Understanding Experimental Error: Standard Deviation vs. Instrumental Precision
The discussion centers on the interpretation of the quantity 'b' in experimental results expressed as + or - b. It highlights that 'b' can represent various forms of uncertainty, including standard deviation or instrumental precision, depending on the context of the experiment. For example, in measuring gravity, the uncertainty could stem from the precision of the measuring instrument rather than statistical variability. The conversation emphasizes the importance of clarifying with the experimenter to determine the nature of the quoted error. Ultimately, understanding the context and methodology of the experiment is crucial for accurate interpretation of uncertainty.
amm17
When coming into contact with a result such as a + or - b, what should one take the quantity 'b' as? Is it always the standard deviation? Or is it an arbitrary uncertainty decided by the scientist running the experiment, based on the equipment? Please help.
Thanks,
Andrew
Mathematics news on Phys.org
Um it really depends on the context. It is hard for us to know what you are talking about because we use + or - all the time.
For example
|x| = 5 implies that x = + or - 5.
or in the quadratic equation
x = + or - the square root of b squared minus 4 ac...
These have nothing to do with standard deviation.
Or for example survey results.
60% or a population + or - 3%, this is error not standard deviation.
These are just a few examples, but we use + or - in a huge number of ways and contexts. So can you tell us a little more what you are talking about? Is there a specific scientific result you are looking at that prompted this question?
We need more info.
Say that a scientist has found, using some experiment, that the acceleration due to gravity is 9.92 +or- .15 m/s^2. Is the .15 the standard deviation, or not necessarily? What else could it be?
Thanks
It could be the uncertainty due to having only a finite number of digits of precision. For example, someone may calibrate a device that has a 16 digit binary output so that its min reading (sxteen zeroes) is 2.80 V and its max reading (sixteen ones) is 900.60 V. If the device gives a reading in between these values, it will only be precise to 16 binary digits. The uncertainty in what a missing 17th digit would represent gives you an error that doesn't necessarily correspond to the uncertainty in not knowing a base 10 digit.
Great, thank you. Now how do you know when the quoted error is standard deviation or instrumental precision? I would guess that an experiment that has no use being repeated (like measuring the length of a dollar bill) would feature an error due to instrumental precision, whereas an experiment worth repeating might have a standard deviation as an error. Thoughts?
The only way to know for sure is to communicate directly with the person who did the experiment.
One of my brothers once showed me that he could shrink a dollar bill by repeatedly folding it up and unfolding it. - I couldn't resist mentioning that.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
