Understanding 2nd Order Correlation in Fock States and Density Functions
  • Level: Graduate
  • Thread starter Thread starter babylonia
    Correlation
3 replies · 3K views
babylonia
Hi all,
I read on some paper that for a system of Fock state |...nk...>, and with the field operator expanded as
[tex]\Psi[/tex](r)=[tex]\sum[/tex]ak [tex]\phi[/tex]k(r), the second order density correlation function can be expressed as
G(2)=<[tex]\Psi[/tex]+(r)[tex]\Psi[/tex]+(r')[tex]\Psi[/tex](r')[tex]\Psi[/tex](r)>=<n(r)><n(r')>+|<[tex]\Psi[/tex](r)+[tex]\Psi[/tex](r')>|2-[tex]\sum[/tex][tex]^{N}_{k}[/tex] nk ( nk +1) |[tex]\phi[/tex]*(r)|2|[tex]\phi[/tex](r')|2.
I have no idea how the last term, ie. the term after the minus sign, come out? If I use the Wick's theorem for
<a+ka+laman>=<a+kam><a+lan>[tex]\delta[/tex]k,m[tex]\delta[/tex]l,n+<a+kan><a+lam>[tex]\delta[/tex]k,n[tex]\delta[/tex]l,m,
so why in the 2nd correlation there are additional terms after '-'?
This seems really strange, can anybody help me? Thank you.
I didn't check your formula for the correlation function, but your Wick theorem looks wrong to me. You have a two-body density matrix on the left and on the right you have only one-body density matrices. Did you apply a relation like
[tex]\langle a^+_k a_m a^+_l a_n\rangle = \langle a^+_k a_m\rangle\langle a^+_l a_n\rangle?[/tex]
Because such a relation does generally *not* hold.
Hi,
Thanks a lot for your reply. I think for Fock state the Wick theorem leads to [tex]\langle a^+_k a^+_l a_m a_n\rangle = \langle a^+_k a_m\rangle\langle a^+_l a_n\rangle \delta_{k,m}\delta_{l,n}+\langle a^+_k a_n\rangle\langle a^+_l a_m\rangle\delta_{k,n}\delta_{l,m}[/tex], because particle number conservation requires the other terms in the full expression given by wick theorem to vanish. And sorry I forgot to mention that my problem is for bosons. If this is wrong, why, and what is the correct form?
Thanks
Sorry, I might have misunderstood your post: By "In Fock Space", do you mean for a single permanent[1] (or for some mean field approximation?)? Because for a general superposition of permanents no such relation holds, and the two-body reduced density matrix [tex]\langle a^+_k a^+_l a_m a_n\rangle[/tex] in general cannot be reduced to anything which is itself less than a two-body (mixed) density matrix. So by applying (only) the Wick theorem, you could have, for example, something like [2]
[tex]\langle a^+_k a^+_l a_m a_n\rangle = \langle a^+_k a_m a^+_l a_n\rangle + \delta_{ml} \langle a^+_k a_n\rangle[/tex]
but that still has a two-body density matrix in it and is still far from your expression for G. You might need to apply some other relations, too.
[1] that's the positive-symmetry version of a determinant
[2] how exactly the Wick theorem looks depends on whether there is a normal order imposed on the operators, and if it is, which reference it applies to.
