TypeError with input() function in binary star simulation
  • Context: Python
  • Thread starter Thread starter BiGyElLoWhAt
    error lambda python
17 replies · 3K views
BiGyElLoWhAt
Somewhat irrelevant, but we need to simulate the redshift for a star system. Pretty open ended. Single star, binary, whatever.
The problem is this:
TypeError: <lambda>() takes at most 1 argument (5 given)
And upon searching, most people who get this error have a function that they're using named lambda and it takes some number of arguments and they input the wrong ones such as here:
http://stackoverflow.com/questions/31447844/typeerror-lambda-takes-exactly-1-argument-3-given
That's not the case with mine.
Quite a few
Code:
# -*- coding: utf-8 -*-
Created on Mon Mar 14 20:49:29 2016
@author: Tyler
from __future__ import division
from math import sin, cos, sqrt, pi
step = float(input("Enter the step size in seconds: "))
G = 6.674*10**(-11)
c = 3*10**8
def Move_Stars(r, theta):
    x= r*cos(theta + step)
    y = r*sin(theta + step)
    return x,y
Mass1 = int(input("Enter the mass of object 1 in Kg: "))
Mass2 = int(input("Enter the mass of object 2 in Kg: "))
x_obs = float(input("Enter the x coordinate of the observer in m: "))
y_obs = float(input("Enter the y coordinate of the observer in m: "))
distance = float(input("Enter the distance between the two stars: "))
CoM1 = distance/(1+Mass1/Mass2) (Comment pound-pound) Distance to center of mass of system
CoM2 = distance/(1+Mass2/Mass1) (Comment pound-pound) Distance to center of mass of system
speed1 = sqrt(G*Mass2/CoM1)
speed2 = sqrt(G*Mass1/CoM2)
XS1 = CoM1
XS2 = -CoM2
YS1, YS2 = 0.0, 0.0
input("The speed and orbital radius of Object 1 are ", speed1, " and ", CoM1 , " respectively. Input any key to continue. ")
input("The speed and orbital radius of Object 2 are ", speed2, " and ", CoM2 , " respectively. Input any key to continue. ")
timeLapse = float(input("Enter the time you would like to watch over in seconds: "))
time = 0
omega = speed1/CoM1
theta1 = 0
theta2 = pi
z=0
Rs1 = 2*G*Mass1/(c**2)
while time < timeLapse:
    XS1, YS1 = Move_Stars(CoM1, theta1)
    XS2, YS2 = Move_Stars(CoM2, theta2)
    theta1 += omega*step
    theta2 += omega*step
    print("Position 1 = (",XS1, ",",YS1, ")")
    print("Position 1 = (",XS2, ",",YS2, ")")
    time += step
Sorry for the lack of comments.
It works fine up until this:
Python:
Enter the distance between the two stars: 100000
Traceback (most recent call last):
  File "<ipython-input-2-713c37472433>", line 1, in <module>
    runfile('C:/Python27/Lib/site-packages/xy/Compu2Modern.py', wdir='C:/Python27/Lib/site-packages/xy')
  File "C:\Python27\lib\site-packages\spyderlib\widgets\externalshell\sitecustomize.py", line 685, in runfile
    execfile(filename, namespace)
  File "C:\Python27\lib\site-packages\spyderlib\widgets\externalshell\sitecustomize.py", line 71, in execfile
    exec(compile(scripttext, filename, 'exec'), glob, loc)
  File "C:/Python27/Lib/site-packages/xy/Compu2Modern.py", line 31, in <module>
So where is it getting this lambda thing from?
To me, it looks like it's error-ing on line 31, which is nothing. Just an arbitrary input, not assigned to any variable, to give the user time to read some info before it starts running the loop.
It didn't like my #'s in the code. It tried to latex them.
input() takes a single argument. As you have used it, there are five args.
Try this:
Python:
print("The speed and orbital radius of Object 1 are ", speed1, " and ", CoM1 , " respectively.")
input("Press any key to continue.")
Don't forget you need to fix the other call to input() as well.
