mehacute
- 1
Derive a formula for the bullet speed v in terms of D, T, and a measured angle theta between the position of the hole in the first disk and that of the hole in the second. If required, use pi, not its numeric equivalent. Both of the holes lie at the same radial distance from the shaft. theta measures the angular displacement between the two holes; for instance, \theta = 0 means that the holes are in a line and \theta=\pi means that when one hole is up, the other is down. Assume that the bullet must travel through the set of disks within a single revolution.
So, I know that speed = 2*pi*r/t and that speed = r*omega. but I don't know how to factor in the theta. Can someone please derive the whole thing and explain? Thank you.
