Understanding Photon Momentum and Radiation Pressure
  • Context: Undergrad
  • Thread starter Thread starter gunblaze
The discussion revolves around the concept of photon momentum and its implications for moving an object in a vacuum with constant speed. Participants explore the mechanics of using light to accelerate an object and the conditions under which it can maintain constant velocity after the light source is turned off. The conversation touches on fundamental principles of physics, including Newton's laws and the nature of mass and momentum.
  • Some participants propose that shining light on an object can cause it to accelerate, and then turning off the light allows the object to move at constant speed due to the absence of net force.
  • Others challenge this by questioning how an object can maintain constant speed if it continues to accelerate after the light is turned off, suggesting that there may still be forces acting on it.
  • There is a discussion about the relationship between force, momentum, and velocity, with references to Newton's laws of motion.
  • Participants express curiosity about the nature of mass and how it relates to the momentum of photons, with some suggesting that defining mass is essential to understanding the topic.
  • One participant mentions the concept of radiation pressure and its relevance to the discussion, particularly in the context of solar sails and electromagnetic radiation.
Participants do not reach a consensus on the mechanics of maintaining constant speed after the light is turned off, with multiple competing views remaining on the role of forces and acceleration in this scenario.
The discussion includes unresolved questions about the definitions of mass and force, as well as the implications of photon momentum in classical mechanics. There are also references to specific physical laws that are not fully explored or agreed upon.
This discussion may be of interest to individuals studying physics, particularly those focused on mechanics, electromagnetism, and the properties of light and momentum.
gunblaze
Think..
Can i ever make an object in vacumm and on a frictionless surface move with constant speed.. from rest?
Shine light on it and stop after it moves.
Zz.
how?
by using light particles as a resistive force?
Photons have momentum.
Zz.
So u mean by using photons, i can provide an opposing force on the accelerating object.. then as the resultant force on the ball reaches zero, i switch off the light.. the ball will move at constant speed.
But just another qn.. How long will this take?
OK, now you lost me.
You said you want to know how to get an object that was originally AT REST to move with a constant velocity.
My response was shine a light on to it. This will make it move (i.e. accelerate). When you're happy, stop shinning the light. No more source of that acceleration. The object will then simply coast with constant velocity. You DID say this thing is in vacuum with no friction.
Zz.
Yes. After shining the light, the body will accelerate.. but how by switching off the light can the object move with constant speed? the body will continue accelerate even with the light switched off since there is no opposing force on the object right?
No it won't. After the force is "turned off" there's nothing to accelerate the body.
now there is sum of all forces affecting the body zero.
So F=0=dp/dt...so...dp/dt=0...so...p=const...v=const...and that's it.
Please study Newton's First and Second Law of motion.
Zz.
It will continue moving at constant speed because all forces have equalized (ie. in this case, no forces exist) and acceleration only occurs when there is a net force.
By the way, since it is on topic, what is our best understanding as to why photons have momentum but no mass?
hm, and what is mass?:)
I think we can start off with defining that, very good.
Could be good definition that mass is that m in the equotation F=d(mv)/dt?
but how can we define that F now? :-))
I was looking for more of an answer instead of a Q&A session :P
Even without the photon picture, classical EM radiation also contains something called "radiation pressure" (see, for example, Jackson's Classical Electrodynamics). This is due to the presence of E-fields in EM radiation. It is why the often-imagined solar sails are usually made of "metallic" or mylar surface. The conducting surface interact with the E-field of the photon more efficiently than insulating surfaces.
Zz.
  • · Replies 38 ·
  • · Replies 33 ·
  • · Replies 28 ·
  • · Replies 31 ·
  • · Replies 25 ·
