Understanding Mahalanobis distance
  • Context: Undergrad
  • Thread starter Thread starter Avatrin
    Normal distribution
The discussion focuses on Mahalanobis distance, a metric used primarily in statistics to measure how many standard deviations a point is from the mean of a multivariable normal distribution. The participant seeks a rigorous understanding of this concept, particularly its relationship with ellipsoids and its advantages over Euclidean distance when dealing with variables on different scales. Key resources mentioned include a review of Mahalanobis distance and an informal derivation, which provide foundational insights into its properties and applications in pattern recognition.
  • Understanding of multivariable normal distribution
  • Familiarity with measure theory and integration
  • Basic knowledge of statistics and probability theory
  • Concept of covariance and variance in data analysis
  • Study the properties of Mahalanobis distance in relation to multivariable normal distributions
  • Explore the derivation and applications of Mahalanobis distance in pattern recognition
  • Learn about the implications of covariance and variance in distance metrics
  • Investigate alternative distance metrics and their use cases in statistical analysis
Statisticians, data scientists, and machine learning practitioners seeking to deepen their understanding of distance metrics in multivariable analysis and improve their pattern recognition techniques.
Avatrin
I am currently taking a course in pattern recognition, and several times I have encountered the multivariable normal distribution and thus, Mahalanobis distance. I want to understand Mahalanobis distance; Primarily for understanding the normal distribution, but also to understand the measure itself.
I have read several intuitive explanations here and in books, but how can I do this rigorously? I have had some, but not much, measure theory (in the part of a real analysis course that covered integration theory). I have had one introductory statistics and probability theory course.
What should I read to understand the Mahalanobis distance? Clearly it is related to ellipoids, but how? Again, I don't want a rough intuitive explanation.
MarneMath said:
I'm not really sure what else you're looking for with regards to this. It's simply a metric.
Well, I did write I want to understand it in regard to the N dimensional normal distribution. According to Wikipedia, it tells me how many standard deviations a point x is from the mean of the deviation. The books on pattern recognition don't even really mention it.
So, I guess, what I am looking for is the property of the metric. Why is it used in statistics rather than some other metric?
Imagine you have units on different scales, then the euclidian distance doesn't really make sense, since you're simply adding the squared units of that measurement. So if it's all the same, then we're good. However, if you have units in different scales and types, the idea of distance becomes a bit more complicated. In fact, I don't really like to think about the Mahalonbis distance as a distance but rather a measurement of intensity.
The number one answer here does a good job of explaining how Mahalonbis does a good job at transforming the data into something reasonable: http://stats.stackexchange.com/questions/62092/bottom-to-top-explanation-of-the-mahalanobis-distance
Overall, though the main advantages are that it considers variance, covariances and unitizes uncorrelated variables for the Euclidian distance.
  • · Replies 24 ·
