Understanding the Speed of Space in Relativity
The discussion revolves around the concept of the speed of space in the context of relativity, particularly focusing on the implications of special and general relativity regarding the expansion of space and the speed of light. Participants explore the idea of whether space can exceed the speed of light and the nature of this expansion.
  • Some participants propose that space can exceed the speed of light, suggesting that this implies space contains negative mass.
  • Others argue that according to special relativity, nothing with mass can reach the speed of light, and photons, being massless, can travel at that speed.
  • A participant mentions that in general relativity, distant objects can recede from each other at speeds greater than light, which may align with the idea of space expanding faster than light.
  • Some participants clarify the distinction between objects moving and the metric expansion of space, emphasizing that space itself is not moving but rather the distances between objects are increasing.
  • There is a discussion about the scale at which expansion occurs, with some participants questioning whether local structures like hydrogen atoms or solar systems are affected by this expansion.
  • One participant notes that gravity can counteract expansion at smaller scales, suggesting that expansion becomes significant at the supercluster level.
  • Another participant expresses confusion about the concept of metric expansion, questioning how distances can increase without movement.
  • Several participants reference the redshift of distant supernovae as evidence for the expansion of the universe.
Participants express multiple competing views regarding the nature of space, the implications of relativity, and the concept of expansion. There is no consensus on whether space can be said to contain negative mass or on the specifics of how expansion operates at different scales.
Participants highlight limitations in understanding the implications of metric expansion and the conditions under which it applies, particularly regarding gravitational effects at smaller scales.
  • #31
my2cts said:
On this page light itself can go faster than c. Goodbye special relativity.
If you think so, then you'd better stop flying and using your GPS, among other things.
This thread has gone quite off-topic. Please look at the OP.
Zz.
  • #32
my2cts said:
Following phinds' advise I read on wikipedia, the first google hit:
"metric expansion is defined by an increase in distance between parts of the universe even without those parts "moving" anywhere"
The distance between two non-moving objects can increase, even with v>c.
That is not understandable.
This is where thought experiments become invaluable, the easiest way to explain is to imagine an expanding soap bubble, if you blow a bubble inside that first bubble it will attach itself to the original, now imagine blowing billions of bubbles inside the original. After that, what you end up with is the original outside expanding bubble with trillions of interconnected bubbles inside. Now imagine that each interconnected surface has a number of objects attached to them. Every object will be moving away from the other objects as each surface expands, even though the objects themselves are not moving, but the expansion of everything is being driven by the original expanding bubble. Now change the bubbles to space-time and the objects to galaxies and you have the answer to how the distance can increase between non-moving objects.
  • #33
Zz.
Actually I do not think so but I am quoting from a page pointed out in a post.
And I believe this thread is still on topic.
  • #34
us40 said:
Hello, we know that according to special relativity nothing in the universe go faster than speed of light,but space can.Now according to E=mc^2 entity with mass can not reach speed of light and photon is mass less with mass=0.So it can reach speed of light so its meaning that space contain negative mass so it has speed greater than speed of light,and why special relativity does not put any constrain on speed of space.Thanks in advance.
Read the OP again, there is a severe misunderstanding here. This isn't just a topic about the expansion of space. If it is, it belongs in the astrophysics forum. Rather, it is the assertion that the apparent super luminal expansion of space is DUE to a "negative mass" of space! It is VERY specific!
Zz.
  • #35
my2cts said:
I mean a cluster of galaxies interacts at a timescale of millions of years, which should short enough to wipe out the effect of a big bang having occurred more than 10 billion years ago.
I'm not quite sure what you mean here. What effects are being wiped out?
  • #36
The simple answer is that a negative mass would have the same constraints as a positive mass, neither of which can travel faster than c.
The difference is that a positive mass will move with the force applied and the negative mass will move opposite to the force applied.
  • #37
I mean that thermalisation would wipe out the memory of a specific state of motion at a certain timescale. That timescale should follow from dynamics.
  • #38
Zz.
I agree. But this thread is at least partly about superluminal expansion.
  • #39
my2cts said:
So the object at 1 billion ly moves at v=c away from us. An object further away would move faster than c relative to us. That contradicts SR.
