Two masses connected via pulley: find acceleration
2 replies · 3K views · last reply
pivoxa15
Two masses A and B, and of mass 1.6kg and 2.4kg respectively are connected by a light string which passes over a frictionless pulley. Calculate the acceleration of the 1.6kg mass.
To get started I must know whether the two masses both have the same acceleration. Is that true? I know the tension of the system is the same.
Assuming it's true I get a simultaneous equation that looks like
16-T=1.6a
24-T=2.4a
which works out for a=10m/s^2 and T=0 which is a bit fishy. But if a is different for each mass than there are 3 variables but only two equations.
The two masses have the same acceleration (they are connected by a string!) The smallest mass will move upwards, so its resultant force will be T-16, hence your first equation should read T-16=1.6a
I see. The system should have a predetermined positive, negative direction. It's not the case that upwards is always + and downwards always - in this pulley problem.
