Understanding proof for Heisenberg uncertainty
The forum discussion centers on the proof of the Heisenberg uncertainty principle as presented in Konishi's Quantum Mechanics. The significance of the discriminant being less than or equal to zero is clarified, indicating that this condition ensures the inequality holds for all real values of α. The derived inequality, A - Bα + Cα² ≥ 0, leads to the conclusion that AC - B²/4 ≥ 0, ultimately resulting in the uncertainty relation ΔQΔP ≥ ħ/2. This establishes the necessity of the discriminant condition for maintaining the validity of the inequality across real numbers.
  • Understanding of the Heisenberg uncertainty principle
  • Familiarity with quadratic equations and discriminants
  • Knowledge of basic quantum mechanics concepts
  • Ability to manipulate inequalities in mathematical proofs
  • Study the derivation of the Heisenberg uncertainty principle in detail
  • Learn about the implications of complex roots in quadratic equations
  • Explore the role of inequalities in quantum mechanics proofs
  • Investigate advanced topics in quantum mechanics, such as wave-particle duality
Students of quantum mechanics, physicists, and mathematicians interested in the foundational principles of quantum theory and the mathematical proofs underlying them.
TheCanadian
I've uploaded a proof of the Heisenberg uncertainty principle from Konishi's QM. I just don't quite understand one part: what is the significance of the discriminant being less than or equal to 0? Wouldn't this just result in ## \alpha = R \pm iZ ##? Why would this be desired in this proof?
He finds an inequality that must hold for all real ##\alpha##.
Simplified, it says: ##{\alpha}^{2}+b\alpha +c \geq 0##
The discriminant of the equation ##{\alpha}^{2}+b\alpha +c = 0## is ##D=b²-4c##.
If ##D>0##, the equation will have two different real roots, ##r_1## and ##r_2##, so you get ##{\alpha}^{2}+b\alpha +c=(\alpha-r_1)(\alpha-r_2) \geq 0## (still for all real ##\alpha##).
But this can't be true for values of ##\alpha## lying between the two roots. Therefore ##D \leq 0##.
If I made no mistake just set ##α = ħ / (2<(P-P_0)^2>)##.
I'm not sure about the discriminate, but the equation he derives, true for any \alpha, is:
A - B \alpha + C \alpha^2 \geq 0
where A = \langle (Q - Q_0)^2 \rangle, B = \hbar, and C = \langle (P- P_0)^2 \rangle
So if it's true for every \alpha, then in particular, it's true when \alpha = \frac{B}{2C}. Plugging this into the inequality gives:
A - \frac{B^2}{2C} + \frac{B^2}{4C} \geq 0
Which implies AC - \frac{B^2}{4} \geq 0, or \sqrt{A}\sqrt{C} \geq \frac{B}{2}
Going back to the definitions of A, B and C gives us the uncertainty principle:
\Delta Q \Delta P \geq \frac{\hbar}{2}
where \Delta Q = \sqrt{\langle (Q - Q_0)^2 \rangle} and \Delta P = \sqrt{\langle (P - P_0)^2 \rangle}
Okay, that makes sense since if it's between the two roots then the inequality is not satisfied. But if the discriminant is less than 0, then isn't ## \alpha## now complex and thus not real? Therefore the initial assumption that ## \alpha## is real for the inequality doesn't stand?
The inequality holds for all real ##\alpha##. That leads to the condition that the discriminant must be 0 or less. He doesn't care about non-real roots of the equation. Sure they will exist if the discriminant is less than 0, but the inequality has been derived for real ##\alpha##.
No, in the original derivation, \alpha is just declared to be an arbitrary real number. It's not the solution to the equation \alpha^2 + b \alpha + c = 0 (which would be complex if b^2 - 4c &lt; 0).
  • · Replies 48 ·
  • · Replies 23 ·
  • · Replies 49 ·
10K
