Uncountable additivity (sigma algebra)
  • Context: Graduate
  • Thread starter Thread starter woundedtiger4
    Algebra
The discussion centers on the concept of uncountable additivity in probability theory, specifically regarding the probability measure of sets within the interval [0, 1). Participants clarify that if the probability of a single point, P({0}), is zero, the sum of probabilities over uncountably many points results in zero. Conversely, if P({0}) is greater than zero, the sum diverges to infinity. The equation ∑α∈[0,1) P(Aα) = |[0,1)| P0 illustrates this relationship, where |[0,1)| represents the cardinality of the interval.
  • Understanding of probability measures and their properties
  • Familiarity with sigma algebras and uncountable sets
  • Knowledge of basic set theory and cardinality
  • Concept of limits and infinite series in mathematics
  • Study the properties of sigma algebras in probability theory
  • Learn about Lebesgue measure and its application to uncountable sets
  • Explore the implications of uncountable additivity in measure theory
  • Investigate the Cantor set and its relevance to probability measures
Mathematicians, statisticians, and students of probability theory seeking to deepen their understanding of uncountable additivity and its implications in probability measures.
woundedtiger4
Respected members: I am trying to learn this example but I am stuck that "WHY the sum on the right-hand side of the equation above is either 0 or ∞, which
contradicts (iii)."
Can anyone give me an example that when will it 0 and when it will ∞ ?
if I =[0, 1)
let's say that we have three sets A_0 = {0}, A_0.5 = {0.5}. A_1 = {1}
then P(0)=1/3, P(0.5)=1/3, P(1)=1/3
because after all they are just three sets and we are after the probability of A_α
therefore P([0, 1)) = ƩP(A_α) = P(0) + P(0.5) +P(1) = 1/3 + 1/3 + 1/3 = 1 and that satisfies condition that P([0, 1)) = 1
Please correct me if my approach is wrong.
Thanks in advance.
It follows from (ii). Note that ##A_\alpha = \{ x + r | x \in A_0 \}## with ##r = \alpha## so ##\mathbb P(A_\alpha) = \mathbb P( \{ 0 \} ) \equiv P_0 \in \mathbb R##.
Hence, $$\sum_{\alpha \in [0, 1)} P( A_\alpha ) = |[0, 1)| P_0$$. Now either ##P_0 = 0## in which case the sum will give 0 no matter how many elements you sum over; otherwise ##P_0 > 0## (IIRC a measure must be non-negative) and you sum a positive value over uncountably many elements.
what is |[0,1)|in ∑α∈[0,1)P(Aα)=|[0,1)|P0 ?
Why the probability of {0} is equal to 0 i.e. P({0}) = P_0 = 0 ? because in (ii) it says "(remember that we want to construct a probability measure where the probability of drawing any given number is equally likely)." does it not say that like other numbers in [0, 1) the 0 has equal probability to appear? or are we considering the number of points in [0, 1) as cantor set (Cantor ternary set) which means that we don't know that how many of them are in [0, 1) ?
PS. I am totally confused because when I look at an example of a fair single coin toss then the probability measure gives 1/2 for head and 1/2 for tail. Similarly, if the probability of drawing any given number is equally likely then why P_0 is zero?
That would be the number of elements in [0, 1), i.e. the number of indices you sum over.
Recall that in the finite case,
$$\sum_{\alpha \in I} P_0 = |A| P_0$$
where |I| is the number of elements in the index set; it may look more familiar as
$$\sum_{k = 0}^n P_0 = n P_0.$$
If you have an infinite sum of a positive constant, the sum will diverge. We write
$$\sum_{k = 0}^\infty P_0 = \infty \qquad \text{( if } P_0 > 0 \text{)}$$
which is just an informal way of saying that
$$\lim_{n \to \infty} \sum_{k = 0}^n P_0 \text{ does not exist}.$$
It's not necessarily. I said: if it is 0, then the infinite sum is 0. If it is not 0, then the sum is infinite.
Thanks a tonne. Crystal clearly understood.
  • · Replies 29 ·
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 19 ·
