Using centroid of object to find moment of inertia
The discussion focuses on the relationship between the centroid of an object and its moment of inertia, particularly in the context of a spun spandrel and a parabola. It highlights that while the centroid can be used to find the moment of inertia, the method may not yield correct results due to the distinction between first and second moments of area or volume. Specifically, the centroid is derived from the first moment, while the moment of inertia relies on the second moment, which involves squaring the distance from the axis. This discrepancy is crucial, especially for objects with an axis of symmetry, where the centroid lies on the axis but the second moment does not equal zero. Understanding this difference is essential for accurately calculating moments of inertia.
petitericeball
Hey, I was doing some problems involving finding the moment of inertia of a spun spandrel, and I came across the idea of using the centroid to find the moment.
For example, if you have a parabola, find the centroid. If you're rotating around the x-axis (y=x^2), then find y_bar and multiply the total mass by y_bar^2 (or x_bar^2 for Iyy). This isn't working, but it seems like it should. Can anybody explain why?
Maybe because the centroid is based on the first moment of area or volume (x*A or x*V) and the moment of inertia is based on the second moment of area or volume (x^2*A or x^2*V). For example, objects which have an axis of symmetry will have a zero first moment about that axis, so that the centroid will lie on the axis (for bodies with constant rho at least). On the other hand, second moments about the same axis of symmetry will be non-zero (due to the presence of the x^2 term).
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 16 ·
