Using exponents and logarithms to calculute pH
interhacker
If a solution containing a heavy concentration of hydrogen ions(i.e., a strong
acid) is diluted with an equal volume of water, by approximately how much is its
pH changed? (Express (pH)diluted in terms of (pH)original.)
I think the question requires the equation defining pH:
[itex]pH = \log[H+][/itex]
According to the document, the answer is supposed to be:
[itex]pH_{dilute} = pH_{original} + \log 2[/itex]
If the concentration of H+ ions in the original (undiluted) solution is [H+] and you add approximately an equal amount of H+ ions by diluting the original solution, what is the total concentration of H+ ions in the dilute solution?
interhacker,
pH means negative of the logarithm of hydrogen ion concentration; you were missing the negative sign.
pH = -log[H+]
If you just double the volume to make the dilution, this is only a fraction of a pH unit change. The concentration change must be up or down by a factor of 10 for a change of pH of one unit.
He must have made another mistake that canceled out the first one and made the answer right! :biggrin:
