Unit circle derived distribution
The discussion revolves around deriving the probability density function (PDF) for the random variable Y, which is related to a uniformly distributed random variable X from the unit circle. The initial calculations led to an incorrect result of zero for Yden(y), prompting a reevaluation of the absolute values and derivatives involved. The correct approach using cumulative distribution functions (CDF) was suggested, emphasizing that differentiating the CDF can simplify the process and avoid common pitfalls with PDF formulas. The conversation also highlighted the importance of clarifying the distribution of X, whether it is uniformly distributed over the interval or along the unit circle, which impacts the calculations. Ultimately, the participants focused on refining their understanding of the relationships between X and Y to arrive at accurate density functions.
rabbed
Hi
Assume an x-coordinate from the unit circle is picked from a uniform distribution.
This is the outcome of the random variable X with probability density function Xden(x) = 0.5 (-1 < x < 1).
The random variable Y is related to the random variable X by Y = f(X) = √(1-X2) and X = g(Y) = ±√(1-Y2).
What is the probability density function Yden(y)?
Since Yden(y) = Xden(g(y)) / |f'(g(y))|, i first calculate f'(x) = -x/√(1-x2).
Then Yden(y) = Xden( √(1-Y2) ) / f'( √(1-Y2) ) + Xden( -√(1-Y2) ) / f'( -√(1-Y2) )
I get Yden(y) = 0
Where do i go wrong?
Rgds
Rabbed
Your last formula looks (almost) correct but the result is not zero. What are the values of the Xden(..) in that formula and where did the absolute values go ? Also, do compute f'(g(y)), it will simplify.
As an aside, it's a personnal quirk perhaps but I never use the density formulas, it's easy to mishandle them - using cumulative distribution functions instead, you cannot go wrong.
Hey
Thanks for your answer!
I checked my calculation again (in particular the absolute values) and came up with this:
Yden(y) = √y2 / √(1-y2)
Don't know if that's correct.. i'll try do it the other way around, starting with Yden(y) to get Xden(x) = 0.5
How do you do this using CDF instead?
Rgds
Rabbed
That looks ok to me, you might replace ## \sqrt{y^2} ## with just ## y ## though : )
With the CDF ## P(Y\leq y)=P(\sqrt{1-X^2}\leq y)=P(|X|\geq\sqrt{1-y^2})=1-\sqrt{1-y^2}##, differentiate and you get your result.
Of more general applicability, differentiate ##P(|X|\geq\sqrt{1-y^2})##, this gives you the Y-PDF from the X-PDF without needing the actual X-CDF.
Same thing really - for me it's harder to miss a step this way, I just find it more concrete but it's really a matter of taste, and to be perfectly homest, I'm just too lazy to memorize the PDF formula.
Ok, i'll check out that technique, thanks.
So what does the answer tell me, that if i pick an x-coordinate at random between -1 and 1 (with all having equal probability), it's very probable that it's corresponding y-coordinate (on the upper half of the unit circle) is close to 1, and very improbable that the y-coordinate is close to 0?
Rgds
Rabbed
Something like that, yes, depending how improbable is very improbable :)
This relates to the fact that the half-circle has a horizontal tangent at x=0 and a vertical one at x=1.
Hi again...
Is this a correct usage of the CDF method?
Y_den(y) =
Y_cdf'(y) =
( P( Y < y ) )' =
( P( f(X) < y ) )' =
( P( sqrt(1-X^2) < y ) )' =
( P( 1-X^2 < y^2 ) )' =
( P( -1+X^2 > -y^2 ) )' =
( P( X^2 > 1-y^2 ) )' =
( P( X > sqrt(1-y^2) ) )' =
( 1 - X_cdf(sqrt(1-y^2) ) )' =
(-X_cdf'(sqrt(1-y^2))) * (-y/sqrt(1-y^2)) =
(-X_pdf(sqrt(1-y^2))) * (-y/sqrt(1-y^2)) =
(-0.5) * (-y/sqrt(1-y^2)) =
0.5*y/sqrt(1-y^2)
Rgds
Rabbed
Almost. You are off a factor of 2 because of your step ## ( P( X^2 > 1-y^2 ) )' =
( P( X > \sqrt{1-y^2} ) )' ##. Looks like you forgot something here : )
Oh and by the way, do try the tex formatting, it's not difficult (there's a guide in the help/howto section too), and it makes equations much easier to read...
Do you mean this?
( P( X > \pm\sqrt{1-y^2} ) )' =
( P( (X > -\sqrt{1-y^2}) OR (X > \sqrt{1-y^2}) ) )' =
And then i can use the OR/+ formula to continue?
Shouldn't ## P( (X > -\sqrt{1-y^2}) OR (X > \sqrt{1-y^2}) ) = P( X > -\sqrt{1-y^2} ) ## ?
Yes the OR was sthe missing part - but it's easy to handle here : from the symmetry of the distribution of X, ## P(|X|>x)=2P(X>x)##
Note : it is true of course that in general ## P(|X|>x)=P(X>x)+P(X<-x) ## but in this case the two terms are equal, hence the simplification.
rabbed said:
Hi
This seems to me to be ambiguous. Yes, the x coordinates of points on the circle all lie between -1 and 1. But does this mean that x is uniformly distributed on -1 to 1, as you are assuming here, or does it mean that x is x coordinate of a point on the unit circle and the points are uniformly distributed?
Those are not at all the same. In the latter case, X is cos(\theta) with \theta uniformly distributed between 0 and 2\pi.
I get Yden(y) = 0
Rgds
Rabbed
Thanks, I've got the same answer with the CDF method now.
https://www.physicsforums.com/members/hallsofivy.331/:
Yes, i mean the x-coordinate should be uniformly distributed, not the angle. But I do want to check that also later, to see the difference.
My next concern is how i get from:
Y_pdf(y) = y/√(1-y2)
X = g(Y) = ± √(1-Y2)
to:
X_pdf(x) = 0.5
I think i go wrong here:
( P( ± √(1-Y2) < x ) )' =
( P( -√(1-Y2) < x OR √(1-Y2) < x ) )' =
( P( √(1-Y2) > -x OR √(1-Y2) < x ) )' =
( P( 1-Y2 > x2 OR 1-Y2 < x2 ) )'
Any tips? :)
Rgds
Rabbed
Your inequalities are wrong... x^2&gt;f(y) \Rightarrow x &lt; -\sqrt{f(y)} ~~\text{or}~~ x&gt; + \sqrt{f(y)}
Also when you have something like: \pm \sqrt{1+Y^2} \le x it doesn't really make sense...
edit \*what happened with the square roots and latex?*\
Thanks,
But how do you go from X = g(Y) = ± \sqrt{1-Y^2}
to insert into the CDF definition P(X &lt; x)
Should i start by squaring them both, so that i can insert
X^2 = g(Y)^2 = (± \sqrt{1-Y^2})^2 = |1-Y^2|
into
P(X^2 &lt; x^2)
and get
P(x^2 &gt; |1-Y^2|) = P(x &lt; -\sqrt{|1-Y^2|}\ OR\ x &gt; \sqrt{|1-Y^2|})
Rgds
Rabbed
Any pointers on this, please?
Rgds
Rabbed
  • · Replies 30 ·
