Understanding Experimental Error: Standard Deviation vs. Instrumental Precision
amm17
When coming into contact with a result such as a + or - b, what should one take the quantity 'b' as? Is it always the standard deviation? Or is it an arbitrary uncertainty decided by the scientist running the experiment, based on the equipment? Please help.
Thanks,
Andrew
Um it really depends on the context. It is hard for us to know what you are talking about because we use + or - all the time.
For example
|x| = 5 implies that x = + or - 5.
or in the quadratic equation
x = + or - the square root of b squared minus 4 ac...
These have nothing to do with standard deviation.
Or for example survey results.
60% or a population + or - 3%, this is error not standard deviation.
These are just a few examples, but we use + or - in a huge number of ways and contexts. So can you tell us a little more what you are talking about? Is there a specific scientific result you are looking at that prompted this question?
We need more info.
Say that a scientist has found, using some experiment, that the acceleration due to gravity is 9.92 +or- .15 m/s^2. Is the .15 the standard deviation, or not necessarily? What else could it be?
Thanks
It could be the uncertainty due to having only a finite number of digits of precision. For example, someone may calibrate a device that has a 16 digit binary output so that its min reading (sxteen zeroes) is 2.80 V and its max reading (sixteen ones) is 900.60 V. If the device gives a reading in between these values, it will only be precise to 16 binary digits. The uncertainty in what a missing 17th digit would represent gives you an error that doesn't necessarily correspond to the uncertainty in not knowing a base 10 digit.
Great, thank you. Now how do you know when the quoted error is standard deviation or instrumental precision? I would guess that an experiment that has no use being repeated (like measuring the length of a dollar bill) would feature an error due to instrumental precision, whereas an experiment worth repeating might have a standard deviation as an error. Thoughts?
The only way to know for sure is to communicate directly with the person who did the experiment.
One of my brothers once showed me that he could shrink a dollar bill by repeatedly folding it up and unfolding it. - I couldn't resist mentioning that.
