Unit conventions (SI versus others)
  • Level: High School
  • Thread starter JR Jonsson
    Unit
104 replies · 13K views · last reply
OmCheeto said:
It appears to say "50dkg"
50 dekagrams = ½ kg
Still wrong, as ##d## means "deci" which is 0.1, so 50 dkg = 5 kg. Uranium maybe?
Edit: Just found out that ##da## for "deka" is relatively new and they formerly used indeed "(dk)g" for dekagram = 10 g. So it's all in all more a timestamp than a sample of interesting matter.
jbriggs444 said:
Body weight is a mass measurement and is properly reported in pounds mass or kilograms mass. Anyone who thinks it should be reported in Newtons has taken one first year physics course too many.
OK, I can't really disagree with you on that one.
How about world weightlifting records? Why is the record for the snatch (unlimited) shown as 220 kg? Surely that should be shown as 2150 N? I think even I could snatch 220 kg on the moon, for instance.
My real point is, arguments over which system of units is "better" are really just silly.
Just to round out the discussion of mechanic's tools, I have three sets - inch, metric, and Whitworth (for the old Brit motorcycles). The ironic thing is, people often point to Whitworth as "see, we have too many "standards'" while the fact is, Mr Whitworth was the guy who (in 1841) said "we need to standardize fasteners." https://en.wikipedia.org/wiki/Joseph_Whitworth
OmCheeto said:
First time in a LONG time that I've seen the "Rankine" temperature scale used. :partytime:
I like Delisle!
fresh_42 said:
I spent at least a full day in total just by switching to or from foot, miles or gallons since I joined PF. What a waste.
Whatever in the world did you do this for? Why switch? If the information comes to you in SI, by all means, work the problem in SI. If the information comes to you in US Customary units, then converting it to SI is an utter waste of time. The point is simply that any coherent systems of units works, and there is no need to convert.
fresh_42 said:
... In this sense, yes, call me snobbish.
Me too. I do almost all of my calculations in SI now.
Perhaps sometime in the future, PF will require all problems to be presented in SI, just like we all have to speak English.
Maybe they can make an "Archaic Physics Units" sub-forum, just for the old-timers and historians.
btw, that was really interesting reading about the Delisle temperature scale at wiki, as I'm fairly certain I've never heard of it.
It was originally backwards!
Kind of like the "Apparent Magnitude" scale of celestial objects. I understand the historical reason for it, but it still annoys me.
They also pointed out 3 other temperature scales which I hadn't heard of: Newton, Réaumur, and Rømer.
If you're a savant, maybe, and can think in different systems.
I'm no savant, so I convert everything to SI. Base units. As missing a prefix can send your calculations off by hundreds of millions of years! :redface:
celsius was originally backwards! A friend of him turned it posthum!
Someone should start a new thread; "When did science switch from the sport-like '#1 is the greatest! And higher numbers(2nd place, 3rd place) mean less. :olduhh:' to whatever it is we have now?"
fresh_42 said:
... while the real world would love to use e.g. Delisle
While doing a search on the Delisle scale, the Wikipedia information has this conversion chart I found interesting. Here's a scaled down image of it I made.
Conversion chart comparing eight temperature scales on aligned number lines: Kelvin, Celsius, Fahrenheit, Rankine, Römer, Newton, Delisle and Réaumur. A red line marks 313.15 K = 40 °C = 104 °F = 563.67 °Ra = 28.5 °Rø = 13.2 °N = 90 °D = 32 °Ré.
  • Conversion chart comparing eight temperature scales on aligned number lines: Kelvin, Celsius, Fahrenheit, Rankine, Römer, Newton, Delisle and Réaumur. A red line marks 313.15 K = 40 °C = 104 °F = 563.67 °Ra = 28.5 °Rø = 13.2 °N = 90 °D = 32 °Ré.