No it doesn't. You are missing a very very very important point here. The distance we're are talking about here is the comoving distance. That means the distance is not measured the same way it would usually be measured in special relativity and any receding rate cannot be directly used to find how fast an object is moving with respect to another. Note that that is possible to do even within Special relativity. There is no need to use General relativity.
  • #40
I am not missing the point. I use Fizeau-Doppler. GRT tells me that the rate of change of distance is not related to velocity and frankly I do not know what to think of that.
  • #41
I agree with 2cts, that we only get objects moving at relative velocities greater than c because we are using general relativity. I can't think of any situation in special relativity where two objects would have relative velocity which is greater than c...
edit: I guess it depends on where you draw the line between special relativity and general relativity...?
  • #42
This link may help to understand my view:
http://www.livescience.com/38533-photons-may-emit-faster-than-light-particles.html
  • #43
It essentially is saying that if photons were not massless, then other objects could move faster than photons. Yep, but that's not very interesting in my opinion. c would still be the upper speed limit, and relativity would still work the same, but photons would be massive particles instead.
  • #44
us40 said:
You need to be very careful here. The paper in question (not this news report) is similar to the investigation on the UPPER LIMIT of photon mass. It does NOT imply that it has a mass. The same goes with this particular study. It is saying that if a photon has a mass, then it must have a lifetime and decay to other particles. So they estimated the LOWER LIMIT of the decay lifetime of a photon. It doesn't mean that they have actually found it! Furthermore, look at the lifetime that they computed, and compare that to the age of the universe!
a visible wavelength photon in our reference frame would be stable for 10^18 years or more
There's a lot of "If's" here and there's a lot of "sensationalistic noise" that you have to overcome to get the actual physics.
Zz.
  • #45
What I trying to say is...
Photon is quantum of light.Now in loop quantum gravity(candidate theory for quantum gravity) physicist create quantum of space.(http://en.wikipedia.org/wiki/Quantum_loop_gravity).
Now say that quantum of space spaceon(sorry for wired name). Now according to article I have referenced in previous post if particle is lighter than photon it can go with greater velocity.So spaceon can go faster than speed of light.If photon has positive mass spaceon has mass somewhat lesser than photon and if photon has zero mass mass of spaceon is negative.That is my point.
  • #46
But what exactly is the physics that allows you to say that if a particle has v>c, it mass must be negative?
Look at tachyons, for example. One can arrive as the mass of these hypothetical particles quite directly from SR. See, for example:
http://math.ucr.edu/home/baez/physics/ParticleAndNuclear/tachyons.html
Look at the criteria for M^2 to be negative. That is why I said earlier about mass being "imaginary" in this case. Nowhere in here is the requirement that mass has to be "negative" for this particle to have v>c!
Again, to repeat, we know and already have particles with negative mass. They have the opposite behavior as regular particles in a gravitational field, etc. But they certainly do not have superluminal behavior.
Zz.
  • #47
The article is saying if the photon has mass, then another particle might go with greater velocity. This is possible because this other particle could still have velocity less than c, but greater than the speed of the photon. The main thing is that massless particles move at c, and particles with mass move at less than c.
A (hypothetical) particle which travels at greater than c is called a tachyon, and would have imaginary mass, as ZapperZ was saying. Also, about the 'spaceon' I'm not sure what you mean. I don't know anything really about quantum gravity. But I think in string theory, a 'graviton' is predicted (which is a massless particle). But from what I read in the wikipedia page on quantum loop gravity, there is no particle like the graviton which is fundamental to quantum loop gravity.
  • #48
Zz.
underline by me
Sorry to butt in, but I would like to read more about this. Do you have a link or source?
  • #49
OK, this is just getting weirdly speculative. Even in theories where the volume operator is discrete that doesn't mean that there are spaceons that travel anywhere. Please stop just making stuff up.
Also, your question wrt negative mass has been answered. To recap: the article you cited was talking about the possibility of photons having some non-zero (positive) mass. If that were true then photons would not travel at c and particles with (positive) mass could travel faster than photons but still slower than c. Hypothetical particles which would go faster than c are called tachyons and would have imaginary mass, not negative mass.
Thread closed.
  • · Replies 18 ·
  • · Replies 45 ·
  • · Replies 130 ·
18K
