Understanding the Stress-Energy Tensor
The discussion revolves around understanding the stress-energy tensor, particularly from a mathematical perspective. Participants explore various interpretations, formulations, and applications of the tensor in the context of physics, including its role in cosmological models and its representation through different mathematical frameworks.
  • One participant seeks an intuitive understanding of the stress-energy tensor, expressing difficulty due to a math background.
  • Another participant introduces the concept of using Clifford algebra to represent volume elements and discusses the necessity of a rank-2 tensor for describing energy and momentum density.
  • A question is raised about whether to consider a changing volume element over time or a static one when analyzing energy changes within it.
  • Further elaboration on the stress-energy tensor as a bilinear map from tangent vectors to real numbers is presented, emphasizing its dependence on the chosen arguments.
  • Some participants reference the stress-energy tensor of a perfect fluid used in cosmological models, providing a specific formulation.
  • There is a discussion about different interpretations of the stress-energy tensor, with one participant suggesting that it serves as a bilinear map from a 4-vector representation of a volume element to the 4-momentum vector.
  • A participant expresses confusion regarding the units of the stress-energy tensor in the context of a perfect fluid model, leading to a detailed examination of the Schwarzschild solution and the implications for the tensor's diagonal elements.
  • Another participant indicates they may have identified a mistake in their calculations related to the stress-energy tensor's formulation.
Participants express various interpretations and approaches to understanding the stress-energy tensor, indicating that multiple competing views remain. The discussion does not reach a consensus on the best intuitive understanding or the resolution of the unit conflict in the perfect fluid model.
Participants highlight the complexity of the stress-energy tensor's formulation and its dependence on the chosen mathematical framework. There are unresolved mathematical steps and assumptions regarding the representation of volume elements and the implications for energy-momentum relationships.
Fubini
What is a good intuitive way to think of the stress-energy tensor outside of Einstein's Ric-(1/2)Sg = 8pi T? I'm trying to understand the concept, but coming entirely from a math background I'm not quite getting it.
If you have a math background, you might be familiar with Clifford algebra.
If you are, then you know that a volume can be represented as a 3-form, and has a clifford dual, which is a 1-form.
The point of this is that the total amount of energy and momentum contained in any particular volume in any frame is given by the volume element (a 1-form) multiplied by the stress-energy tensor. This is a coordinate independent formulation for the "density" of energy and momentum.
You might not think that you need a rank-2 tensor to describe the density of energy and momentum, but it turns out to be required.
If you don't have a background in Clifford algebra, think of a volume element as being defined by a vector which is orthogonal to the volume element. (This implies that the choice of the reference frame determines the direction of the vector). The length of the vector defines the size of the volume element.
When we look at this tensor do we consider a volume element and consider how it changes in time, like divergence?
Or, would we keep a static volume element and consider how the energy inside the volume is changing?
Overview.
The stress-energy tensor T is a second rank tensor so it can be viewed, for example, as a bilinear map from pairs of tangent vectors to the real. The metric tensor allow T also to be viewed a linear map from tangent vectors to tangent vector, as a linear map from cotangent vectors to tangent vector, etc. Depending on the viewpoint taken, and on which arguments (like 4-velocities) are used for the linear maps, various physical quantities (like pressure) appear the image of a particular linear mapping.
Hopefully, I can specifics tomorrow.
On the other hand, the stress-energy tensor used in some cosmological models is that of a perfect fluid -
T_{\mu\nu} = pg_{\mu\nu} + \mu u_{\mu}u_{\nu} + \frac{p}{c^2}u_{\mu}u_{\nu}
As George alludes, there are several different interpretations possible of the stress-energy tensor. These are discussed in, for example, MTW's "Gravitation". IMO, however, the most useful interpretation of the stress-energy tensor is that it is a bi-linear map from a 4-vector representation of a volume element to the vector representation of the 4-momentum contained within that volume element. The 4-momentum is of course a 4-vector.
Thus the stress-energy tensor is a map from a 4-vector to a 4-vector, which makes it a rank 2 tensor.
Clifford algebra comes in handy in demonstrating that a vector *is* the correct way to represent a volume.
Could someone, please, explain me, the conflict in the stress-energy tensor units. So for the perfect fluid we have:
T_{\mu\nu} = pg_{\mu\nu} + (\rho + \frac{p}{c^2})u_{\mu}u_{\nu}
But on the other hand
u_{\mu} = g_{\mu\nu}u^{\nu}.
Now, in the comoving frame
u^{\nu} = \frac{dx^{\nu}}{d\tau}
where
d\tau^2 = - ds^2 (-, +, +, + signature).
that follows:
d\tau = \sqrt{-g_{00}}dx^0
(remember, we are in comoving frame). Here the real problem starts. For Schwarzschild solution, g_{00} = - e^{2\nu} and dx^0 = cdt. Then
d\tau = e^{\nu} c dt
This makes
u^{\nu} = \frac{dx^{\nu}}{d\tau} = e^{-\nu} (1, 0, 0, 0)
and
u_{\mu} = g_{\mu\nu}u^{\nu} = - e^{\nu} (1, 0, 0, 0)
Now let us see, the diagonal elements of energy momentum tensor:
T^0_0 = p \delta^0_0 + (\rho +p/c^2)u^0u_0 = p - \rho - p/c^2?
And this makes no sense. Could someone help me, where am I doing wrong? Thanks.
I think i found my mistake:
c^2 d\tau^2 = - ds^2
  • · Replies 33 ·
