Understanding the Uniform Probability Distribution in Statistical Ensembles
231 replies · 16K views
bananabandana
Confused about what a statistical ensemble actually means. Why does the ensemble have to have a uniform probability distribution at equilibrium? [If my definition of an ensemble is correct]
This is what I understand so far: [/B]
  • For any given macrostate, there is going to be an associated set of microstates ( a region in phase space)
  • If we look at a great number of systems started off with the same macrostate, under the same conditions, then if we looked simultaneously at all of them some time later you would have say, five in microstate 1, 2 in microstate 2 etc. etc.
  • So in this way you have a probability distribution for the microstates [as a function of time] - is this what an ensemble is?
  • But then why is it necessarily true that at equilibrium the probability distribution must be uniform? I.e the ensemble doesn't change with time?
  • I can understand the logic for an isolated system - but why does it hold in general?
Thanks!
I think that that the concept of ensemble in statistical physics creates more confusion than explanation. Most ideas of statistical physics can be more easily understood without it. The central concept one needs to start from is probability, and if one understands what probability is then the concept of ensemble is superfluous. The concept of ensemble is created for those who are confused with the concept of probability, with the motivation to better explain what probability "really is". However, the explanation based on ensemble can easily create even more confusion.
That being said, one can concentrate on your questions which do not mention ensemble. The entropy can be defined in terms of probability (without referring to ensembles) as
$$S=-\sum_x P(x) ln P(x)$$
where ##x## are points in the phase space of physical interest and ##P(x)## is the corresponding probability distribution. Depending on the physical context, the states ##x## can be either (fine-grained) microstates or (coarse-grained) macrostates. By definition, equilibrium probability distribution is the one that maximizes entropy. So it is a matter of relatively straightforward calculation that entropy (defined by equation above) is maximal when probability is uniform.
Or perhaps you wanted to know where does the definition "equilibrium probability distribution is the one that maximizes entropy" comes from?
But to make sense of the concept of probability in the spirit of Kolmogorov one needs the notion of realizations of random variables. The ensemble is just the collection of all conceivable realizations.
bananabandana said:
why is it necessarily true that at equilibrium [...] the ensemble doesn't change with time?
Equilibrium is defined through stationarity in time. Thus the ensemble is time-independent by definition. If there are changes in time, is is a sure sign of lack of equilibrium.
Different ensembles have different distributions. The distribution of the canonical ensemble is not uniform.
That being said, one can concentrate on your questions which do not mention ensemble. The entropy can be defined in terms of probability (without referring to ensembles) as ...
"The central concept one needs to start from is probability, and if one understands what probability is."
What is your understanding of probability, please?
N88 said:
"The central concept one needs to start from is probability, and if one understands what probability is." What is your understanding of probability, please?
It often leads to heated argument but my understanding is Kolmogorov's axioms
http://www.econ.umn.edu/undergrad/math/Kolmogorov's Axioms.pdf
Like QM itself you can have different interpretations - frequentest, Baysian, Decision theory etc etc.
Interestingly much of QM interpretations is simply an argument about probability
http://math.ucr.edu/home/baez/bayes.html
I hold to the ignorance ensemble interpretation of QM which is ensemble, frequentest in its interpretation of probability etc etc - it all really means the same thing. Copenhagen, Bayesian etc etc (I really can't tell the difference) is Bayesian. Many worlds is decision theory based - at least in modern times.
Chose whatever you like - but for heavens sake don't worry about it - all are equally valid, or not valid - its meaningless really - just a personal preference thing or sometimes a specific choice makes solving a problem easier.
I did a degree in applied math where I had to do mathematical statistics 1a, 1b, 2a, 2b, and as an elective also 3a, 3b. We would seamlessly choose between different views such as frequentest or Baysian purely on the problem. Why not do the same in QM?
Thanks
Bill
Demystifier said:
It depends on the context, so the question is too general. Can you ask a more specific question?
Demystifier, I was asking in the context of your statement: "I think that that the concept of ensemble in statistical physics creates more confusion than explanation. Most ideas of statistical physics can be more easily understood without it. The central concept one needs to start from is probability, and if one understands what probability is then the concept of ensemble is superfluous."
For I take an ensemble to be the starting point for understanding probability.
PS: Thanks Bill; I'm also a fan of Ballentine.
Then let me use an example. Suppose that you flip a coin, but only ones. How would you justify that the probability of getting heads is ##p=1/2##? Would you use an ensemble for that?
It would be premature to try to assign a probability based on one trial ( I hope you don't gamble).
I should say though, that if I knew the phase space of the coin tossing Hamiltonian, I could use that to get a probability.
How about zero trials? Even without flipping a coin I would predict that probability of getting heads is p=1/2.
You would be making an assumption. Not all coins are 'fair'.
Being serious for a moment - if we have a Hamiltonian we can define an ensemble without reference to probability. Probability is not fundamental - likelihood ( the number of ways something can happen) comes first ( in physics anyway).
I agree with that. But do we necessarily need ensembles for that purpose?
We are delving into rather obvious circularity here - which is why the axiomatic approach is best for clarity.
Thanks
Bill
I would take those axioms to define what it means to be a probability function---it's any function on subsets of events such that blah, blah, blah. But it doesn't say what it means to say that something has probability X, because for any set of possibilities, there are infinitely many different probability functions.
The axiomatic approach only tells one what is permitted to do with probabilities, not what they are.
Various items on the meaning of probability can be found in Chapter A3: Classical probability of my theoretical physics FAQ.
