this stuff.
I'm sorry i was reading 2 ques. and i mixed them.
Ok... now so you know that q1, q3 is +ve and q2 is negative and also mag. of q1 < mag of q2 ... can you tell me should q3 be between q1 and q2 or not?
OMG good call. I kept thinking it had to either be Q1------Q2----Q3 or Q1---Q3---Q2 and I kept thinking that just doesn't make sense logically cause of the charges but Q3------Q1----Q2 does make sense! Alright altering my equation to take the new positioning into account. Will tell you the result.
Damn. Still didn't work. So if we assume the setup is like this
Q3(3.33 uC)------X----Q1(1.39uC)-----.301m-----Q2(-3.22 uC)
The equation would turn into this correct:
K(Q3Q1)/ X2 + K(Q3Q2) /(.301+X)2 = 0
Or more plainly K(Q3Q1)/ X2 = K(Q3Q2) /(.301+X)2 If you use the absolute values of the charges.
Wait I guess it could look like this Q1(1.39uC)-----.301m-----Q2(-3.22 uC)-----Q3(3.33)
X being the distance from 1 to 3.
Actually does this make sense? I think Q3 on the left is actually the right setup cause in this one wouldn't it be impossible for the forces to equilibrate no matter how close or far away charge 3 was on the right.
well it has to work this way
and the next one won't work as q2 has more mag. than q1 so in order of zero net force, Q3 should be near Q1
maybe answer given to you is not correct
what is your answer?
So K(Q3Q1)/ X2 + K(Q3Q2) /(.301+X)2 is the same as:
K(Q3Q1)/ X2 = K(Q3Q2) /(.301+X)2 (If we use the absolute value for the charges)
And Then we can turn this into
(.301+X)2 / (X)2 = [K(Q3Q2)]/[K(Q3Q1)]
Then the Ks cancel on the right side leaving you with
(.301+X)2 / (X)2 = (Q3Q2)/(Q3Q1)
Then we square root both sides and it turns into
(.301+X)/X = SQROOT[(Q3Q2)/(Q3Q1)]
Does all of this algebra look correct so far?
I think your very first equation will be correct if u remove the minus sign from right hand side.
Then from (.301+X)/X = SQROOT[(Q3Q2)/(Q3Q1)]
We divide the left side of the equation to get:
.301/X+1=SQROOT[(Q3Q2)/(Q3Q1)]
Move the 1:
.301/X=SQROOT[(Q3Q2)/(Q3Q1)]-1
Move the X:
.301=[SQROOT[(Q3Q2)/(Q3Q1)]-1]X
Get X alone:
(.301)/[SQROOT[(Q3Q2)/(Q3Q1)]-1]=X
And that's the end of it does all of that look right about to plug it in
I got .58 meters and still incorrect. I do not have the actual answer.
But if we assume 3 must be on the left of one done we have to change x-.301 to x+.301.
I forgot to put a negative sign in front of distance since it was to the left. -.58 m is correct. Thanks so much for sticking through this with me and helping me out cupid!
Using the initial equation with x-.301 you ll just find 2 values for x, one negative and one positive. You keep only the negative one cause in the positive solution the forces do not cancel out but addup.
Ah got ya
10K
