Understanding Topology: Metric Spaces, Open Balls, and Intersection Proofs
  • Context: Graduate
  • Thread starter Thread starter oxeimon
    Topology
The discussion revolves around the concepts of metric spaces and topology, specifically focusing on open balls, their intersections, and the properties of the metric topology. Participants explore definitions, properties, and examples related to these topics, including the relationship between open sets and open balls.
  • One participant notes that a metric space is a topological space under the topology of all open balls but questions whether the intersection of two open balls is itself an open ball.
  • Another participant clarifies that the metric topology is generated by the set of all open balls, which includes finite intersections and arbitrary unions of open balls.
  • A later reply emphasizes the distinction between open sets and open balls in a metric space.
  • One participant asks for a proof that the intersection of two distinct open balls is not itself an epsilon-ball.
  • Another participant provides a definition of a topology and explains how open balls can serve as a basis for generating a metric topology.
  • There is a discussion about whether two different bases for the topology on \mathbb{R} are the same, with one participant suggesting they are homeomorphic but not identical.
  • Participants discuss the correct use of LaTeX notation for inline and display math.
Participants express differing views on the nature of intersections of open balls and the relationship between different topologies. Some agree on definitions and properties, while others challenge or seek clarification on these points, indicating that the discussion remains unresolved in several areas.
There are limitations in the discussion regarding the completeness of proofs and definitions, particularly in establishing the homeomorphism between different topologies and the properties of intersections of open balls.
This discussion may be of interest to students and enthusiasts of topology, mathematics, and related fields, particularly those looking to understand the foundational concepts of metric spaces and their properties.
oxeimon
So I'm trying to teach myself some topology, and the first thing I noticed, was that a metric space is a topological space under the topology of all open balls..
But then, consider the intersection of two open balls, can someone prove to me that the result is another open ball?
Or do they mean, that the topology is the set of all open balls, finite intersections of open balls, and arbitrary unions of open balls?
edit: How do I use latex notation on these forums?
The metric topology is not the set of all open balls, but rather, the topology generated by the set of all open balls. Meaning, is open in the metric topology any set U having the property
"For any x in U, there is an open ball containing x and itself entirely contained in U."
Alternatively, but this is more difficult to express and more vague also, the metric topology is the topology obtained, as you say, by taking the set of all open balls, finite intersections of open balls, and arbitrary unions of open balls, but also, by taking all arbitrary union of finite intersections of open balls.
To use latex use the tags [ tex] [/tex] (without the space in the first one).
Yes, that is what they mean.
Take care to note the difference between open sets and open balls in a metric space, just in case they said "a metric space is a topological space under the topology of all sets that are open with respect to that metric."
On another note, can someone prove that for any two points [tex]x \ne y[/tex], we have that the intersection [tex]B(x)\cap B(y)[/tex] is not itself an [tex]\epsilon[/tex]-ball?
why is the epsilon so high up? I used "\epsilon" ...
ahh i typed out a good responce and then didn't post it. ok here goes.
take a universal set X
take a collection of subsets of X
1. the collection is closed under arbitrary (countably infinite) union and finite intersection meaning the union of any numbers of sets in the collection is a set in the collection and the intersection of finitely many sets in the collection.
2. the empty set and X are in the collection.
then the collection is called a topology. to be a set in this collection, in the topology, is the definition of being an open set.
1. the union of all these subsets = X, they "cover" X
2. inside the intersection of any 2 of these sets is another set in the collection
this collection is called a basis. sets inside the basis are called basic sets
it can be proved that a topology defined by, meaning here's how we tell you which sets are in the topology: all sets such that for every element in the set there is a basic set containing that element in the set.
you can now see how open balls serve as a basis, which if you prove that all bases generates topologies, generates a "metric topology".
for example:
basis on R1: all sets (a,b) a<b a,b in R.
now the topology this basis generates is the usual topology.
another example
basis on R1: all sets (x-e,x+e) x,e in R
now the topology this basis generates is the "euclidean metric" topology on R1.
ice109 said:
for example:
another example
Aren't these the same topologies? If [tex]x = (a+b)/2, e = (a-b)/2[/tex], then [tex](a,b) = (x-e,x+e)[/tex]
So I guess the "usual topology" on [tex]\mathbb{R}[/tex] is just the "euclidean metric"?
When you want to include latex in a paragraph, as opposed to being on its own line, use
[ itex] [/itex]
without that first space as before ("i" stands for "inline").
they're not the "same"; they're homeomorphic. and you've misused the words a little. the "euclidean metric" is a function, with properties that meet those of a metric. the topology generated by the "euclidean metric" is the "euclidean metric" topology, which turns out to be homeomorphic to the usual topology. note that "euclidean metric" is a phrase i made up and not standard nomenclature.
also your proof that the two topologies are homeomorphic isn't sufficient because you've only proven for xs that are in the middle of the (a,b) interval that there exists an open ball around them. to prove that the two tops(topologies) are homeomorphic you need to show that any open set in 1 is open in the other and vice versa. this amounts to provingthat for all xs in an open set in one top there exists an openball (and open interval for the reverse direction) in the other.
anyway your intuition is correct and if you don't care about proofs don't worry about it. i wager you're a physics student since you know latex and are interested in topology. am i correct?
  • · Replies 25 ·
  • · Replies 16 ·
