Understand Adam Moulton & Bashforth Methods for Numerical Analysis
The discussion focuses on the Adams-Moulton and Adams-Bashforth methods for numerical analysis, particularly in solving differential equations. Steven clarifies that the Adams-Bashforth method uses previously known solution points to create an interpolating polynomial, which is then extrapolated to find the next solution point. The Adams-Moulton method, on the other hand, corrects the predicted value of the next point using both prior information and the extrapolated solution. Participants suggest using graphical demonstrations in Mathematica to visualize these methods effectively.
  • Understanding of numerical analysis concepts, specifically multi-step methods.
  • Familiarity with differential equations and their solutions.
  • Proficiency in using Mathematica for plotting and visualizing mathematical concepts.
  • Knowledge of predictor-corrector algorithms in numerical methods.
  • Explore the implementation of Adams-Bashforth and Adams-Moulton methods in numerical analysis.
  • Learn how to visualize numerical methods using Mathematica, focusing on polynomial approximations.
  • Investigate the stability and convergence criteria for predictor-corrector algorithms.
  • Study the differences between single-step and multi-step methods in solving ordinary differential equations (ODEs).
Mathematicians, numerical analysts, and students studying differential equations who seek to understand and visualize the Adams-Moulton and Adams-Bashforth methods for better application in numerical analysis.
steven187
hello all
I have been researching into numerical analysis, differential equations in particular, I underdstand how the Runge kutta methods work geometrically but I don't quit understand what is the idea behind Adam moultons method And Adam Bashforth method, Is there a graphical way of understanding it? I find it very confusing?
steven
hello all
so far after a bit more research I have come to understand that the adams bashforth requires information about the solution at more than one point, If I assume that we already know these points then what this method does is find an interpolating polynomial that passes through these points and then uses it to obtain the solution of the next point- this occurs when the resulting polynomial is extrapolated over the next interval h, this is pretty understandable graphically but I still don't understand what adams moultons method does graphically does anybody have any ideas
steven
Hello Steven,
My understanding of these multi-step methods is that they're similar in that they use previous points to calculate a polynomial curve as a trajectory to the next point as opposed to a "weighted" straight line for Runge-Kutta. However, the Milne's method and Adam-Moulton methods correct the predicted value of the next y before going on to the next step.
I think a nice way of gleaming a geometrical notion of these methods is to work with ODEs that I know what the analytical solution is and then go through the numerical methods and actually plot (in Mathematica of course) the quadratic and cubic curves that are these methods, as well as the "predictors" and "correctors", and see how they follow the actual path.
Why not just work through a few points for y'=Ay. Maybe post some plots too. :smile:
Hello Saltydog
well that aint a bad idea, there is always one way of finding out how something works and that is if we demonstrated it graphically, I have been writting a program over the last few days, writting the predictor corrector code wasnt difficult but trying to plot each step all on the same graph is a bit complicated, I have given it some thought but i think the way i have structured my program does not accommodate for my expected outcome which is to see the convergence for each point after running the predictor corector many times consecutively for the same point until it satisfies the stopping criteria, anyway this is my current output which is based upon increasing the subintervals
steven
hello all
to answer my original question, a predictor-corrector algorithm, consists of basically two parts, the predictor extrapolates the solution over some finite range h based on the information at prior points and is inherently unstable and the corrector which allows for this local instability and makes a correction to the solution at the end of the interval which is also based on prior information as well as the extrapolated solution.
steven
steven187 said:
Hello Saltydog
steven
Hello Steven,
My first though is why didn't you just save the plots in Mathematica as bitmaps and/or convert them to JPEG as I do and then just post the plots directly here without going through Microsoft Office?
Also, the plots seems to have straight line approximations. I was expecting quadratic or cubic approximations for these numerical methods.
hello saltydog
well the reason why Iv got straight line approximations is because I have structured my program with the 2nd order runge kutta and the second order adam bashforth and second order adam moulton, upgrading the program shouldn't be too difficult anyway
steven
  • · Replies 18 ·
13K
