Two particles having charges separated by a distance
  • Thread starter Thread starter sonrie
    Charges Particles
The discussion focuses on determining the point along the line connecting two charged particles where the net electric field is zero. The calculated position is 0.325 m from the 0.600 nC charge, derived by equating the electric fields due to both charges. The method involves setting the magnitudes equal and solving for the distance, considering both charges are positive. When one charge is negative, the approach remains similar, but the algebra changes due to the differing directions of the electric fields. Participants emphasize careful attention to vector directions in the calculations.
sonrie
Two particles having charges of 0.600 nC and 5.40 nC are separated by a distance of 1.30 m.
A.) At what point along the line connecting the two charges is the net electric field due to the two charges equal to zero?
the electric field is zero at a point _______ m from .600nC
i found out the answer to this to be .325m. by doing the following:
E due to q1 is equal in magnitude to E due to q2 but in opposite direction
As both q1 and q2 are positive, the field is zero at a point in between them
As distance from q1 is L , distance from q2 is (1.3 - L)
kq1/L^2 = kq2/(1.2 - L)^2
(1.3 - L) / L= sq rt (q2 / q1)
(1.3 - L) = L* sq rt (q2 / q1)
1.3 = L [1+sq rt (q2 / q1)]
L = 1.3 / [1+sq rt (q2 / q1)]
L = 1.3 / [1+sq rt (5.40 / 0.600)]
L = 1.3 / [1+sq rt ( 9.00 )]
L = 1.3 / [1+ 3.0]
L = 1.3 / [ 4.0]
L=0.325 meter from 0.550 nC
Where would the net electric field be zero if one of the charges were negative.
Enter answer as a distance from the charge initially equal 0.600 nC . This is where i get lost, i don't know what to do next. please Help!
__________________
You do it like you did the first one. Start with
\vec{E_1} + \vec{E_2} = 0
Be careful about the vector directions.
should the answer be the same but just negative since i using the same values as before?
When I wrote, "You do it like you did the first one," I meant, you start it the same way. The algebra is different.
I apologize; I should have been clearer.
Thanks A Bunch!
You're welcome.