Ahhh that makes sense, I suppose.
So now I'm getting other errors. I'm assuming it's because it doesn't like my inputs that I'm giving it. I've never done this mid program before, only at the end, to keep it from terminating before you can get the output info. Is this an acceptable thing to do according to python?
What other errors and what input?
Also, for comments, use just a single # character. With two of them, the browser interprets this as some LaTeX script.
first error, with a space as input:
SyntaxError: unexpected EOF while parsing
second error, with n as input:
NameError: name 'n' is not defined
for the EOF error, google told me to look for a missing parenthesis
Python:
input("Input any key to continue. ")
print("The speed and orbital radius of Object 2 are ", speed2, " and ", CoM2 , " respectively.")
It gets to the first input, then errors upon my submission of said input.
I suppose I didn't put a space as input. I just hit enter.
I commented out the inputs, and it ran fine. I'm just curious why you can't do this, or if I'm just doing it in a dumb way.
I'm not getting any errors. Here's the output I get. I don't know if my input values are valid, so I can't tell if the output I get is reasonable.
For the input prompts, I pressed SPACE and then hit ENTER.
Code:
C:\Users\Mark\Documents\Python3.4.2>python test.py
Enter the step size in seconds: 10
Enter the mass of object 1 in Kg: 10000
Enter the mass of object 2 in Kg: 20000
Enter the x coordinate of the observer in m: 0
Enter the y coordinate of the observer in m: 0
Enter the distance between the two stars: 50000
The speed and orbital radius of Object 1 are  6.3280328696997135e-06  and  33333.333333333336  respectively.
The speed and orbital radius of Object 2 are  6.3280328696997135e-06  and  16666.666666666668  respectively.
Enter the time you would like to watch over in seconds: 20
Position 1 = ( -27969.050969215084 , -18134.03702964566 )
Position 1 = ( 13984.525484607544 , 9067.018514822828 )
Position 1 = ( -27969.05093478924 , -18134.037082742394 )
Position 1 = ( 13984.525467394622 , 9067.018541371197 )
I hit space and enter and got this:
Code:
Enter the mass of object 1 in Kg: 100000
Enter the mass of object 2 in Kg: 500000
Enter the distance between the two stars: 2000000
('The speed and orbital radius of Object 1 are ', 4.474594953736036e-06, ' and ', 1666666.6666666667, ' respectively.')
  File "<string>", line unknown
I am using python 2.7 though. Perhaps that has something to do with it.
I suppose it's all just flare, anyways. It'd be nice to know what the deal is, but it's absolutely non-essential.
You mean "flair"?
I was able to get your code to run, but I'm using 3.4.2. There's a difference between the 2.7 versions and the 3.x versions in that print doesn't take parentheses in the earlier versions. Other than that, I can't think of any reason why your code doesn't run for you, but it does for me.
What's your final version look like? Possibly you're missing a quote, or you have one where it's unexpected in the earlier version.
Yea, that's probably the one that I meant. Not the one that you shoot up in the air.
Sorry, passed out last night.
Python:
@author: Tyler
G = 6.674*10**(-11)
c = 3*10**8
    return x,y
CoM1 = distance/(1+Mass1/Mass2) #Distance to center of mass of system
CoM2 = distance/(1+Mass2/Mass1) #Distance to center of mass of system
XS1 = CoM1
XS2 = -CoM2
YS1, YS2 = 0.0, 0.0
time = 0
omega = speed1/CoM1
theta1 = 0
theta2 = pi
z=0
Rs2 = 2*G*Mass2/(c**2)
    print("Position 2 = (",XS2, ",",YS2, ")")
    time += step
There's my code.
I might just be blind, but I'm not seeing anything to the effect of parentheses or quotes, etc.
Additionally, here's my console return:
Code:
Your code seems to be failing at the first input line. See if this helps -- change the two input() lines to s = input("...")
Other than that, I don't have any more ideas. Your code works for me running 3.4.2. If you still can't get it to work, you might try posting a question on http://www.python.org/.