Well, as Bill says, there is something a little circular about saying that
If there are [itex]N[/itex] possibilities, then each possibility has likelihood [itex]\frac{1}{N}[/itex].
That conclusion assumes that each possibility is equally likely. So you need some notion of likelihood to start with. We might say that "If I throw a pencil, there are three possibilities: It could land on its side, or it could land on its point, or it could land on the eraser." But obviously, those three possibilities don't all have probability 1/3.
It's possible that a lot of probability can be derived from some assumption along the lines of:
If there is a symmetry relating all [itex]N[/itex] possibilities, then they are all equally likely.
Hmmmm - yes - but its a bit more complicated
From Feller - An Introduction To Probability Theory And Its Applications page 3
'We shall no more attempt to to explain the true meaning of probability than the modern physicist dwells on the real meaning of mass and energy or the geometer discusses the the nature of a point. Instead we shall prove theorems an show how they are applied'
It is the 'intuition' you build up in seeing how its applied that is its real content. In particular you need to see concrete examples of this thing called event in the axioms.
Thanks
Bill
If I buy a lottery ticket, there are two possibilities: Either I win the jackpot, or I don't. The jackpot is worth many thousand times the lottery ticket. Assigning equal probabilities (or likelihoods) I should buy a dozen tickets and win almost with certainty.
stevendaryl said:
If there is a symmetry relating all N possibilities, then they are all equally likely.
But this principle is almost never applicable. Coins, for example, are not symmetric, neither are dice.
It therefore requires some knowledge of physics to assign correct probabilities to a physical system that is not measured.
Yes. This is the analogue of shut-up-and-calculate in applied mathematics.
I may have been overly influenced by Bayesianism, but it seemed to me that ensembles (and the associated frequentist probability) doesn't actually help in understanding probabilities. You can understand "A coin toss has 50/50 chance of resulting in heads or tails" in terms of repeated trials as follows:
"A coin toss has a 50/50 chance of heads or tails" means "Tossing a coin 100 times will produce [itex]50 \pm 5[/itex] heads and [itex]50 \mp 5[/itex] tails with probability 99%" (or whatever the number is). But you've just defined the probability for one event (tossing a single coin) in terms of the probability for a different event (tossing 100 coins). You haven't explained anything.
Well, subjective (Bayesian) probability doesn't have this problem, because there is a symmetry in our knowledge about the coins. That is, we don't have any reason to prefer one side of a coin over another.
Physics by itself isn't good enough either. Physics allows you to deduce (in principle---in practice, it's often too complicated) probabilities for final states from assumed probability distributions on initial states. But physics alone doesn't tell us the probabilities of the initial states.
I don't know what you mean. There's no mention of phase space.
I mean something very different by 'likelihood'.
If you throw 2 dice, the various outcomes depend on the number of ways they can happen. And they are not the same. Probability is normalized likelihood and likelihoods are raw phase-space volumes.
As I said one flicks between different interpretations depending on the problem. You can't use a frequentest view to assign a reasonable a-priori probability to a coin - but in the Bayesian view its rather trivial then one uses Bayesian inference to update the probabilities.
Thanks
Bill
I think you are introducing a Bayesian reasonable a-priori view here. This stuff is notoriously slippery and circular.
Thanks
Bill
Subjective probability isn't good either since one can choose arbitrary probabilities that have nothing to do with the real situation. As it is subjective, any choice is as good as any other. I can prefer head 3 times as much as tail because it shows the value of the coin. Your argument not to prefer one side of the coin is based on reason, which is a subjective preference. (Most people are often unreasonable.)
What you are effectively saying is that one needs reason to determine the probabilities. I agree.
But the only acceptable reasons to predict the later frequencies are physical - any other reasons don't matter!
Experiment and data collection is part of physics. They determine the missing information in the physical models.
If you can see that a physical system is in equilibrium you know that you only need to determine a few numbers to determine the full density operator and hence all probabilities. If you can see that the only relevant degree of freedom is the polarization, you need to determine just four numbers - the components of the Stokes vector. And so on.
Theoretical physics tells you precisely which kind of information you need to determine the probabilities, Experimental physics tells you what are the reliable ways to obtain this information.
The difference between probability and likelihood is exactly what? Please be precise. I think you will find its very very slippery just like pinning down exactly what a point is rather slippery. That's why the axiomatic method was developed - it wasn't just so pure mathematicians could while away their time.
Thanks
Bill
But you're making the assumption that equal volumes in phase space are equally likely. I guess you could say that that's the way you're defining "likelihood", but why phase space? For a single particle, you could characterize the particle's state (in one-dimension, for simplicity) by the pair [itex]p, x[/itex], where [itex]p[/itex] is the momentum. Or you could characterize it by the pair [itex]v, x[/itex], where [itex]v[/itex] is the velocity. If you include relativistic effects, [itex]v[/itex] is not linearly proportional to [itex]p[/itex], so equal volumes in [itex]p,x[/itex] space don't correspond to equal volumes in [itex]v,x[/itex]. So why should one be the definition of "equally likely" rather than the other?
Exactly. Based on intuition and experience we all make reasonable assumptions.
Thanks
Bill
But the point is that subjective probability is subjective, so the fact that different people use different probabilities is not a problem.
I guess intuitively we feel that some people's subjective probabilities are more accurate than other people's, but you would need a nonsubjective notion of probability to make such a judgement.
Physics alone can't tell you anything about probabilities unless you know the initial conditions exactly. If you don't know them exactly, then in probabilities you compute must be weighted by your notion of likelihood of initial conditions. So you can't avoid subjective probabilities, it seems to me.
