Understanding Vector Addition with the Parallelogram and Triangle Laws
  • Context: High School
  • Thread starter Thread starter SS2006
    Laws Vectors
The discussion revolves around the use of the Parallelogram Law and the Triangle Law of vector addition, focusing on when to apply each method and whether they yield the same results for vector addition. The scope includes conceptual understanding and practical application in physics.
  • Homework-related
  • One participant questions when to use the Parallelogram Law versus the Triangle Law for vector addition and whether they always provide the same result.
  • Another participant suggests that the Parallelogram Rule is necessary for adding two vectors, while the Triangle Rule can be used for subtraction by adding the opposite vector.
  • There is a claim that the Triangle Law cannot be used for addition, although some participants believe it yields the same result.
  • One participant proposes that when two vectors share the same origin, the Parallelogram Rule should be used, while the Triangle Law applies when vectors are arranged in series.
  • Another participant notes that half of a parallelogram is a triangle, implying that the information in the parallelogram is also present in the triangle, and suggests that trigonometry could be applied to the triangle formed.
  • A later post requests a comprehensive explanation of the concepts due to an upcoming physics test, indicating a need for clarification.
Participants express differing views on the applicability of the Triangle Law for vector addition, with some asserting it cannot be used while others believe it can yield the same results. The discussion remains unresolved regarding the conditions under which each law should be applied.
Some assumptions about the arrangement of vectors and the definitions of the laws may not be fully articulated, leading to potential misunderstandings about their applications.
SS2006
when do i use
the
Paralleogram Law of Vector Addition
and when
THe Triangle law of vector addition
will they always give the same answer for vector a + vector b?
this is relaly confusing me thanks!
so u can't add using tirangle law
i heard it gives same result
Just add the components!
Substracting an opposite vector will gave the same result as adding it, of course.
Edit:
I think I know see what you mean. When two vectors have the same origin, you use the parallelogram rule.
Perhaps you're thinking of two vectors placed 'in serie', so one starts where the other ends. Then you can make the sum by contructing the triangle. The parallelogram rule will work here as well, by placing the second vector's tail where the first one starts.
Half of a parallelogram is a triangle- and since all the information given in the parallelogram is also present in the triangle you don't really need to draw the whole parallelogram. I think by "triangle law" you are simply referring to apply trigonometry (the sine and cosine laws in particular) to half the parallelogram.
hey will u please explain me the whole concept...becoz tmmorw is my physics test...
pls help...
  • · Replies 33 ·
  • · Replies 19 ·
  • · Replies 27 ·
  • · Replies 32 ·
