Understanding Double Slit interference and Uncertainty
This discussion centers around the double slit experiment and the implications of the uncertainty principle in quantum mechanics. Participants explore interpretations of how momentum conservation applies in the context of the experiment, the nature of particle behavior, and the challenges of understanding quantum phenomena from both beginner and advanced perspectives.
  • One participant questions whether the double slit experiment can be understood as a result of fundamental uncertainty regarding a particle's position and velocity, suggesting an alternative modeling approach.
  • Another participant challenges the interpretation of the uncertainty principle, stating that while there is no limit to the accuracy of measuring position and momentum for a single particle, predicting these values involves inherent uncertainty.
  • A different viewpoint references Richard Feynman's perspective on particles taking multiple paths, indicating a complex nature of particle behavior in quantum mechanics.
  • One participant critiques the concept of wave-particle duality as outdated, suggesting that modern quantum mechanics has evolved beyond this idea, while acknowledging the complexity of the topic.
  • Another participant expresses frustration about the difficulty of grasping these concepts as an engineering student, highlighting the challenge of balancing time for deep understanding with ongoing inquiries.
  • There is a discussion about the specific nature of uncertainty relations, noting that they apply to the three spatial components of position and momentum separately, without cross-relations between different components.
  • A participant raises a question about the constancy of direction in momentum, linking it to the uncertainty principle and its implications for changes in momentum at the slits.
Participants express differing interpretations of the uncertainty principle and its implications for the double slit experiment. There is no consensus on the best way to model these phenomena, and the discussion reflects a range of perspectives and levels of understanding.
Some participants acknowledge the limitations of their understanding and the complexity of the topic, suggesting that advanced interpretations may not be fully accessible at the current discussion level. There are references to external papers that provide further explanations, but their validity is also questioned.
John Morrell
I've recently been doing some learning about the double slit experiment and a bit about how, qualitatively, quantum electro dynamics works. Something that I wondered about for a long time was how momentum could be conserved in these systems when we assume that a particle could land in any number of positions. I kept thinking; couldn't we do the double slit experiment and just measure the velocity of the particle before it reaches the slits so that we know which one it goes through and where it hits after that? Then I realized that the uncertainty principle states that we can't know both the position and velocity beyond a certain uncertainty.
I just want to check if this is a correct interpretation of this principle. Is it fair to look at the double slit experiment as a result of our fundamental uncertainty about where the particle is and where it's moving? Is it possible to get similar results by assuming particle-like motion where we just don't know where the particle starts or which direction its moving?
Note, I'm not saying that this is why the double slit experiment works the way it does. I just want to know if this is a valid alternative way of modeling it.
This is not quite right interpretation of uncertainty principle nowadays. There is no principal limit to accuracy with which you can measure position and momentum of single particle but you can't predict position and momentum beyond certain limit i.e. it is not possible to prepare a state (ensemble of particles) such that position and momentum does not show some spread in observed values.
The alternative way is to Feynman, as far as we know. The particle along a well defined path from the source to the plate ... a path? no .. different paths, to be honest endless ... what? everyone imaginable compatible with the constraints of equipment ... all ... all and all together.
Well the double slit is surprisingly an advanced topic.
At the beginner level you use a wrong Idea - the wave particle duality - its wrong, was overthrown at least by 1926 when Dirac came up with his transformation theory that generally goes by the name of QM these days, but you need to start somewhere.
Then using the formalism of standard QM you have the following explanation:
https://arxiv.org/abs/quant-ph/0703126
But even that is wrong from an even more advanced standpoint:
https://arxiv.org/abs/1009.2408
And to make matters worse even the above is wrong from the very advanced view - we have professors that post here who even criticize it.
Sometimes physics is like that - maddening isn't it.
At your level , since this is an I level and not an advanced level thread, simply use the first link I gave - you can come to grips with the more advanced stuff layer. If it was an advanced level thread I would let the professors and other professional physicists talk about and simply listen. I understand it to the level of the second paper - beyond that it gets a bit over my head.
Thanks
Bill
Hey thanks for the help guys! In a way this sort of this is kind of maddening because I'm actually an engineering student and I don't know if I'll ever have time to really thoroughly understand this sort of thing in the way that a real professional course of study would let me. But It's nice to know that at least I can keep asking and pick it up one misguided question at a time.
It's also worth pointing out that the uncertainty in position and momentum actually relates to the three spatial components separately. There is an uncertainty relation between the x-components of position and momentum; between the y-components; and, between the z-components. But, there is no uncertainty relation between the x-component of momentum and the y-component of position, say.
Do you mean that the direction, like the unit vector of the x y and z momentum, is unchanging (unless of course the particle interacts with something else)? The direction it travels is essentially constant?
Since the kinetic energy remains constant the change in momentum at the slit due to the uncertainty principle is reflected in a change in direction.
See the first paper I posted.
Thanks
Bill
  • · Replies 32 ·
  • · Replies 36 ·
10K
  • · Replies 20 ·
