Finding the Constants in a Motion Equation
  • Thread starter fghtffyrdmns
  • Tags
    Constants
In summary: Kt?In summary, to find s(t), you need to integrate a(t) twice and solve for the undetermined constants using the given initial conditions. If you have not learned integration yet, you can use the fact that the derivatives of a cubic function follow the power rule to find the anti-derivatives of a(t) and v(t), and then solve for the constants using the initial conditions. In this case, the anti-derivative of a(t) is v(t) and the anti-derivative of v(t) is s(t). Remember to include the constant in your
fghtffyrdmns
145
If s(0) = 0, v(1) = 24 and a(t) = 24t+6 find s(t)
I know a(t) is s''(t) and v(t) is s'(t). however, How can I find s(t)?
Integrate a(t) twice. You get two undetermined constants. Find them by using the s(0) and v(1) conditions.
We have not learned integration yet :(. Infact, we have not even done anything from finding a function from it's derivatives.
Is there any other way to do it?
Have you been given any equation relating s,v, and a?
Nothing at all.
Find the anti-derivative of a(t), which is v(t).
Plug in t=1 for v(t) to get the constant.
The find the anti-derivative of v(t), which is s(t).
Plug in t=0 for s(t) to get the constant, and now you have your answer.
What is this anti-derivative? What's integration? :/
Well either you haven't been paying attention in class or there is something seriously wrong with how they are teaching you.
Since you haven't learned integration, the only possible way I can see you finding s(t) by derivatives only is knowing that since a(t) = 24t + 6, all of the integrals of a(t) must obey the power rule. Knowing this you know that
v(t) = f(t^2) and s = g(t^3)
So g(t^3) is a cubic. and can be written in the form:
q*t^3 + b*t^2 + c*t + d
can you solve from there?
Could you not do the inverse of the power rule?
The inverse of the power rule is integration. Since you know that
s = q*t^3 + b*t^2 + c*t + d
all you need to do is solve for q, b,c and d using derivatives.
then s = 3qt^2 + 2bt + c?
no, s = q*t^3 + b*t^2 + c*t + d
I'm so lost right now.
My teacher shall get angry letters >:[
Recap: You know that s(t) is a cubic because when you take two derivatives of a cubic you get At + B which is the same form as a(t) = 24t + 6.
So using the initial conditions eg. s(0) = 0, the a(t) formula, s(t) = q*t^3 + b*t^2 + c*t + d, and knowing that s' = v and s'' = a, solve for q,b,c, and d.
Someone's been skipping class. Anti-derivative is basically doing the reverse of a derivative.
For example the derivative of 3x^2 + 5x + 4
= 6x + 5
The anti-derivative of 6x + 5
= 6x^2 * (1/2) + 5x * (1/1) + C
= 3x^2 + 5x + C
If the f(x) = 3x^2 + 5x + C
and we're given f(0)=4
then we can figure out the constant C
and we get f(x) = 3x^2 + 5x + 4
Hey guys, what's math? :p
I think I got it! My book doesn't even have this stuff in it. No, I was not skipping class. This teacher just gives us questions we've not even seen before. He does it all the time.
v(t) = 12t^2+6t
s(t) = 4t^3+3t^2 + t?
no?
not even close?
almost, v(t) is incorrect, redo the derivative of s(t) to find the correct v(t)
am i missing the constant in the v(t)? a K right?
Your s(t) is correct, now take its derivative to find v(t).
yes, you are missing a constant in v(t)
EDIT: Sorry I said that your s(t) is correct, sorry it isn't, the "t" term is wrong, you need a constant coefficient, so you need a Kt not a t. But using the initial conditions given to you, you can find what K is.
fghtffyrdmns said:
v(t) = 12t^2+6t
You need the constant, so it's
v(t) = 12t^2+6t+C
to find C, you plug in the fact that you know v(1)=24
After you find C, then you repeat the process to find s(t)
See, this is what I don't understand.
would I just write 24 = 12t^2+6t +c?
the solve for c? where does the K come from?
v(t) = 12t^2+6t + C
s(t) = 4t^3+3t^2 + Kt +C
If I'm understanding your use of variables correctly, K is C.
K is one of the coefficients in s(t), which is known by figuring out C in v(t).
v(t) = ... + C
s(t) = ... + Kt + ...
You wrote v(t) correctly, now just plug in t=1, and you'll get C.
fghtffyrdmns said:
v(t) = 12t^2+6t + C
yes, but C is not the same value or variable in both of those equations. C is just commonly used to represent an unknown constant.
The C in your first equation will be the K in your 2nd equation.
Why do I get 2 values for C, though?
You don't. You just reused the same variable.
I rewrote it:
v(t) = 12t^2+6t + C
s(t) = 4t^3+3t^2 + Ct + D
v(1)=24
s(0)=0
Wait, I think I solved for C improperly. 24 = 12t^2 +6t + C
C = -12t^2-6t+24
t= 3/2 and -2
v(1)=24, which means t = 1. Plug in 1 wherever you have a t.
ahhh yes. I was thinking of something else sorry.
I got c at 6. which makes sense since d should be zero as s(0) = 0.
v(t) = 12t^2+6t
no?
not even close?
Close. The 't' is s(t) would give you a '1' in v(t). I don't see any. How about replacing it with a constant 'C'?
1. What are the constants in a motion equation?
The constants in a motion equation refer to the fixed values that do not change throughout the motion, such as acceleration due to gravity or initial velocity. They are represented by letters or symbols in the equation and are used to calculate the motion of an object.
2. How do you find the constants in a motion equation?
To find the constants in a motion equation, you will need to gather information about the motion, such as the initial velocity, acceleration, and displacement. Then, you can plug these values into the appropriate equations to solve for the constants.
3. What is the significance of finding the constants in a motion equation?
Finding the constants in a motion equation allows us to accurately describe and predict the motion of an object. By knowing the values of these constants, we can calculate the position, velocity, and acceleration of an object at any given time during its motion.
4. Can the constants in a motion equation change?
No, the constants in a motion equation are fixed values and do not change throughout the motion. However, they may vary depending on different factors, such as the location or environment in which the motion is occurring.
5. How do you use the constants in a motion equation to solve for other variables?
The constants in a motion equation can be used in conjunction with other known variables to solve for unknown variables. For example, if we know the initial velocity and acceleration, we can use the equation v = u + at to solve for the final velocity. The constants provide a framework for solving for other variables in the motion equation.
