How is the Gamma function used in solving for the expectation value of momentum?
The discussion focuses on the use of the Gamma function in calculating the expectation value of momentum, specifically how to transition from the integral of x^2 e^(-x^2) to Gamma(3/2). The integral is shown to be symmetric, allowing it to be expressed as twice the integral from 0 to infinity. By substituting x^2 with t, the relationship to the Gamma function is established. The final result confirms that Gamma(3/2) equals the integral of x^2 e^(-x^2) over the entire real line. This connection clarifies the mathematical steps needed to solve the problem.
jg370
jg370 said:
Hi,
My question relates to the solution to a question regarding the expectation value of momentum, that is <p^2>.
As the solution unfold, we have the following two expressions:
-\frac{m*\omega*\hbar}{\sqrt Pi}\left[\int_{-\infty}^{\infty} \xi^2 *e^-\xi^2 d\xi-\int_{-\infty}^{\infty} e^-\xi^2 d\xi\right]
-\frac{m*\omega*\hbar}{\sqrt Pi}\left[\Gamma(\frac{3}{2}) -\sqrt Pi\right]
My problem with the above, is that I do not understand how one gets from
\left[\int_{-\infty}^{\infty} \xi^2 *e^-\xi^2 d\xi\right]
to
\left[\Gamma(\frac{3}{2}) \right]
I have reviewed the \Gamma function and tried to make a conversion from the exponential function to the gamma function; this did not lead me to understand the relation ship involved in this case.
I hope that some one can help me with this.
I thank you for your kind assistance
jg370
The function under the integral sign is symmetric wrt the origin 0, so the integral is twice the value it has at 0. So
I = \int_{-\infty}^{\infty} x^2 e^{-x^2} {} dx = 2 \int_{0}^{\infty} x^2 e^{-x^2} {} dx
But
\Gamma\left(\frac{3}{2}\right) = \int_{0}^{\infty} t^{1/2} e^{-t} {} dt
Now make te substitution x^2 = t. You'll immediately get your result.
From the definition of the gamma function:
\Gamma(z) = \int_0^\infty t^{z-1}e^{-t}dt
Now make the substitution t=u^2, dt = 2u du, then
\Gamma(z) = \int_0^\infty u^{2(z-1)} e^{-u^2} 2 u du = 2\int_0^\infty u^{2z-1} e^{-u^2} du
Now, plugging in z=3/2, and recognizing that the resulting integral is even gives:
\Gamma(\frac{3}{2}) = 2\int_0^\infty u^2 e^{-u^2} du = \int_{-\infty}^\infty u^2 e^{-u^2} du
This is what you wanted to show.
