Understanding the Gravitational Constant Formula | Jamie
The discussion centers around the gravitational constant (G) and its representation in a formula. Participants explore the meaning of the units involved, the distinction between a constant and a formula, and historical methods of measuring G. The scope includes conceptual clarification and historical context.
  • Historical
  • Jamie seeks clarification on the gravitational constant formula, specifically the meaning of the units m, kg, and s.
  • One participant explains that m, kg, and s refer to meters, kilograms, and seconds, respectively, and describes the constant's expression.
  • Another participant asserts that G is a constant rather than a formula, providing the Law of Universal Gravitation as the relevant formula.
  • This participant also explains how to derive the units of G from the formula, noting that G has units of m^3 kg^-1 s^-2.
  • A historical perspective is provided, detailing how Henry Cavendish first measured G using a torsion balance and how C.V. Boys later modified this experiment to measure G through a different method.
Participants generally agree on the definition of the units and the distinction between a constant and a formula. However, there is no consensus on the need for a step-by-step solution to the formula, as some focus on historical measurement methods instead.
The discussion does not resolve the specifics of how to apply the gravitational constant in calculations or the implications of its measurement methods.
lxXTaCoXxl
Can someone explain the following formula to me? I would like to know what m, kg, and s are. At glance I believe this is the cross product of 6.67384 and the other half of the formula. However I am very unsure on how to continue into solving this for any specific value. I believe m is for the mass of a given object? A quick step by step solution of this formula would be helpful.
G = 6.67384 × 10^-11 m^3 kg^-1 s^-2
Thanks,
Jamie
m, kg and s are the units this constant is written in (meters, kilograms and seconds respectively).
The constant is read as 6.67384 times 10 to the power of -11 cubic meters per kilogram second squared.
That's a constant, not a formula.
The formula is the Law of Universal Gravitation, by Sir Isaac Newton:
F_Gravity = G * (m1 * m2) / r^2
Where m1 and m2 are the masses and r is the distance between them.
For a planet orbiting a star or moon orbiting a planet, in a circular orbit r is the radius of the circle of the orbit, hence the use of "r" instead of "d" for distance.
The units for G can be found by working backwards from the formula:
[Newtons] = G * [kg * kg] / [m^2]
so G has units of kg^2 m^(-2) N^(-1) or m^3 kg^-1 s^-2
G is measured from experiments, just like other constants.
Henry Cavendish first measured G by suspending 2 little masses on a torsion setup that were allowed to rotate. And then set another 2 larger masses on the outside and then let the thing come to equilibrium, and then he moved the larger masses and then measured the change in the angle. Knowing the resistance in the thread he was able to calculate G.
Later C.V. Boys modified the experiment and took 2 spheres and then set them on a balance and then put a larger sphere under one of the balance pans and the measured the deflection angle and was able to calculate G.
  • · Replies 16 ·
