Uranium density in fuel meat/kernel
7 replies · 2K views
nuclearsneke
TL;DR
Tl;dr - why is it so low and how to get the right value of density?
Howdy partners!
I am currently doing some project on Klt40s neutronic simulation (you might have heard of Akademik Lomonosov, the floating npp). But I have encountered a problem with fuel density. The only info that i got that "uranium density IN FUEL MEAT/KERNEL" is 4.5 g/cm3. The Fuel is uranium dioxide dispersed in aluminum-silicon alloy.
However, I need the fuel density for further calculations of nuclear densities (1/cm3).
I know that density of uo2 is 10.9 g/cm3 and density of the alloy is around 2.7 g/cm3. Have you guys gotten any ideas on how to calculate the whole fuel density and maybe fractions of fuel and matrix (sial alloy) from these data?
nuclearsneke said:
Summary:: Tl;dr - why is it so low and how to get the right value of density?
That is the uranium density, as opposed to UO2 density correct?
And is it 14% enriched?
The density would be low because the U, in the form of UO2, is dispersed in Al-Si alloy.
I get it that density of fuel would be low due to its dispersion in alloy. But is there any way to calculate a density of fuel pellet starting from this "uranium density in fuel kernel" value?
Well, assuming that the 'uranium density' refers to uranium with ρ = 4.5 g/cm3, then the UO2 density in the dispersion would be ~5.1 g/cm3, based on 0.8814 gU/gUO2.
For a given volume V of dispersion, the mass of the volume would be xV*ρ(UO2)+(1-x)V*ρ(Al) = M with a volume V and density D=M/V of the dispersion ( x = volume fraction of UO2), assuming that there is no interaction between UO2 and Al. The total mass M = m(UO2) + m(Al).
The mass of UO2 in the dispersion is simply xV*ρ(UO2) and the effective density is just x*ρ(UO2) = 5.1 g/cm3, and so x = 0.465, based on ρ(UO2) = 10.96 g/cm3.
This is basically an application of 'rule of mixtures', or 'law of mixtures'.
https://link.springer.com/referenceworkentry/10.1007/978-1-4419-6247-8_6810
https://www.sciencedirect.com/topics/engineering/rule-of-mixture-equation
Wow. Given that I had a material science course mostly focused on phase diagrams and lattice types, I have never heard of that preem law/rule of mixture. Now the problem I mentioned above looks so trivial... Thank you, Astronuc!
Well, I had much the same experience. I didn't hear about the 'rule/law of mixtures' until I encountered in the job. I've done similar problems in the past. It can be tricky. In this problem, one must assume no chemical interaction between the UO2 and Al-Si-alloy, which is a reasonable assumption if done at low temperature, which it usually is. Basically one would mix powders and cold press them between layers of Al-Si. Also, one must be clear on the problem statement, which is why I asked about the density of uranium vs uranium dioxide. Things can go wrong when there is miscommunication between design and manufacturing, or between engineering groups.
