Uncovering the Discovery of e=2.7
  • Context: Undergrad
  • Thread starter Thread starter Hepic
    Discovery
The discussion centers around the mathematical constant e, specifically its value of approximately 2.7, its historical discovery, and its significance in various mathematical contexts. Participants explore the reasons behind its usefulness, its appearances in different fields, and the definitions that have been proposed over time.
  • Some participants note that e arises naturally in economics when transitioning from discrete to continuous compound interest calculations.
  • Others mention that e appears in growth models where the rate of increase is proportional to the current population level.
  • A participant highlights the historical context of e, stating it was used long before its value was calculated.
  • Several participants discuss the integral relationship \(\int_1^e \frac{dx}{x} = 1\) as a key definition of e, with some expressing skepticism about its adequacy as a definition.
  • There is a debate about the significance of defining e in terms of its derivative property, with some arguing it provides clearer insight into its applications than the integral definition.
  • Some participants argue that the definition based on the area under the curve of \(1/x\) is fundamental, while others challenge its clarity and relevance.
  • One participant suggests that the universality of e could be a more interesting topic for discussion, referencing its series expansion.
Participants express differing views on the definitions and significance of e, with no consensus reached on which definition is superior or more fundamental. The discussion remains unresolved regarding the best way to conceptualize e and its historical context.
Participants reference various mathematical concepts and historical developments related to e, indicating that the discussion may depend on specific definitions and interpretations of mathematical principles.
Hepic
I want to learn how mathematicians found the number e=2.7
I do not mean the way(1/1 + 1/1*2 ...),but why they found that??
How they imagine that this number will be so usefull??
What was their difficulty and they discover this number??
Thank y!
Mathematics news on Phys.org
1. Well, within economics, if you go from discretely calculated compound interest to calculations of continuously calculated compound interest, the number "e" will appear as the most natural number base for such calculations.
2. Another way in which "e" naturally appears are in simple growth models: If the rate of increase is strictly proportional to the actual population level at that time, again "e" will occur as a naturally preferred base for the exponential growth.
1. and 2. are obviously conceptually related, but comes from two different fields of reality, so to speak.
[tex]\int_1^e \frac {dx} x = 1[/tex]
This relationship is a key definition for my understanding of e.
That seems rather silly.
Why?
To find the area under the multiplicative inverse function (i.e, standard hyperbola) was a MAJOR undertaking in the 17th century.
That is, the gradually developed understanding of the (natural) logarithm function was a critical step in the history of the development of modern mathematics.
In his "First course in calculus", Lang has a nice argument to introduce ##e##. It's a bit informal, but he makes it rigorous eventually.
Basically, he introduces the exponential function ##f(x) = a^x##. He then proves that
[tex]f^\prime(x) = f^\prime(0) a^x[/tex]
Then he shows (by using graphs), that there must exist some number ##e## such that if ##a=e##, then ##f^\prime(0) = 1##. Thus holds that
[tex]\frac{d}{dx}e^x = e^x[/tex]
In my opinion, this is the absolute best way to think of ##e## since this is its fundamental property. I know historically it has been introduced with interest rates and stuff. But the importance nowadays of ##e## seems to be its use in derivatives.
arildno said:
Why?
None of that makes it a particularly good definition, but to each their own.
arildno said:
Why?
I agree with 1MileCrash here. It's obviously a very important property, but this doesn't really make a good definition.
Actually, you are the one needing to argue for the "silliness" of Integral's comment. As yet, you haven't
That seems rather silly only after the fact when you know that Integral's integral evaluates to ##\ln(e) = 1##.
Before the fact, I see Integral's integral as rather fundamental.
If e was discovered to answer the question "what is the maximum of the real valued function x^(1/x)", sure, maybe that had some important application and was an important question in this hypothetical universe, but that does not make it a good definition.
"The number a such that d/dx a^x = a^x" says the same thing denotatively as "the number a such that when 1/x is integrated from 1 to a, the result is 1" except the former is more concise, and requires less to understand.
Connotatively, saying that e is "a such that d/dx a^x = a^x" immediately tells me where e is going to be involved, and its significance. Clearly, e is going to make an appearance in situations where growth or decay is proportional to current value. It isn't even a leap, or a derivation, it is plainly stated.
Saying "the number a such that when 1/x is integrated from 1 to a, the result is 1" does not allow me to immediately see where e would appear. Showing me that, I could not see its significance in application immediately, I would only know it as an interesting number with a relationship to 1/x.
"After the fact" requires knowledge of e in the first place, so "before the fact" is how any reasonable person should consider that definition.
Nope.
If you go back to 17th century maths, the question of what number would make the the area under the hyperbolic curve equal to 1 was a fairly important question.
Basically, here you presuppose the conception of the derivative.
Finding the area under a curve does not, and questions about how to evaluate it will occur independent of fruitful mathematical definitions of derivatives and integrals.
arildno said:
Nope.
What exactly are you objecting to? That we should consider Integral's definition without knowing that the integral of 1/x evaluates to ln(x)?
I would presume that Integral's definition of e does not require me to know this property about e (that it is the base of the logarithmic function whose derivative is 1/x).
Intergral's definition is about area, it has nothing to do with 1/x's antiderivative as a function.
Area is not a more basic concept than a rate of change. I used the derivative notation to symbolize the rate of change just as the integral symbol has been used to symbolize area. Neither requires a fruitful mathematical definition of derivatives or integrals.