OmCheeto said:
That right there points to one of my principle objections to SI as it is commonly (improperly) used. Proper SI says all lengths are in meters, and that works just fine. Right now, I'm dealing with a problem concerning machine parts with all dimensions in millimeters (yes, I can multiply by 10^3). The difficulties come when calculating mass moments of inertia, with density in kg/m^3, linear dimensions in mm, so suddenly there is a factor 10^15 that drops into everything. What a mess! If it was all dimensioned in inches with weights in pounds, then the MMOI calc would give lb-s^2-in in the usual way, with no massive fudge factors required. But its so much better, or so they tell me ...
Doh! I guess I read through that section too fast. From that chart, the Delisle scale is STILL BACKWARDS!
The Celsius scale, like the Delisle scale, originally ran from zero for boiling water down to 100 for freezing water. This was reversed to its modern order after his death, in part at the instigation of Swedish botanist Carl Linnaeus and the manufacturer of Linnaeus thermometers, Daniel Ekström.​
This is nonsense. If all problems 'should' be done in the base units, there would be no reason for the prefixes to even exist. It's as if you are trying to prove your car is better than ours by beating ours with a baseball bat before comparing them. It says more about the chip on your shoulder than about the ease/difficulty of using the units.
Are you calling the prefix a fudge factor? Is 12 inches per foot a fudge factor? What if you did the problem in in^3 and you find the catalog for the part you need is in ft^3. Can you do that "fudge" in your head?
Caveat: Every industry has conventions for unit choices and rolled-up constants for common calculations. It may seem easier once you have them memorized, but it is only because they are memorized. A couple of days ago I had to dissect the rolled up constant 6356 for showing my work in a report. It took me an absurd amount of time.
If you drive your car as actually recommended instead of driving it on the highway at 60mph in first gear, it will definitely work much better.
A bit more on that last example:
cfm x in wc / 6356 = horsepower
I literally used this equation for years thinking 6356 included a constant of nature* (like 1.082 does...) before I realized it was entirely comprised of IP unit conversions. And so I didn't realize the equation I was using was simply airflow x pressure = power. No conversions inherrent!...
...until I did a project in SI and found that m^3/s x Pa = Watts
It was a revelation! Physics makes sense as applied to engineering!
Two minor caveats:
-You of course need to know the named units. But it is as if ft-lb=horsepower, but without the conversion factor. Still easier.
-Can't avoid conversions with time: Often the flow rate is expressed per hour. But again, that issue is worse in IP. I once showed my boss a calculation with ton-hours per year as the unit and he kicked me out of his office! (it has three different units of time in it).
*An not for nothing, but SI is also designed to eliminate conversion factors with some constants of nature as well.
As a fellow who still keeps Whitworth wrenches
and uses Imperial unit steam tables
and considers himself practical
I agree with Dr D - we should be fluent in both systems.
i appreciate some of the simplicities of the Metric system
but i curse my Oldsmobile with its fasteners that are SAE on the drive train and Metric on the body.
The eye can pretty easily discern the 1/16 inch increments in SAE bolt heads , but a mm being only ~2/3 of that fools me most every time.
We EE's have it easy because our units are already SI (Amps Volts Ohms Farads Henries).
but I've always pitied ME's because their Ohm's Law involves local gravity, Reynolds Number, viscosity, density, a square root, and a discharge coefficient.
So i think you guys ought to ease up on Dr D . His point is simply that we should be multilingual if we wish to consider ourselves well rounded.
When nobody can read cursive anymore how will we proof-read printed versions of the Bill of Rights ?
Magnetics is a place you really need to be fluent - there's still Oersteds and Gilberts and Maxwells floating around. Every specialty develops its own shorthand with implicit 'fudge factors' .
Web page excerpt from a unit converter defining line per square centimeter, line per square inch, and gamma as units of magnetic flux density, with links and a converter link at the bottom.
  • Web page excerpt from a unit converter defining line per square centimeter, line per square inch, and gamma as units of magnetic flux density, with links and a converter link at the bottom.
