badphysicist
- 80
Hi all,
I've been looking at the problem of two interacting electrons in a 1D infinite well and wanted to run my conclusions past other people to see if I'm on the right track. The potential is 0 from x=0 to x=1 and infinite outside of this. The 1 particle solutions to this potential are \psi(x)=2^{1/2}sin(m\pi x) where m=1,2,3... For solutions to the two particle interacting Schrödinger equation, we will use linear combinations of spatially asymmetrical and symmetrical combinations of the one particle solutions. Schrödinger's equation is now:
H=-\frac{1}{2}\frac{\partial ^2\psi(x_1,x_2)}{\partial x_1^2}-\frac{1}{2}\frac{\partial ^2\psi(x_1,x_2)}{\partial x_2^2}+\frac{\psi(x_1,x_2)}{|x_1-x_2|}=E\psi(x_1,x_2)
The added fun is the interaction between the electrons. The functions I will be taking linear combinations of are:
\phi_{m,n\pm}(x_1,x_2)=N_{m,n}[sin(m \pi x_1)sin(n \pi x_2) \pm sin(n \pi x_2)sin(m \pi x_2)]
where the + corresponds to a symmetric function and - corresponds to an asymmetric function. The normalizing parameter is:
N_{m,n}=\left( \begin{array}{cc} 1 & m=n\\ \sqrt{2} & m \neq n\end{array}\right).
So our solutions will be:
\psi_{\pm}(x_1,x_2)=\sum_{m,n}c_{m,n \pm} \phi_{m,n\pm}(x_1,x_2).
where the c's are the coefficients to be determined.
Now we plug into our hamiltonian and we will get an eigenvalue equation:
\sum_{o,p}H_{m,n,o,p}c_{o,p \pm}=E_{\pm}c_{m,n \pm}
So now that I've set up the problem, here are my thoughts that I've been looking into. The problem is with solving this is with the Coulomb (aka Hartree) term. It has a singularity whenever x_1=x_2 unless the wave function is 0 when x_1=x_2, but this is only true for the asymmetric functions. Does this mean that I shouldn't consider the symmetric functions? I know that by Pauli's exclusion principle that I need to have a symmetric spatial function paired with an asymmetric spin function and vice versa. There is the possibility that from a linear combination of the symmetric functions we can find a combination that will make the function zero along the x1=x2 line.
I have also considered another way to make a spatially symmetric wave function that will satisfy the potential, but I think there is a problem with calculating the kinetic term. The function is:
\phi_{m,n}(x_1,x_2)=sign(x_1-x_2)[sin(m\pi x_1)sin(n\pi x_2) - sin(n\pi x_1)sin(m\pi x_2)].
Here sign(x_1-x_2) is basically just the sign of the expression so it will have values of 1, -1 and 0.The problem that arises from this function is that the second partial derivative in either variable isn't really defined when x_1=x_2. I think it would be the derivative of a delta function which isn't good.
So my questions are:
Is it okay to eliminate the (original) symmetric functions from my basis set for this problem?
Therefore, is the ground state spatially asymmetric?
Can I use my alternate symmetric functions to form a basis set?
Any other thoughts on this problem?
I've done a lot of work on this in Mathematica and have been able to calculate the energies and wave functions for the spatially asymmetric wave functions just fine.
Thanks for any thoughts and for reading this. Also, please let me know if my explanation isn't making sense.
