Understanding Reaction Quotient and Molarity
  • Context: Chemistry
  • Thread starter Thread starter njh
    quotient rxn
The discussion revolves around the concepts of reaction quotient, molarity, stoichiometry, and equilibrium in chemical reactions. Participants explore the relationships between these concepts, how they apply to balanced equations, and the implications for calculating reactant and product amounts.
  • Some participants assert that in a balanced equation, molarity is fixed, and excess reactants remain unutilized.
  • Others argue that stoichiometry and equilibrium are distinct concepts, with stoichiometry describing proportions without addressing molarities directly.
  • It is noted that reactions do not go to completion but rather reach an equilibrium point, which can be very close to completion.
  • Participants discuss the reaction quotient (Q) as a value that describes the system at any point, while the equilibrium constant represents the value of Q at equilibrium.
  • Examples are provided to illustrate how to calculate final amounts of reactants and products at equilibrium, using the ICE (Initial, Change, Equilibrium) method.
  • There is a caution against using the term "reduction" in reference to reactants, suggesting "decrease/increase" as more accurate terminology.
  • Some participants clarify that mass and charge are conserved between reactants and products, while other quantities may change.
Participants express differing views on the relationship between stoichiometry and equilibrium, as well as the implications of the reaction quotient. The discussion remains unresolved regarding some of these conceptual distinctions.
Participants highlight the importance of understanding the definitions and assumptions underlying the concepts discussed, particularly in relation to equilibrium and the use of the ICE method.
This discussion may be useful for students and practitioners in chemistry seeking to deepen their understanding of reaction kinetics, equilibrium, and stoichiometric calculations.
njh
I understand that a Reaction Quotient states that Products/ Reactants balance at the Equilibrium Constant. Therefore, if one of the Reactants in the numerator rises in concentration, then you expect to see a REDUCTION in the other Reactant(s) and an INCREASE in the Product.
Firstly, may I confirm that my understanding is correct please?
However, I think that I am getting confused with a part of this and wondered if I could ask for clarification:
I have given an example equation below. A balanced equation, such as the example given, shows two Reactants of 1 mole each (H_2 and I_2), with one Product of 2 moles (2HI). I can not have (1.5 moles of H) and (0.5 moles of I) to create (2 moles of HI).
So, where is my understanding going wrong?
##K_c = \frac{Products} {Reactants}##
##H_2 + I_2 \leftrightarrow 2HI##
##Q_c = \frac {[HI]^2}{[H_2] [I_2]}##
I think the answer is that in a balanced equation you do have the fixed molarity. If there is an excess concentration of one of the Reactants, then this remains unutilised.
You are right in your first paragraph, but I feel like you are misunderstanding some basics here.
Stoichiometry (described by the reaction reaction equation) and equilibrium are two separate (although in practice closely related) concepts.
Reaction equation describes the stoichiometry, and can be used to calculate amount of products/amount of required reactants assuming reaction went to completion (see below). It doesn't say anything about molarities or amounts of substances involved, it just describes their stoichiometric proportions when they react. That helps calculate amounts of substances reacting and helps determine if there are limiting reagents, or if something is in excess.
Technically no reaction goes to completion, technically every reaction goes to the equilibrium point - which is sometimes so close to completion we don't care about details. If we are very close to completion we can use the reaction equation to calculate yield, if we know reaction would go to some equilibrium point that is far from completion we can't - but we still can do some rough estimates of amounts of reactants required, or what would be the maximum stoichiometric yield.
Reaction quotient is a number that describes the mixture at any given point in time - could be the system is at equilibrium, could be it is not there yet, so Q can take (almost) any positive value.
Equilibrium constant is the value reaction quotient will have once the reaction reaches the equilibrium and stops - which actually doesn't mean "nothing is reacting any longer", more like "reaction still goes both ways, but the same amount of products is converted to reactants and the same amount of reactants is converted to products in any given period of time, so their amounts remain constant".
Thankyou Borek, very helpful. There was a gap in my understanding, which is now more clear.
Here is an example. If you initially have 1 mole of H2 and 1 mole of I2, and you let the reaction to to equilibrium, forming x moles of HI, then the final amounts of H2 and I2 will be 1-x/2 and the final amount of HI will be x.
Careful with describing a "reduction" in reactants. Say decrease/increase instead.
Between reactants and products, the only thing that is conserved is mass and charge. Every other quantity is potentially subject to change.
Thank you. I believe that to be the ICE process.
Thankyou.
Equilibrium process.
ICE is just a convenient way of dealing with the math involved (you can call it "math device"), but it doesn't define any property of the system, it just helps describing the principle of mass conservation with equations.
13K
  • · Replies 16 ·
