Understanding Negative Exponents and Bases in Algebraic Expressions
7 replies · 2K views
DS2C
Going through a problem and and I keep getting it wrong and I'm not sure why.
In a part of the problem, the expression ##\left(-3\right)\left(-r^4\right)\left(-s^5\right)## comes up and the solution that it's giving me is ##-3r^4s^5##
Wouldn't the last factor be ##-s^5## since the power of a base with an odd exponent should be negative? Not sure if I'm tripped up somewhere but the book specifically states this, and then gives this solution.
Mathematics news on Phys.org
There's a difference between ##-r^4## and ##(-r)^4## that you seem to be overlooking. The latter equals ##r^4##, which is the opposite sign of ##-r^4##. In the second and third factors, the bases are, respectively, r and s, not (-r) and (-s).
##(-3)(-r^4)(-s^5) = (-1)^3 \cdot 3r^4s^5 = -3r^4s^5##.
To my understanding, ##-r^4## simply means "the negative of ##r^4##.
So ##-r^4=-\left(r\right)\left(r\right)\left(r\right)\left(r\right)##, and it will always be a negative no matter how many r factors there are and no matter if there is an even or odd amount.
Similarly, ##\left(-r\right)^4=\left(-r\right)\left(-r\right)\left(-r\right)\left(-r\right)=r^4##
However, if it were ##\left(-r\right)^5##, would this not be a negative since there is an odd exponent? Or am I just getting hung up on the even/odd exponent ordeal and way overthinking it? Will ##\left(-r\right)^4## and ##\left(-r\right)^5## BOTH have positive results?
For clarification, I plugged ##\left(-2\right)^5## into my calculator and it gave me -32. I then plugged in ##\left(-2\right)^6## and it gave me +64. So according to that train of thought, if the exponent is odd then the result will be negative and if the exponent is even then the result will be positive.
Kind of a dumb question, thank you for taking the time.
There is no (-r)5 involved.
Your expression is ##\left(-3\right)\left(-r^4\right)\left(-s^5\right) = (-3)(-(r^4))(-(s^5)) = (-3)(-1)(r^4)(-1)(s^5)## with additional brackets added to make the association clearer. If you simplify the last expression, you'll see that the exponents of r and s are irrelevant here.
Ok I think I understand. I just used the ##\left(-r\right)^5## as an example not pulled from the actual expression.
I understand what youre both saying. But why does the calculator come up with something different, as in my last post?
##(-2)^5## is the same as ##(-1)^5(2)^5##, which is -32. For the other expression, you have ##(-1)^6## times ##2^6##, or 64.
