Uncertainty in particle position
3 replies · 1K views · last reply
MaxJ
below
below
For this problem,
Problem text: a particle is in the state psi(x) = sqrt(2/a) sin(pi x/a) for 0 <= x <= a, and 0 otherwise; asks which option gives the uncertainty Delta x in position.
My solution is
Typeset derivation of position uncertainty for the wavefunction psi(x) = sqrt(2/a) sin(pi(x-a)/a) on 0 to a, zero otherwise, showing the expectation values of x and x squared and the trigonometric identity for sin squared.
Handwritten-style typeset derivation of the expectation value <x> using integrals from 0 to a, including a cosine term, an integration by parts step, and the evaluated result a/2 for the first integral.
Handwritten-style typeset derivation computing the position uncertainty of a particle: <x> = a/2, <x^2> = a^2/3, and Delta x = sqrt(a^2/3 - a^2/4) = a/(2 sqrt 3).
However, the my answer for ##\Delta x## is not correct. The correct answer is ##\Delta x = 0.18a##. Does someone please know what I have done wrong?
Kind wishes
You have hand waved "zero by symmetry" where what you have waved away is not zero by symmetry. Why do you think it should be zero and what symmetry would there be?
Orodruin said:
You have hand waved "zero by symmetry" where what you hade waved away is not zero by symmetry. Why do you think it should be zero and what symmetry would there be?
Be blessed Sir.
I have doubt what you mean in regards to symmetry. Can you explain some more?
MaxJ said:
Be blessed Sir.
You were the one trying to invoke symmetry arguments so you should be able to tell me why you think the integral should be zero "due to symmetry".