"Intergral's definition is about area, it has nothing to do with 1/x's antiderivative as a function. "
QUITE so.
That's why it can be regarded as more fundamental, rather than as silly.
Actually a more interesting discussion would be the universality of e:
[tex]\sum_{k=0}^{\infty} \frac{1}{k!} = \lim_{n\rightarrow\infty} \left(1+\frac{1}{n}\right)^n[/tex]
Aah, happy memories!
Reminds me of my student days, when I and a couple of co-students became determined to prove that identity directly.
We were proud of ourselves when we managed to do so, not the least because we found it rather troublesome to achieve.
:smile:
QUITE so.
I still regard it as silly. The OP was not asking, as I interpret it, for the best formal definition of e but rather why and how mathematicians came to realize e was important. All of my insight into why e is important came before I saw that integral definition and historically that is the case too as far as I know.
You are entitled to your opinions, obviously, but not to your own (historical) facts.
That ends my involvement in this thread.
QUITE so.
The thing is, if I were a student new to calculus and if I were to define ##e## as
[tex]\int_1^e \frac{1}{x} = 1[/tex]
then I would think "alright, cool". But I wouldn't see at all the importance of what ##e## is. Why would we care about this new number ##e## in the first place? This definition doesn't answer this question.
It's a bit like Rudin does the following, he defines
[tex]\sin(x) = x - \frac{x^3}{3!} + \frac{x^5}{5!} - ...[/tex]
and then he defines ##\pi## as the smallest positive zero. This definition is correct, it is important and it makes it very easy to derive all the analysis properties. But it doesn't show why I would care about ##\pi##. So in that sense, I don't like the definition.
I'm not sure how I was listing my own historical facts. To the best of my knowledge the first use of e where e was recognizable in the modern sense is from the standard limit definition - not the integral listed.
If we rely on wikipedia, then the first uses of ##e## were very closely linked to logarithms. So the question really is how people historically saw logarithms. Did they see it as an anti-derivative or as the inverse of an exponential function. Personally, I prefer the latter definition, but I don't know about the historical one.
By the fundamental theorem of calculus, it has *everything* to do with 1/x's antiderivative as a function.
Let's expand upon Integral's integral a bit. Define ##g(x)=\int_1^x \frac {dt}{t}##. Here's the key question: For what value of x is this g(x) equal to one? For lack of a better name, let's call the solution to g(x)=1 e. In other words, e is the unique value that satisfies ##\int_1^e \frac {dt}{t} = 1## (i.e., Integral's integral.)
To find this value e it will help to find the inverse function of g(x). Let's call this inverse function f(x), defined by f(g(x))=x.
That f'(x)=f(x) pops right out of this definition. Since g(1)=0, f(0)=1. These two results immediately lead to ##f(x) = \sum_{n=0}^{\infty} \frac {x^n}{n!}##, from whence ##e = \sum_{n=0}^{\infty} \frac {1}{n!}##.
Of course it actually has everything to do with the functional antiderivative when we know such things.
The point is that the relationship described by the integral does not depend on understanding the relationship between area and antiderivative. This is something that aldrino and I can agree on, and if you are claiming otherwise then any argument you had for the definition being fundamental goes right out the window.
And yes, obviously we can derive other definitions and properties about e from an expression that uniquely describes e.
The point is that the integral definition of e, no matter how important of a question it answers, or how cool it is, does not give any intuitive understanding of why e is important or where it will appear in mathematics. It is the area of this region, OK, so what? Who cares about this region?
If someone asked you what e was and why it was portant, would you really tell them that it was the area of this region? Or even mention that fact?
This is the logic, as I learned it in an analysis course (note, "real analysis" not "Calc 1".)
First, define the idea of derivatives (for example using the epsilon-delta definition) and antiderivatives.
Then you can easily prove that the derivative of ##x^n## is ##nx^{n-1}##, for all ##n \ne 0##.
That leaves an unanswered question: what is the antiderivative ##A(x)## of ##1/x##?
You can prove that ##A(x)## has the properties of a logarithm, to some (unknown) base - for example ##A(xy) = A(x) + A(y)## - direct from the definition of the antiderivative.
So you can write ##A(x) = \log_e x##, and Integral's integral defines the value of ##e##.
It then follows that the derivative of the inverse function, ##e^x##, is ##e^x##, and hence we get the power series for ##e^x##.
And after jumping through those hoops to motivate the definition, it's much simpler just to define ##e^x## as a power series (for all complex values of ##x## not just real values), and define ##\ln x## as the inverse function of ##e^x##.
Wow! That's a lot of discussion for such a simple statement. Obviously area is a more fundamental concept then rate of change. History shows that area has been a useful concept since the very first writings of mankind, rate of change is a much later and subtler concept.
Expressing e as a upper limit in a integral is not the most computable way of going about it. But for me tying it to a simple geometry is much more meaningful then expressing it as an infinite series or any other more esoteric definitions.
This integral is a large portion of the reason e shows up in nature as much as it does.
I guess it depends which bits of nature you look at. You could argue that ##e^{iz} = \cos z + i \sin z## shows up just as much as the integral.
Personally I find the connection with ##\lim_{n \rightarrow \infty}(1 + \frac 1 n) ^n## the least motivational approach.
But mathematicians are fairly agnostic about the "right way" to define things. Back in my day, if a math exam paper asked you to prove three results about X, it was perfectly acceptable to define X three different ways for the three proofs, without bothering to show that the definitions were equivalent!
  • · Replies 105 ·
11K
