Undergrad Understanding the Uncertainty Principle
The discussion centers on the Uncertainty Principle in quantum mechanics, specifically the characteristics of minimum-uncertainty states, which are represented by Gaussian wavefunctions. It is established that the product of uncertainties in position and momentum, denoted as ##\sigma_x \sigma_p##, equals ##\frac{\hbar}{2}## for these states. Participants clarify that while every Gaussian is a minimum-uncertainty state, not all minimum-uncertainty states are Gaussian. The discussion also emphasizes that in stationary states, there is no uncertainty in energy, as energy values are precisely defined.
  • Understanding of the Heisenberg Uncertainty Principle
  • Familiarity with Gaussian wavefunctions in quantum mechanics
  • Knowledge of self-adjoint operators in quantum theory
  • Basic proficiency in mathematical proofs related to quantum mechanics
  • Study Griffiths' "Introduction to Quantum Mechanics" to solve problem 1.14 on minimum-uncertainty states
  • Explore the mathematical derivation of the Heisenberg Uncertainty Principle
  • Investigate the implications of self-adjoint operators in quantum mechanics
  • Learn about the role of Gaussian wavefunctions in quantum state representation
Students and professionals in physics, particularly those specializing in quantum mechanics, as well as researchers interested in the mathematical foundations of quantum theory.
majormuss
Hi everybody,
I was reading about the Uncertainty principle and I came across the statement:
"the position-space wavefunction of a minimum-uncertainty state is a Gaussian. Indeed, because it’s a minimum-uncertainty state, its momentum-space wavefunction is also a Gaussian."
Unfortunately it was stated without any mathematical proof or diagrams so I am a bit puzzled! Also,
what does it mean exactly that:
"The first energy level of a system is minimum uncertainty."
My guess it that it means for lower energies the uncertainty in the energy is minimum. However, due to the quantized nature of the energy levels, how is it possible to be uncertain about the energy of a particle?
A minimum-uncertainty state is one in which ##\sigma_x \sigma_p = \frac{\hbar}{2}##, where ##\sigma_x## is the uncertainty in position and ##\sigma_p## is the uncertainty in momentum. ##\hbar /2## is the smallest possible value for the product of uncertainties in position and momentum, by the Heisenberg uncertainty principle.
I don't know if every minimum-uncertainty state is a gaussian, but it is certainly true that gaussians are minimum-uncertainty states. To show this, do problem 1.14 in Griffiths, Introduction to Quantum mechanics.
Likes entropy1
The minimum uncertainty refers to the product: σxσp=ℏ/2, as stated above by Lucas SV. There is no uncertainty in energy in a stationary state, as the energy is known exactly.
One proof of the uncertainy principle for two observables represented by self-adjoint operators ##\hat{A}## and ##\hat{B}## goes as follows: Let ##\lambda \in \mathbb{R}##. Now we use that the quadratic polynomial
$$P(\lambda)=\langle (\hat{A}+\mathrm{i} \lambda \hat{B}) \psi| (\hat{A}+\mathrm{i} \lambda \hat{B}) \psi \rangle \geq 0.$$
It's ##=0## if and only if (for some value of ##\lambda##)
$$(\hat{A}+\mathrm{i} \lambda \hat{B}) |\psi \rangle=0. \qquad (*)$$
Without loss of generality we can assume that
$$\langle A \rangle=\langle{B} \rangle=0,$$
because otherwise we can consider the observables ##\hat{A}-\langle A \rangle \hat{1}## and ##\hat{B}-\langle B \rangle \hat{1}##. Now due to the self-adjointness of the operators and since ##\lambda \in \mathbb{R}## by assumption, we have
$$P(\lambda)=\langle \psi|(\hat{A}-\mathrm{i} \lambda \hat{B})(\hat{A} + \mathrm{i} \lambda \hat{B})|\psi \rangle=
\langle \psi |\hat{A}^2 + \lambda \hat{B}^2+\mathrm{i} \lambda [\hat{A},\hat{B} ]|\psi \rangle.$$
Since this polyonmial is ##\geq 0## always, it has either exactly one real root, and then for this root (*) is valid or it has two complex conjugate roots. This implies that always
$$\langle A^2 \rangle \langle B^2 \rangle \geq \frac{1}{4} \langle \mathrm{i} [\hat{A},\hat{B} ] \rangle.$$
This is the uncertainty relation.
Now (*) is the condition for the state to be of "minimal uncertainty", i.e., that the equality sign holds in the uncertainty relation. Now take ##\hat{A}=\hat{p}## and ##\hat{B}=\hat{x}##. Now we use the position representation of the space ket and check the solution for (*), given any ##\lambda \in \mathbb{R}##:
$$(\hat{p}+\mathrm{i} \lambda \hat{x})\psi(x)=0 \; \Rightarrow \; \mathrm{i} (-\partial_x + \lambda x) \psi(x)=0.$$
Here and in the following I use natural units, where ##\hbar=1##. The above equation means
$$\psi'(x)=-\lambda x \psi(x)$$
with the solution
$$\psi(x)=A \exp \left (-\frac{\lambda}{2} x^2 \right ).$$
In order that ##\psi \in L^2(\mathbb{R})## we must have ##\lambda>0##. So for any ##\lambda>0## the above Gaussian wave function represents a state of "minimal uncertainty", i.e., for which
$$\Delta x \Delta p=\frac{1}{2}.$$
Likes majormuss, Jilang and Lucas SV
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 20 ·
