Use Newtonian dynamics to find the speed at this position
This discussion focuses on applying Newtonian dynamics to solve a problem involving a non-Hookean spring characterized by coefficients α = 60.0 N/m and β = 18.0 N/m². The potential-energy function U(x) is derived using the force equation F = αx + βx², leading to U(x) = ∫F dx. The speed of a 0.900 kg mass attached to the spring is calculated at a position 0.500 m from equilibrium using conservation of energy principles. Instantaneous power at this position is also explored, reinforcing the relationship between force, mass, and acceleration.
  • Understanding of Newtonian dynamics
  • Familiarity with potential energy concepts
  • Knowledge of calculus for integration
  • Basic principles of conservation of energy
  • Calculate the potential-energy function for different spring constants
  • Explore the implications of non-Hookean behavior in mechanical systems
  • Learn about instantaneous power calculations in dynamic systems
  • Study conservation of energy in non-conservative forces
Students in physics, mechanical engineers, and anyone interested in advanced dynamics and energy conservation principles in non-linear systems.
Jessikalinphy
I need some help with this hwk! Please someone help me...:confused:
A certain spring is found not to obey Hook’s law; it exerts a restoring force if it is stretched or compressed, where α = 60.0 N / m and β = 18.0 N / m2. The mass of the spring is negligible. (a) Calculate the potential-energy function U(x) for the spring. Let U = 0 when x = 0. (b) An object with mass m = 0.900 kg on a frictionless, horizontal surface is attached to this spring, pulled a distance 1.00 m to the right (the + x-direction) to stretch the spring, and released. What is the speed of the object when it is 0.500 m to the right of the equilibrium position? (c) Use Newtonian dynamics to find the speed at this position. (d) What is the instantaneous power when x = 0.500 m?
According to the given coefficients it seems the relationship is of the form
[tex]F = \alpha x + \beta x^2[/tex]
therefore
(a) use
[tex]U(x) = \int {F\ dx} + C[/tex]
(b) use conservation of energy
(c) I am not sure what to do here maybe
[tex]a = \frac{dv}{dt} = \frac{F}{m}[/tex]
therefore
[tex]\frac{dv}{dx} \frac{dx}{dt} = \frac{dv}{dx}v = \frac{F}{m}[/tex]
giving
[tex]\frac{1}{2}v^2 = \int {\frac{F}{m}dx} + C[/tex]
which in essense is conservation of energy again ?
thankyou...
  • · Replies 17 ·
