Explaining Skewness: Why E[(x-u)^3] Determines Direction
  • Thread starter Thread starter skwey
Skewness is determined by the third moment E[(x-u)³], where a positive value indicates right skew and a negative value indicates left skew. This relationship arises because skewness measures the asymmetry of a distribution, with odd moments being zero for symmetric distributions. The discussion highlights that values far from the mean significantly influence skewness, as they weigh more heavily in the calculation. The conversation also touches on the balance between the frequency of values and their distances from the mean, explaining why skewness can be positive or negative despite the presence of higher frequencies on one side. Overall, the understanding of skewness involves recognizing how the distribution's shape affects the moments calculated around the mean.
skwey
Hey
In my textbook it says if E[(x-u)^3] is positive the skew is to the right, and negative to the left. u=expected value.
This is ok and I believe it, but I can't see why it is like this. Is there an easy explanation of why this has to hold?
The first thing to note is that skewness is defined as E[((x-μ)/σ)3], so your E[(x-μ)3] is just the skewness scaled by the cube of the standard deviation. If a distribution has positive (negative) skewness then E[(x-μ)3] is positive (negative) by definition.
The next thing to note is that skewness is an odd moment (e.g., E[(x-μ)1], E[(x-μ)3], E[(x-μ)5], ...) about the mean. All of these odd moments would be zero if the distribution was symmetric. So a non-zero value skewness necessarily means the distribution is not symmetric. (The converse is not true. A zero skewness does not necessarily mean the distribution is symmetric.)
So when talking about a distribution with a positive (negative) skewness we are talking about a distribution that is not symmetric. Think about what E[((x-μ)/σ)3] is measuring. Values far from the mean (|x-μ|/σ > 1) will weigh much more heavily than those near the mean (|x-μ|/σ < 1). It is those values that are far from the mean that determine the skewness. For the skewness to be negative, there must be more such values far from the mean for x<μ than for x>μ. The opposite is the case when the skewness is positive.
Likes 1 person
Thanks DH you obviously know what you are talking about. And sorry for not scaling it as you mentioned, I didn't do it because I only wanted to know why it was negative and why it was positive at times.
However I hope you can give me some more of your time, cause there is one thing that is still unclear:
Regarding the last paragraph of yours, I have had the same thought as you. But let's for argument sake look at the first moment E[(x-u)], with this moment you can use the same arguments as you use. If the distribution is skewed to the right x-u will tend to be bigger than |x-u| to the left. But the moment is still zero, because the p(x)-values to the left will tend to be bigger, so this will make the moment zero.
My question is: how do you disregard this when looking at the third moment, cause even though |x-u| will tend to be bigger at the skewed side. p(x) will tend to be bigger at the non-skewed side. So why does the effect of |x-u|^3 beat the p(x) "effect"? That is, if we have right skew, why does
(x-u)^3*p(x)dx tend to be more positive on the right, than (x-u)^3*p(x)dx is negative on the left side. Because p(x) will be bigger on the left, ex: chi-squared distributions.
Consider each term in the expectation: If there are more terms left of the mean than the right when considered with respect to the frequency of each value in the domain, it would make sense that you get a negative value.
If the distribution was skewed to the left (i.e. had a right tail), you would expect a negative result since the proportion of values of (x-mu)^3 would be negative and we would have a higher frequency of weight being negative.
Think of a scale where you have an object on the left scale, and weights on the right hand scale. You have to balance the weights with the object to get an exact reading: it works in the same sort of way for the skewness.
chiro said:
If the distribution was skewed to the left (i.e. had a right tail), you would expect a negative result since the proportion of values of (x-mu)^3 would be negative and we would have a higher frequency of weight being negative..
That's a bit counter to the more or less standard mean of skewed to the left versus skewed to the right.
For example, this distribution with a long tail to the right is typically denoted as skewed right.
This nomenclature (skewed right means a longer tail to the right) is widespread but is not universal. Some would call the above distribution as being skewed to the left, evidenced by the mode and median being to the left of the mean.
If my terminology was wrong I apologize to the OP (and think D H for the correction). In saying this the premise of my general message still stands.
If there are an infinite number of natural numbers, and an infinite number of fractions in between any two natural numbers, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and... then that must mean that there are not only infinite infinities, but an infinite number of those infinities. and an infinite number of those...
  • · Replies 53 ·
  • · Replies 62 ·
