Uniformly Charged Circular Sector problem (Electrostatics)
1 reply · 2K views
Boardy222
Hi, I am having problems trying to solve an electrostatics question. Basically there are two circular sectors of radius R and with angle 2β. Both of these sectors have their vertices at the same point in the xy plane (ie at the origin) but have a separation d in the z axis. Also the displaced from one another by an angle in the xy plane of α. Both of these are equally but oppositely charged with a uniform surface charge density σ.
Given this, find the rotational component of the force between these sectors (ie if you where using cylindrical co-ordinates the θ component
Differential charge in cylindirical co-ords is;
dq = σ*ρ*d[itex]\varphi[/itex]*dρ
E = ∫∫ ke**ρ*d[itex]\varphi[/itex]*dρ/z^2 + ρ^2 (sin^2([itex]\varphi[/itex]) + cos^2([itex]\varphi[/itex]) r(hat)
After this i get stuck, I can't resolve this into the different cylindrical components
This looks like the old-fashioned type of radio variable capacitor!
I would approach this problem from an energy viewpoint:
what is the E field between the section of the two sectors opposite each other? Ignore fringing effects.
then: assume α > 0 , what is the energy content of the electric field?
then: moving one of the sectors to α = 0, what is the change in energy content of the E field?
Equate the change in energy to the work done to turn the sector thru the angle α. BTW I think the answer should be a torque, not a force, unless you want to assume the force is applied at radius = R.
